Discussion fermée
Vieux 06/10/2014, 19h13   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut fvdi renault
Bonjour a tous j au u un petit pour rerog d une carte sur laguna 2 ph2 je l ai fait avec le fdvi renault et j ai ce msg d erreur qui apparait
quelqu un a deja eu ce msg
Verdun est déconnecté
The Following User Says Thank You to Verdun For This Useful Post:
COTECH00 (19/10/2014)
Vieux 06/10/2014, 19h52   #2
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Salut verdun, je n'ai acune experience avec fvdi, mais d'aprés la photo je vois que la case pin code est vide, alors est ce que t'as essayer de lire le pin code avec le bouton read pin code?
diagprog est déconnecté
The Following User Says Thank You to diagprog For This Useful Post:
Vieux 06/10/2014, 19h55   #3
yvespapou
Avatar de yvespapou
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
salut ta carte est pas d' occasion ?
elle est neuve ?
en principe ce message sort quand la carte a été déjà programmé sur un autre vehicule
ou alors elle est défectueuse
yvespapou est déconnecté
Vieux 06/10/2014, 20h34   #4
Verdun
Avatar de Verdun
Envoyé par diagprog Voir le message
en fait sur tout ce qui est a carte le fvdi ne fait pas de lecture de code on doit cliquer directement sur learm pour les programmer
The Following 3 Users Say Thank You to Verdun For This Useful Post:
COTECH00 (19/10/2014), diagprog (06/10/2014), magic abdou (19/04/2018)
Vieux 06/10/2014, 20h38   #5
Verdun
Avatar de Verdun
Envoyé par yvespapou Voir le message
elle est neuve ?
la carte est neuve et quand on utilise une clés même d occasion on arrive au msg ou le fvdi nous demande d insérer la première clés hors j arrive même pas a ce msg
Vieux 06/10/2014, 20h39   #6
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
yvespapou t as demander si ta carte été d occasion ou neuve car si occasion tu ne pourras jamais le recoder sur une autre voiture crdl
seadoo831 est déconnecté
Vieux 06/10/2014, 20h43   #7
Verdun
Avatar de Verdun
re lit bien mais msg j ai déjà préciser la carte est neuve
COTECH00 (19/10/2014), samb4064 (06/10/2014), seadoo831 (06/10/2014)
Vieux 06/10/2014, 20h44   #8
seadoo831
Avatar de seadoo831
desoler mais j avais pas ton message afficher quand j ai poster les deux se sont croiser crdl
Vieux 06/10/2014, 20h54   #9
Verdun
Avatar de Verdun
pas de souci je pense que sa viens de la voiture pas la voiture a jamais eu de souci
Vieux 08/10/2014, 21h21   #10
moradweb
Avatar de moradweb
moradweb is an unknown quantity at this point
Par défaut pin code not accepted make sur ignition is off
bonsoir,
j'ai trouvé un petit tuto ou ton erreur est mentionnée.
regarde tes MP
cdt
moradweb est déconnecté
The Following User Says Thank You to moradweb For This Useful Post:
Verdun (08/10/2014)
Vieux 08/10/2014, 22h19   #11
Verdun
Avatar de Verdun
Merci j ai comprit une vrai galère quoi je vais test on Vera ce sa donne .
Vieux 24/03/2018, 20h37   #12
raimongil
Avatar de raimongil
raimongil is an unknown quantity at this point
Envoyé par moradweb Voir le message
bonsoir,
regarde tes MP
cdt
Bonjour, je passe par le tutoriel d'erreur pour lire un laguna 2 phase 2.
Salutations et merci beaucoup.
raimongil est déconnecté
The Following User Says Thank You to raimongil For This Useful Post:
ggvaniou (25/03/2018)
Vieux 24/03/2018, 21h12   #13
chaoui05
Avatar de chaoui05
Pouvoir de réputation: 80
Envoyé par raimongil Voir le message
Salut, sacré déterrage,près de 4ans tout de même!!
Pas de "Thanks" plus d'aide!
chaoui05 est déconnecté
The Following 2 Users Say Thank You to chaoui05 For This Useful Post:
ggvaniou (25/03/2018), seadoo831 (24/03/2018)
Vieux 25/03/2018, 07h45   #14
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 88
Slt
Faut juste avoir le conctact couper ,tu clique sur learn et validé et tu met le contact...
ggvaniou est déconnecté
Vieux 25/03/2018, 12h56   #15
raimongil
Avatar de raimongil
Merci d'avoir répondu, salutations.
Discussion fermée
avdi /fvdi / orv maitre_flav Autres 18 01/04/2015 17h07
vends FVDI PSA 6.3 jr59 Vente, Achat, Echange 4 30/08/2014 16h19
info FVDI PSA jr59 Vente, Achat, Echange 4 25/07/2014 18h31
Recherche interface fvdi occasion Renault psa toby Vente, Achat, Echange 1 17/07/2014 03h26
FVDI Renault micka84 Vente, Achat, Echange 0 19/05/2014 14h53
Fuseau horaire GMT +1. Il est actuellement 09h30.
