Vieux 24/10/2014, 21h40   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Par défaut code pin bsi valeo C3
bonsoir je cherche le code pin du bsi valeo C3 eprom 24C128 et merci
Type de fichier : rar C3 eprom24C128.rar (3,6 Ko, 39 affichages)
l union fait la force
Vieux 24/10/2014, 22h15   #2
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Salut l'ami, moi je trouve le code pin X2DK ou bien KD2X.
diagprog est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to diagprog For This Useful Post:
betrescudan (24/10/2014), diagnosis29 (24/10/2014), electro_bordeaux1 (24/10/2014)
Vieux 24/10/2014, 22h21   #3
electro_bordeaux1
merci diagprog pour ta reponse si quelqu un peut me confirmer laquelle des deux
The Following 3 Users Say Thank You to electro_bordeaux1 For This Useful Post:
diagprog (24/10/2014), Nizar-maoukil (24/10/2014), teslakg (31/10/2014)
Vieux 24/10/2014, 22h28   #4
zidane autodiag
Avatar de zidane autodiag
zidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the rough
code pin : X2DK
Dtc, Egr, Dpf,Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter
Skype : soufi217
zidane autodiag est déconnecté   Réponse avec citation
The Following User Says Thank You to zidane autodiag For This Useful Post:
Vieux 24/10/2014, 22h38   #5
electro_bordeaux1
merci bien pour vos reponse je vais teste code pin : X2DK et je vous tiendrez au courant
Vieux 26/10/2014, 20h01   #6
electro_bordeaux1
bonsoir les membres j ai voulu faire aprentissage des cles j ai le message suivant echec de programation manitenant je cherche un vierge a cette bsi valeo 24C128 j ai mis fffff ds tout le contenu d eprom ça marche pas et je veux savoir quelle puce fonctionne avec cette bsi valeo est ce que PCF7936 ou autre chose? et merci beaucoup
Vieux 26/10/2014, 20h16   #7
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
oui c'une pcf 7936
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following User Says Thank You to Nizar-maoukil For This Useful Post:
electro_bordeaux1 (26/10/2014)
Vieux 26/10/2014, 20h22   #8
Nizar-maoukil
Par défaut 24c128 vergin dump
voici un dump vierge pass dans t'as boite
regards
Type de fichier : rar C3 eprom24C128 vergin dump.rar (502 octets, 6 affichages)
regards
The Following 2 Users Say Thank You to Nizar-maoukil For This Useful Post:
diagprog (26/10/2014), electro_bordeaux1 (26/10/2014)
Vieux 26/10/2014, 20h26   #9
ERIC"
Avatar de ERIC"
ERIC" is on a distinguished road
attention il me semble que lon peut apprendre une seul foi
il te faut un transpondeur neuf .
ERIC" est déconnecté   Réponse avec citation
The Following User Says Thank You to ERIC" For This Useful Post:
Vieux 26/10/2014, 20h35   #10
electro_bordeaux1
merci nizar c est le bon code je test et je te tiens au courant
The Following User Says Thank You to electro_bordeaux1 For This Useful Post:
Nizar-maoukil (26/10/2014)
Vieux 26/10/2014, 21h11   #11
Nizar-maoukil
oui c vrai mais exist des programeur qui peut vergniser quelque type de transpondeur
regrads
regards
The Following 4 Users Say Thank You to Nizar-maoukil For This Useful Post:
aurelien (26/10/2014), diagprog (26/10/2014), electro_bordeaux1 (26/10/2014), ERIC" (26/10/2014)
Vieux 26/10/2014, 21h17   #12
electro_bordeaux1
ce sont des transpondeurs OTP one time programed
Vieux 27/10/2014, 13h41   #13
electro_bordeaux1
bonjour me voila de nouveau j ai fais apprentissage cle avec le code tout se passe bien code est bien appris au diag pas de dialogue avec calculateur moteur le demareur ne se lance plus les defauts sur BSI
-signal jauge a carburant court circuit a la masse
-capteur de pression d huile moteur non caracterise
-sonde de temperature exterieure non caracterise
-absence de comunication avec calculateur control moteur
ce que je veux savoir est ce que l absence de comunication avec le calculateur control moteur peut empecher le lencement du demareur sur C3 et merci
Vieux 27/10/2014, 14h06   #14
ERIC"
Avatar de ERIC"
Envoyé par electro_bordeaux1 Voir le message
salut jai eu le cas le mois dernier sur 206 calculateur hs absence de com
et mon demareur marcher .
electro_bordeaux1 (27/10/2014)
Vieux 27/10/2014, 14h16   #15
electro_bordeaux1
si quelqu un peut me poster les pins out du calculateur valeo J34P pour voir est ce que l alimentation et les masses sont ok et merci
j attend votre aide les membres
Dernière modification par cedrsan ; 27/10/2014 à 19h46.
valeo V34.1 Firas Immobilizer dumps/solutions 3 15/10/2014 14h03
Bsi valeo Nico Electronique 7 31/07/2014 12h21
Pin code peugeot 307 BSI VALEO say882 Transponder, code pin 2 08/03/2014 00h55
bsi valeo 307 code pin ??? ajmi_gsm Transponder, code pin 8 14/11/2013 19h47
besoin confirmation code PIN BSI valeo M95128 angels59 Transponder, code pin 4 31/05/2013 10h06
Fuseau horaire GMT +1. Il est actuellement 17h29.
