Vieux 31/03/2015, 17h08   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut DA modus
Bonjour j ai une souci avec une da de modus j aurai besoin d un vierge ou du réparation du dump
8200 307 154--A
da modus.rar
Verdun est déconnecté   Réponse avec citation
Vieux 31/03/2015, 17h13   #2
nizar
Avatar de nizar
nizar is a splendid one to beholdnizar is a splendid one to beholdnizar is a splendid one to beholdnizar is a splendid one to beholdnizar is a splendid one to beholdnizar is a splendid one to beholdnizar is a splendid one to behold
slt, c une 24lc16?
nizar est déconnecté   Réponse avec citation
Vieux 31/03/2015, 17h18   #3
nizar
Avatar de nizar
Par défaut vierge
dae clio 3 modus testé ok.rarsi c'est le cas tien
The Following User Says Thank You to nizar For This Useful Post:
Verdun (31/03/2015)
Vieux 31/03/2015, 19h12   #4
Verdun
Avatar de Verdun
Oui 24lc16 merci je teste demain
Vieux 31/03/2015, 23h58   #5
danyparis
Avatar de danyparis
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Envoyé par Verdun Voir le message
Tiens ton dump fonctionnel a 100%
pass dans ta boite
Type de fichier : rar DAE modus VERDUN.rar (1,0 Ko, 8 affichages)
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
The Following User Says Thank You to danyparis For This Useful Post:
Verdun (01/04/2015)
Vieux 08/04/2015, 17h18   #6
mariol56
Avatar de mariol56
mariol56 has a spectacular aura aboutmariol56 has a spectacular aura aboutmariol56 has a spectacular aura about
Bonjour à tous je cherche comment on fait pour avoir le dump de la dae sur modus car ma dae ne fonctionne plus et je les changer pas une occase mais sa marche pas comment on peut la rendre vierge ?? Et avec quoi comme matos merci
Dernière modification par mariol56 ; 08/04/2015 à 18h28.
mariol56 est déconnecté   Réponse avec citation
Vieux 09/04/2015, 06h33   #7
techtronic1
Avatar de techtronic1
Bjr il te faut lire l eprom et poster ton dump
Vieux 09/04/2015, 07h11   #8
mariol56
Avatar de mariol56
ok mais avec quoi je le lit ?? merci
Vieux 09/04/2015, 07h24   #9
techtronic1
Ta un programateur d eprom
Vieux 09/04/2015, 12h26   #10
mariol56
Avatar de mariol56
non mai je peut acheter si tu me dit se qu il me faut et si tu a une photo de la puce a dessouder merci
dae modus gg64 Réparation & Programmation 4 26/03/2015 14h40
Dae modus REDZONE31 Réparation & Programmation 7 08/03/2015 08h53
Dae modus 82 00 294 978 a docteur_v6 Renault, Dacia, Nissan 0 30/12/2014 16h41
rta modus ? chatgris08 Renault, Dacia, Nissan 4 26/05/2014 15h32
Fuseau horaire GMT +1. Il est actuellement 08h33.
