Vieux 25/10/2014, 11h22   #1
utut20
Avatar de utut20
utut20 is an unknown quantity at this point
Par défaut Peugeot 307SW HDi BSM issue.
Hi all,
I have problem use Diagbox 7.06.
It show the BSI & BSM failed, car can running without problem
F000 : Fault engine wiring housing : ECU mute on the CAN
F000 : Engine fuse box not communicating on the CAN fault
ECU is SID803A
utut20
utut20 est déconnecté   Réponse avec citation
Vieux 25/10/2014, 11h58   #2
adiago
Avatar de adiago
Pouvoir de réputation: 35
Hi
F000 =default false ,no problem !
utut20 (26/10/2014)
Vieux 26/10/2014, 06h46   #3
utut20
Avatar de utut20
Envoyé par adiago Voir le message
Hi
I think I need to study hard on the user menu...
thanks
utut20
Vieux 16/11/2014, 04h19   #4
utut20
Avatar de utut20
COnfirmed the BSM issue.
I just replace the "BSM-L11-00" with "BSM-01-00"( (6500CK)
the problem fix .
utut20
Peugeot 307sw Siemens SID 803 Dishny Programmateur de composant (flasher) 21 29/06/2015 12h37
SID803 - 307SW - démarrage impossible... Jules Immobilizer dumps/solutions 10 12/05/2014 19h48
desactivé egr 307sw 1.6L 110 perpi66 PSA Group Peugeot, Citroën 0 11/04/2014 13h38
SVP Retirer FAP / DPF Peugoet HDI 307sw electro68 Chiptuning 2 08/08/2011 03h23
Another driver issue with ECM6.3 zak5665 Chiptuning 0 04/12/2009 20h38
Fuseau horaire GMT +1. Il est actuellement 14h08.
