Vieux 25/05/2015, 13h48   #1
hamada
Avatar de hamada
Post recherche d un vierge da clio3 de 2008
BONJOUR LES AMIS je recherche un dump vierge d un calculateur direction assistee reference 8200937970 / DIAG effectué avec defaut DF002 : par avance je vous remercie
Vieux 25/05/2015, 13h55   #2
davycdz
Avatar de davycdz
davycdz has a spectacular aura aboutdavycdz has a spectacular aura aboutdavycdz has a spectacular aura about
Je t'ai envoyer n mp,test et tien moi au jus
N'OUBLIEZ PAS LE PETIT BOUTON THANKS EN BAS À DROITE
davycdz est déconnecté   Réponse avec citation
The Following User Says Thank You to davycdz For This Useful Post:
hamada (25/05/2015)
Vieux 25/05/2015, 14h00   #3
hamada
Avatar de hamada
SALUT merci de ta rapidité ce vierge provient de la meme ref?
Vieux 25/05/2015, 14h09   #4
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Bonjour hamada,
poste ton dump origine.
diagprog est déconnecté   Réponse avec citation
The Following User Says Thank You to diagprog For This Useful Post:
hamada (25/05/2015)
Vieux 25/05/2015, 14h16   #5
hamada
Avatar de hamada
bonjour diagprog je le posterai des que possible merci
The Following User Says Thank You to hamada For This Useful Post:
diagprog (25/05/2015)
Vieux 25/05/2015, 17h33   #6
davycdz
Avatar de davycdz
Par défaut 24lc16
tien l'ami,teste et tien nous au jus
pass en mp
Type de fichier : rar 24c16 vierge.rar (888 octets, 14 affichages)
The Following 2 Users Say Thank You to davycdz For This Useful Post:
hamada (25/05/2015), smoker byte (21/02/2018)
Vieux 21/02/2018, 20h48   #7
alexpert
Avatar de alexpert
alexpert will become famous soon enough
bonjour quelqu un aurait le mp car pas de reponse de davycdz et hamada
alexpert est déconnecté   Réponse avec citation
Vieux 21/02/2018, 23h10   #8
abdel93
Avatar de abdel93
Envoyé par alexpert Voir le message
slt c'est un peut normal ca date de 2015 si tu a renolink tu peut le faire directe
hamada (23/02/2018)
Vieux 23/02/2018, 01h06   #9
hamada
Avatar de hamada
Salut l ami dsl j ai plus ce dump .
Vieux 23/02/2018, 10h32   #10
jah83
Avatar de jah83
Pouvoir de réputation: 245
Non renolink permet seulement de faire un clear immo
Vieux 23/02/2018, 16h14   #11
alexpert
Avatar de alexpert
salut tous le monde quelqu un aurait ce dump pour une dae clio 3 8200937970 car la dae a déjà était reprogrammer mais pas avec le bon soft du coup j ai même pas l origine.
Vieux 26/02/2018, 02h23   #12
danyparis
Avatar de danyparis
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Des dumps il y en a pas 100
Je peux te le faire mais j'ai besoin d'un dump ori pour la base ainsi que du VIN de la voiture
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
Vieux 27/02/2018, 14h17   #13
alexpert
Avatar de alexpert
Par défaut dae clio3
j ai pas l ori mais j ai le vin si ça va
Pack de 3 dump vierge DAE (modus+clio3) diagprog Immobilizer dumps/solutions 5 07/03/2021 19h46
Dump vierge ecu delphi dcm1.2 clio3 taxi300 Immobilizer dumps/solutions 3 07/01/2018 12h57
Dump Vierge uch 95160 clio3 wish250 Immobilizer dumps/solutions 1 14/11/2014 13h01
dump vierge uch clio3 zidane autodiag Immobilizer dumps/solutions 11 02/05/2013 01h00
recherche soft dae modus clio3 SAMIR75 Renault, Dacia, Nissan 9 17/08/2012 03h30
Fuseau horaire GMT +1. Il est actuellement 04h47.
