Vieux 20/09/2015, 15h36   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut DiagBox v7.77 update
Hello All,
I have DiagBox v7.77 working on the following platform: HP ENVY-M6, Intel i5, 8GB RAM, 1TB Hard Drive, running Windows 10 64bit (10547). DiagBox v7.77 is installed on Windows 10 x86 (10547) which is running on VMware Desktop 12 Pro.
I was surprise that it was easy to upgrade and make it run!!!, so I will perform some tests to see if it is fully functional before further writing on this matter.
Initial readings I got are similar to all previous versions... including the "Communication problem, in DB07.jpg" which I get (with all versions) every time I try to erase Injection Faults (only)... It seems a lot of people have faced this issue. Some are saying it is a fuse others are saying it is a loose connector. If someone has met this problem and solved it; feedback is appreciated...
DiagBox v7.77 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
Type de fichier : jpg DB01.jpg (85,2 Ko, 49 affichages)
Type de fichier : jpg DB04.jpg (42,3 Ko, 22 affichages)
Type de fichier : jpg DB05.jpg (93,8 Ko, 16 affichages)
Type de fichier : jpg DB06.jpg (40,6 Ko, 16 affichages)
Type de fichier : jpg DB07.jpg (50,4 Ko, 19 affichages)
Simple est déconnecté   Réponse avec citation
Vieux 21/09/2015, 05h40   #2
Simple
Avatar de Simple
Procedures to upgrade to DiagBox v7.77.
Please notice that this is intended for educational purposes and that you perform any or all the below at your own risk and I hold no responsibility for any issue you may face.
Procedure 1 (From the internet):
1- Go to C:\AWRoot\bin\fi\ and create another copy of cashe folder naming it cashe.Org
2- Run DiagBox and click on upgrade, after successful download close the application.
3- Run DiagBox it will start the upgrade process and when run for the first time, it will give 6 or 7 error message, keep klicking ok until DiagBox closes down.
4- Go back to C:\AWRoot\bin\fi\ and delete the folder cashe and rename cashe.org to cashe
5- Run DiagBox and it will run successfully.
Procedure 2 (Local upgrade):
2- Download the attached file, Expand it and copy the contents of the updt_77 to C:\AWRoot\dtwr\updt\ directly replacing and overwriting existing files and folders
3- Run DiagBox, it will start the upgrade process, when it finishes successfully click ok, it run for the first time and will give 6 or 7 error message, keep klicking ok until DiagBox closes down.
If you like to try newer file versions:
3- When you receive the first error message in point 3, DiagBox creates 28 new files in the cashe folder copy this folder into a folder named cashe.cpy, because the contents of the original cashe folder get deleted after the crash. Continue to click on the error message until diagBox closes.
4- Now, copy into the (empty) cashe folder the 13 files that start with fr.actia.AWF.xxxxxxx.dll from the cashe.org and all other files from cashe.cpy.
If you don’t like update 7.77 or you have an issue with it. Run Maitresox’s 7.75 to 7.76 again and it will successfully downgrade it to DiagBox v7.76.
Type de fichier : rar updt_77.rar (329,6 Ko, 75 affichages)
diagbox ask for update Chumovoy LEXIA, PP2000, DiagBox 0 10/07/2014 16h56
Diagbox update 7.44 to 77.45 fufounet LEXIA, PP2000, DiagBox 5 23/06/2014 11h57
Diagbox update 7.33 to 7.34 fufounet LEXIA, PP2000, DiagBox 5 24/02/2014 01h16
diagbox update 6.32 deedee LEXIA, PP2000, DiagBox 0 23/12/2012 22h15
New Maj Diagbox UPDATE v05.16 ramaz PSA Group Peugeot, Citroën 0 26/02/2011 09h34
Fuseau horaire GMT +1. Il est actuellement 09h40.
