Vieux 15/07/2015, 19h45   #1
asterixvaovao
Avatar de asterixvaovao
asterixvaovao is on a distinguished road
Par défaut - Malfunction occurred since erasing DTC memory
bonjour a tous
qui a deja eu ce souci?
j ai controlle une q5 edc17 et voila ce que je vois... impossible d effacer les defauts.
ci-dessous le log
merci a tous
Establishment diagnostic session with selected unit ....
Diagnostic channel is open.
Device identification:
VAG Number SW: 8R0907401J 0008
VAG Number HW: 8K1907401A H01
System description: 3.0TDI EDC17
Workshop (Part/Imp/Supp): 00000/0000/06335
Vehicle information:
Coding: 0121002c240f0120
Engine code: CCWA
FAZIT identification:
FAZIT Identification: BPG-810 14.10.08 1334 0644
ASAM/ODX Identifier: EV_ECM30TDI0118R0907401J 001008
Production Change Number: 15H01---
Workshop System Name (J-number): J623
Flash information:
Programming APPLICATION attempts: 2 / 2 / 2 / 2 / 2
Programming APPLICATION successfull: 2 / 2 / 2 / 2 / 2
Flasher info: 30.06.11 98149/0318/01003
48.06.17 98149/0318/01003
Flash status: OK
002643 U101700 - ABS brake control module - Read out DTC
007144 U100800 - Diagnostic interface for data bus-J533 - Read out DTC
008469 002115
005585 0015D1
- active/static
018660 0048E4
004814 P056200 - System Voltage - Low Voltage
007902 001EDE
- Tested in current operating cycle
005398 P157200 - Left Electro-Hydraulic Engine Mount Solenoid Valve -N144 - Short circuit to ground
- active/static
- Malfunction in current or last driving cycle detected
004978 P067000 - Glow Plug Module Control Circuit
- active/static
- Malfunction has not occurred in current operating cycle
- Not confirmed
005368 P302C00 - Low heat output relay - Short circuit to ground
- active/static
- Not confirmed
005369 P302D00 - High heat output relay - Short circuit to ground
- active/static
- Not confirmed
005382 P101500 - Bypass Flap Air Cleaner Valve -N275- - Short circuit to ground
- active/static
002937 U102600 - Transmission control module - Read out DTC
009490 002512
- active/static
005301 0014B5
- Not confirmed
- No warning display on
007155 001BF3
007157 001BF5
- active/static
- Not confirmed
005507 P202100 - Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 - Low
- active/static
- Not confirmed
005608 0015E8
004708 U016400 - Lost Communication With HVAC Control Module
004713 U012100 - Lost Communication With - Anti-Lock Brake System (ABS) Control Module
004714 U021200 - Lost Communication With Steering Column Control Module
004715 U015500 - Lost Communication With - Instrument Panel Cluster (IPC) Control Module
004716 U012800 - Lost Communication With Brake System Control Module
004719 U014600 - Lost Communication With Gateway "A"
004720 U014100 - Lost Communication With Body Control Module "A"
005523 P157000 - Engine Control Module (ECM) disabled
004629 P068A00 - ECM/PCM Power Relay De-Energized Performance - Too Early
005307 0014BB
asterixvaovao est déconnecté   Réponse avec citation
Vieux 15/07/2015, 21h34   #2
smart057
Avatar de smart057
Pouvoir de réputation: 40
Salut c'est une histoire de protection du calculo,ya une lecture sur table en bootmode qui a été fait?
Vieux 28/07/2015, 16h00   #3
doud77
Avatar de doud77
+1 Smart057,
il semble qu'il y ait une lecture/ecriture de l'ECU et qu'il soit désormais bloqué. Y a t il eu manipulation de cet ECU?
diagbox - internal communication error has occurred breakli LEXIA, PP2000, DiagBox 9 30/10/2020 01h26
program Flash Memory misterixion Informatique 1 10/04/2015 23h08
Q Flash memory effacer/reprogrammer benaknoun Programmateur de composant (flasher) 0 01/11/2009 03h35
Fuseau horaire GMT +1. Il est actuellement 01h33.
