Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 11/10/2015, 00h25   #1
ilirii
Avatar de ilirii
ilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really nice
Question 42 dde eeprom bmw 320d 1999
hi to everyone i need help about my bmw 320d 04/1999 let me explain what happend
changed the vp 44 and i had cdp+ inside of menus you have pump characteristic map and etc so i did that and i got and error of 42 dde-eeprom coding or configuration so what i did i bought mpps flashed a file got it online still no luck bought full inpa ediabas k+dcan winkpf diss-44-39-55 ista etc etc so diss hase a menu to do that program pump dageblaich or something like it but cant do it need to mesure something and ends with an error, so anyone any idea and pls dont use delphi cdp+ exept for error codes and key programing nothing else happend other stuff to me with it also i need the file for my dde as i have lost it
Software number: 7785036
Office number: 2249828
Assembly identification number: 7785035
or
Software number: 7789550
Assembly identification number: 7789549
or
http://www.realoem.com/bmw/enUS/partxref?q=7789549
ilirii est déconnecté   Réponse avec citation
Vieux 11/10/2015, 08h11   #2
jah83
Avatar de jah83
Pouvoir de réputation: 245
Did you manage to resolve your eeprom problem? What s the probleme on the car ?
Vieux 11/10/2015, 14h03   #3
ilirii
Avatar de ilirii
well i didnt i still dont have any solution to it exept that to find an dde with ews to mount it to the car to program the key to ews and see what happends usually you have that problem when your vp44 is broken but mine its not my delphi cdp+ erased the eeprom i guess and now no communation betwen them when i take another car and i drag it to start it smokes alot after a while it starts but doesent stay idle so no solution yet
Vieux 11/10/2015, 15h57   #4
jah83
Avatar de jah83
I got quite the same problem on a 520d e39.
I got eeprom error dtc but the engine (ans so the vp44) has been changed.
Car works good the only problem I got is that between ~25/30 ° and 55/60° it doesn t start like it qhould. Like you it needs fews time ans when it start I ve white smoke. But it manages to keep idle without problems
Could you send me your ori files just to take a look ?
Vieux 11/10/2015, 20h15   #5
ilirii
Avatar de ilirii
well i dont have it here tonight and diss updated me with another software that aint good but still i will downloadit from dde via mpps tomorow and i will send it to you i asked for the right ori i wrote up the zusb look if you can find me them so i can flash it with mpps thanks
Vieux 15/10/2015, 00h22   #6
ilirii
Avatar de ilirii
well tried to read the dde no luck dont know why anyway got a new dde with ews and key will mount it tomorrow and c what happends
Vieux 15/10/2015, 01h42   #7
ilirii
Avatar de ilirii
no luck with winkpf either
Vieux 15/10/2015, 07h20   #8
jah83
Avatar de jah83
Ok please tell me if it works well after exchange
Vieux 15/10/2015, 10h35   #9
ilirii
Avatar de ilirii
ok np :D i will and does anyone hase the ori that i asked and does someone know how to boot this this dde 3.0
Vieux 15/10/2015, 11h00   #10
jah83
Avatar de jah83
I dont have this ori sorry. why do you want boot it? You can Read it on table easily by pin out
Vieux 15/10/2015, 19h49   #11
ilirii
Avatar de ilirii
well pinouts i dont know because i found in my winkpf the ori the last one but i dont know how to flash it in my dde on the car ^^ecu not found ^^ so far no progress didnt had time to check the new dde its damn cold here so on some other days will try and i will let you know just send me the pinouts schema thanks
Vieux 15/10/2015, 21h45   #12
ilirii
Avatar de ilirii
Wink
Envoyé par bugmenot2020 Voir le message
i have same problem :(
for everyone for this problem you should open the vp44 edc to look if this chip its burned http://www.ebay.com/itm/121294124776...84.m1436.l2649 this is how you watch it open the edc https://www.youtube.com/watch?v=BUXHxXUdB3U and how you remove the vp44 dont turn it dont touch it and mark the pump caouse there are no timing marks look for thee irlr chip ^^resistor^^ you name it and if its ok it needs programing but if its burned be carreful on repairing it https://www.youtube.com/watch?v=jUq-d_HbGu0 its very fragile you mount it and no problem not like me who has erased the eeprom and no one dont ya use delphi cdp+ to program the eeprom cause it will erase the eeprom and you are done
1 check edc no programing nothing
2 if irlr its burned change it mount it and start the car nothing else but
if aint burned post the ori here someone will watch the eeprom soft and will give it to you dont do anything stupid like i did :D
The Following User Says Thank You to ilirii For This Useful Post:
Roturbo (04/04/2025)
Vieux 15/10/2015, 21h49   #13
ilirii
Avatar de ilirii
jah83 do you have schema of pinout to do that on table thanks
Vieux 16/10/2015, 02h24   #14
ilirii
Avatar de ilirii
Repeat NO PROGRAMING Needet when first appears the error 42 check up the edc of vp 44 dont do nothing else
Vieux 18/10/2015, 08h09   #15
jah83
Avatar de jah83
I m gonna look for the pinout if I find them back cause I did it few months ago, anyway you should be able to read it by obd too
bmw 320d nas33 BMW, Mini, Rolls-Royce 6 13/11/2014 16h24
Bmw 320D e46 Elec-Passion Automobile en général 13 07/09/2014 23h16
bmw e90 320d 163 beaugoss330 Fichiers d'origine, carto, dump, fullbackup 5 27/08/2013 18h16
recherche eeprom E46 320D tony76 Tableau de bord (Dashboard) 5 02/03/2013 18h59
Fuseau horaire GMT +1. Il est actuellement 19h15.
