Vieux 07/10/2014, 19h59   #1
lames
Avatar de lames
lames has a spectacular aura aboutlames has a spectacular aura about
Par défaut SID801 Peugeot 307
Salam à tous,
J'aimerai mettre une immo off dans un calculateur Siemens SID801 d'une 307 HDI, qui me servira comme calculateur de test.
J ai essayer avec volta mais sans succès.
ref du calculo :
Siemens SID 801 5WS40020G-T
SW9644895180
HW9641849280
merci d avance
Type de fichier : bin SID 801 ori_new.bin (256 octets, 12 affichages)
Sans la puissance la maitrise n'est rien !!
lames est déconnecté   Réponse avec citation
Vieux 07/10/2014, 20h06   #2
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Salut, si tu veux un immoff teste a 100%, je te conseille le fichier de smart057, demande lui le mot de passe en mp, tu le trouve ici:
http://www.tlemcen-electronic.com/fo...ghlight=SID801
bonne cahnce
diagprog est déconnecté   Réponse avec citation
Vieux 07/10/2014, 20h54   #3
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
Par défaut sid 801 immo off 100%
voici ton off pass dans ta boite
cldt
Type de fichier : rar sid immo off.rar (184 octets, 7 affichages)
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Nizar-maoukil For This Useful Post:
diagprog (07/10/2014), lames (07/10/2014)
Vieux 07/10/2014, 21h12   #4
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 51
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
Bonsoir voici un off teste par moi même ya quelque jours sur une berlingo HDI
fonctionnel 100%
Type de fichier : rar IMMO OFF SID 801A teste ok.bin.rar (197 octets, 180 affichages)
amrougafsa est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to amrougafsa For This Useful Post:
lames (07/10/2014), rahmani2008 (30/10/2019)
Vieux 07/10/2014, 22h27   #5
lames
Avatar de lames
Merci !
je vais tester sa demain !
Envoyé par amrougafsa Voir le message
fonctionnel 100%
le calculo est un SID801 ! le SID801a c est pareil ?
Vieux 10/10/2014, 18h47   #6
smart057
Avatar de smart057
Pouvoir de réputation: 40
Alors des nouvelles?
Vieux 11/10/2014, 10h56   #7
lames
Avatar de lames
Ben justement je viens de rentrer une 307 avec le problème de la batterie trop faible qui a virginisé le bsi !
Je vais faire une lecture de l eprom dans le calculo pour avoir le code pin .
Je metterrai le dump ici.
Vieux 11/10/2014, 12h18   #8
lames
Avatar de lames
ci joint la lecture du 93C56 en 8b et en 16b
je trouve 1VET
qui peu me confirmer ?
merci d avance
Type de fichier : rar SID 801.rar (310 octets, 17 affichages)
Vieux 11/10/2014, 12h39   #9
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Envoyé par lames Voir le message
je trouve 1VET
merci d avance
Hello,
Je trouve V1TE
a+
___________________________
www.123diagauto.com
Dernière modification par diagnosis29 ; 11/10/2014 à 12h51.
The Following 2 Users Say Thank You to diagnosis29 For This Useful Post:
diagprog (11/10/2014), Nizar-maoukil (11/10/2014)
Vieux 11/10/2014, 13h18   #10
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
salut je confirme code pin :
V1TE ou ET1V
crdl
seadoo831 est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to seadoo831 For This Useful Post:
Vieux 11/10/2014, 13h55   #11
diagprog
Avatar de diagprog
salut je confirme que le code pin correct est : ET1V
The Following 2 Users Say Thank You to diagprog For This Useful Post:
diagnosis29 (11/10/2014), Nizar-maoukil (11/10/2014)
Vieux 11/10/2014, 14h15   #12
CSYSTEME
Avatar de CSYSTEME
CSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant future
le bon code pin est 1VET ,a la lecture du dump ET1V
il faut juste inverser pour avoir le bon pin.
j'ais fait la manip hier sur une 307 avec sid 801 avec comme code lu JCQT , le bon code qui a fonctionner est le QTJC .
le sid 801 se fait tres bien en off
Cordialement
The Following User Says Thank You to CSYSTEME For This Useful Post:
lames (11/10/2014)
Vieux 11/10/2014, 17h15   #13
lames
Avatar de lames
Le code pin est bien 1VET !
Merci a Csysteme ;)
J'ai réussi a config la bsi et la clé. Car quand je coupe le contact j'ai bien le bip bip qui me dis que la clé est resté dans le neman.
Par contre les off ne marche pas !
Et surtout que la voiture est passé en mode économique.
Vieux 11/10/2014, 19h58   #14
lames
Avatar de lames
Bon ben voilà tout est ok !
La voiture démarre sans immo off.
J'ai mis des FF partout sur les 2 première ligne et reconfigurer le calculateur moteur avec le pp2000 puis la bsi et activer les options.
J'ai fais la même manip sur l Ecu de test que je voulais mettre en off !qui non pas marché .
Mais codé tout est ok .
The Following User Says Thank You to lames For This Useful Post:
Immo off Peugeot 307 SID801 matt1781 Immobilizer dumps/solutions 1 01/07/2014 01h56
Immo off Siemens SID801 Peugeot 307 jarod Immobilizer dumps/solutions 5 13/04/2014 18h00
Dump vierge Sid801 peugeot partner Ben29200 Immobilizer dumps/solutions 3 13/04/2014 17h35
Immo off peugeot sid801 slv Immobilizer dumps/solutions 10 13/05/2013 16h44
Fuseau horaire GMT +1. Il est actuellement 18h25.
