Vieux 20/01/2016, 10h14   #1
djspike
Avatar de djspike
djspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to all
Par défaut Calculateur sagem renault espace 3
Bonjour, quelqu'un peut me donner le pinout( Galetto 54)pour ce calculateur. Et où ce trouve l'eeprom merci.
djspike est déconnecté   Réponse avec citation
Vieux 20/01/2016, 10h33   #2
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
c'est boitier prechauf ou refroidicement ?
Vieux 20/01/2016, 10h59   #3
Binbin
Avatar de Binbin
Pouvoir de réputation: 52
Envoyé par selim95 Voir le message
Ceci est le boitier de préchauffage.
Vieux 20/01/2016, 11h38   #4
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
C Calculateur de préchauffage
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
Vieux 20/01/2016, 11h43   #5
djspike
Avatar de djspike
D'accord le calculateur se trouve où? Je le vois pas
Vieux 20/01/2016, 12h21   #6
kmtech
Avatar de kmtech
Pouvoir de réputation: 67
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
quel moteur ? quelle année ?
Regarde sous la batterie
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ...
kmtech est déconnecté   Réponse avec citation
Vieux 20/01/2016, 12h59   #7
djspike
Avatar de djspike
Année 1997
Moteur : JE0E05
Vieux 20/01/2016, 18h29   #8
djspike
Avatar de djspike
Problème résolu merci
Vieux 20/01/2016, 18h47   #9
adam_diag
Avatar de adam_diag
adam_diag is an unknown quantity at this point
Envoyé par binbin Voir le message
ceci est le boitier de préchauffage.
oui vraiment
adam_diag est déconnecté   Réponse avec citation
Vieux 21/01/2016, 03h05   #10
ecutech
Avatar de ecutech
Salut l'immo est dans le dash ou immobox ensuite problème résolu ne donne pas la solution la moindre des chose même si tu t'ai débrouiller tous seul c'est de donner la solution afin d'aider les autre je pense que tu connais le principe du forum . Bref content que t'ai trouver .
Envoyé de mon GT-I9505 en utilisant Tapatalk
Vieux 21/01/2016, 14h33   #11
djspike
Avatar de djspike
Aufait, on avait changé le moteur la voiture ne voulais pas démarré, j'ai récupéré l'immo j'ai récupéré le code pin, j'ai générer une clé la voiture démarre. Pour le calculateur dans ce modèle il se trouve sous la batterie collé à l'abs, si quelqu'un au cas où il le chèche sur ce modèle.
Bonne journée
Compteur sagem espace 4 Nico Tableau de bord (Dashboard) 9 23/12/2014 18h48
Compteur espace 4 Sagem identique au scenic kazouille Tableau de bord (Dashboard) 3 13/09/2014 18h13
RENAULT CLIO 1.2 ESSENCE calculateur sagem hassini Renault, Dacia, Nissan 0 09/06/2013 18h01
calculateur 406 sagem sl 96-1 psa essence marcusbilly Immobilizer dumps/solutions 0 27/02/2012 11h29
calculateur 306 1.4 sagem split78 Immobilizer dumps/solutions 4 06/06/2010 22h54
Fuseau horaire GMT +1. Il est actuellement 13h03.
