Vieux 15/07/2010, 12h03   #1
nany
Représentant T-E
Avatar de nany
nany is just really nicenany is just really nicenany is just really nicenany is just really nice
Thumbs up A trick to skip the EMULATOR in all Sirius 32
Hi guys, i have a trick to make all sirius 32 start. After programming the 29F200, i lift the pin number 43 from 29f200 (Write enable#) and i connect to 5V (pin number 23 from 29F200). The engine starts and when the ecu wants to modified the 29F200, it won´t because we disable the writing. Make sure that you program a good dump from the correct engine. I have 4 categories.
- 1.6 8V with A/C
- 1.6 8V without A/C
- 1.6 16V with A/C
- 1.6 16V without A/C
These are all engine types with sirius 32 Pièce jointe 2937
These are the dump for the 4 categories, REMEMBER: CUT WIRE 58.
Tlemcen-Electronic [ Bejai Diag Tools ]
Price & Quality
Phone Mobile : 06 61 76 01 64
Phone Fix : 034 12 84 15
Dernière modification par nany ; 21/09/2011 à 15h18.
nany est déconnecté   Réponse avec citation
The Following 22 Users Say Thank You to nany For This Useful Post:
adlen22 (14/10/2021), Amine-TE (17/07/2010), auto diag (19/12/2011), Auto16 (08/03/2011), camacho (04/04/2014), cletek (15/07/2010), danyparis (12/03/2014), Formator (29/08/2010), Helpful (23/03/2013), juned (25/02/2014), Licokite (09/11/2013), mb124 (28/07/2010), Mitch82 (17/07/2010), newfree (18/12/2012), poze (16/04/2015), prodiag (17/07/2010), reda75 (15/07/2010), requin51 (16/07/2010), ricards99 (15/07/2010), samsai (25/11/2011), sdesign (23/01/2012)
Vieux 17/07/2010, 12h24   #2
Amine13
Avatar de Amine13
Amine13 will become famous soon enough
Essaye de poster un petit remerciement au propriétaire Original ;)
Just don't like copy paste, in case of, just copy but don't paste !!!!!!!!!:7:
Amine13 est déconnecté   Réponse avec citation
Vieux 18/07/2010, 14h10   #3
nany
Représentant T-E
Avatar de nany
Wink
Envoyé par Amine13 Voir le message
le principale c'est le partage, d'ou sa vient ou d'ou sa provient importe peu!!!!!!!!!!!
Price & Quality
The Following User Says Thank You to nany For This Useful Post:
mb124 (22/02/2011)
Vieux 30/08/2010, 03h35   #4
mehdifree
Avatar de mehdifree
mehdifree is an unknown quantity at this point
slm stp j'ai une quistion et ce quil march avec calculteur simense EMS3132 de motor 1,4/8v
mehdifree est déconnecté   Réponse avec citation
Vieux 21/01/2012, 23h18   #5
crenshaw
Avatar de crenshaw
crenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nice
dommage que le lien Pièce jointe 2937 a ete supprimé car sa aurai pu servir
crenshaw est déconnecté   Réponse avec citation
Vieux 22/01/2012, 13h52   #6
easydiag
Avatar de easydiag
easydiag is a jewel in the rougheasydiag is a jewel in the rougheasydiag is a jewel in the rough
Envoyé par mehdifree Voir le message
POUR SIEMENS EMS3132 , la meilleur solution est de faire clear + emulateur pour avoir un immo off , si non un clear seulement pour laissez l’antidémarrage en marche.:5:
easydiag est déconnecté   Réponse avec citation
Vieux 23/01/2012, 21h57   #7
crenshaw
Avatar de crenshaw
Envoyé par nany Voir le message
- 1.6 8V with A/C
- 1.6 16V with A/C
donc sa se n est pas valable ???qui a teste cet solution avec succes ??
donc immo off plus fil line immo 58 coupé sa fai l affaire sans avoir besoin d emulateur ??
tout est flou on devrai a chaque fois donne les resultat d essai si sa fonctionne ou pas
Dernière modification par crenshaw ; 23/01/2012 à 22h03.
Vieux 23/01/2012, 22h47   #8
djemai
Avatar de djemai
djemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to beholddjemai is a splendid one to behold
Salut a tous
Cette solution ne fonctionne pas si l'ECU et en CAN
Bon courage
Aide ton frère et Allah t’aidera
djemai est déconnecté   Réponse avec citation
Vieux 18/12/2012, 14h04   #9
bej 974
Avatar de bej 974
bej 974 will become famous soon enough
salut,j ai tester sur EMS3134 CAN ça marche,bien sur avec le fichier du calculateur vierginiser
bej 974 est déconnecté   Réponse avec citation
The Following User Says Thank You to bej 974 For This Useful Post:
Vieux 11/05/2013, 15h03   #10
bouizanne
Avatar de bouizanne
bouizanne is just really nicebouizanne is just really nicebouizanne is just really nicebouizanne is just really nice
salam , oui domage que le lien soit HS ca aurait pu me servir @++
bouizanne est déconnecté   Réponse avec citation
Vieux 14/11/2015, 00h17   #11
mohcin2
Avatar de mohcin2
mohcin2 will become famous soon enough
Salut les amis c'est vraiment dommage que le lien ne marche pas quelqu'un pu le faire re Upload
mohcin2 est déconnecté   Réponse avec citation
Vieux 01/02/2016, 21h44   #12
requin51
Avatar de requin51
requin51 has a spectacular aura aboutrequin51 has a spectacular aura aboutrequin51 has a spectacular aura about
question lié a la manip: avec quel soft faire un vierge ?
J'ai un Sirius 32 (pas N) a faire sur clio 1.6 16v, Volta n'a pas fonctionné (marche bien sur 32N 2L 16v) donc que je mette un émulateur ou que j'essaye cette manip il me faut faire un vierge...
merci d'avance !
Amateur passionné, clone => FG54, Kess, Ktag, MPPS, Diagbox, CLIP, VCDS, OpCom, DS150
requin51 est déconnecté   Réponse avec citation
emulator comment il fonc digicar Immobilizer dumps/solutions 25 13/04/2011 13h40
Need Ecu Sirius EMS3132 Immo Off (not virgin) vevepatronu Immobilizer dumps/solutions 5 16/02/2010 16h26
immo off renault 1.4 16v siemens sirius 32 bencho2007 Immobilizer dumps/solutions 3 16/02/2010 07h42
renault immo emulator ricards99 Immobilizer dumps/solutions 18 13/06/2009 00h29
Fuseau horaire GMT +1. Il est actuellement 03h38.
