Vieux 15/09/2014, 13h25   #1
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 51
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
Par défaut confirmation pin code
Bonjour qui peut me confirmer ce pin code d'une 406 2001
93c66 je viens de trouver
F7DE et J326
amrougafsa est déconnecté   Réponse avec citation
Vieux 15/09/2014, 13h51   #2
foulques
Avatar de foulques
foulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud of
salut il manque le dump
foulques est déconnecté   Réponse avec citation
Vieux 15/09/2014, 13h53   #3
electro_bordeaux1
Avatar de electro_bordeaux1
le contenu du 93C66 .?
l union fait la force
Vieux 15/09/2014, 14h26   #4
amrougafsa
ooops voici voici le dump pardon
Type de fichier : bin bsi 406 93c66.bin (512 octets, 19 affichages)
Vieux 15/09/2014, 14h28   #5
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
moi je trouve le code pin= J326
diagprog est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to diagprog For This Useful Post:
amrougafsa (15/09/2014), electro_bordeaux1 (15/09/2014)
Vieux 15/09/2014, 14h39   #6
diagprog
Avatar de diagprog
Désolé le Code pin 3J62 ou bien J326
amrougafsa (15/09/2014), volavka (15/09/2014)
Vieux 15/09/2014, 14h41   #7
electro_bordeaux1
Pin Code - 3J62 c est le bon code
The Following User Says Thank You to electro_bordeaux1 For This Useful Post:
diagprog (15/09/2014)
Vieux 15/09/2014, 15h18   #8
amrougafsa
salut oui 3J62 c est le bon code mais le calculateur moteur et toujours verrouiller
Vieux 15/09/2014, 16h10   #9
diagprog
Avatar de diagprog
et dans la mémoire des défauts bsi et calculateur moteur qu'il sont les défaut enregistrée?
The Following User Says Thank You to diagprog For This Useful Post:
Vieux 15/09/2014, 17h04   #10
amrougafsa
Envoyé par diagprog Voir le message
calculateur moteur ne repont pas et sur mesure parametre standar bsi immo parfois calculateur devrouiller parfois verouiller
cette bête ma fait mal a la tette
Vieux 15/09/2014, 17h07   #11
amrougafsa
malgré que quand je mis le contact la pompe essence et le moteur pas a pas fonctionne mais au demarrage ya rien de tous
Vieux 15/09/2014, 17h32   #12
diagprog
Avatar de diagprog
si le calculateur moteur ne répond pas alors t'as surement un problème dans le calculateur moteur, soit il n'est pas bien alimente, soit le calculateur est hors service.
vérifier les alimentation du calculateur.
Vieux 15/09/2014, 18h21   #13
amrougafsa
j'ai bien chercher je crois que c'est la liaison entre bsi et calculo car si je mis le contacte la pompe et le moteur pas a pas fonctionne alors le calculo n'est pas HS je ne sais pas peut être je mis le calculo en immo off
The Following User Says Thank You to amrougafsa For This Useful Post:
Vieux 15/09/2014, 18h28   #14
diagprog
Avatar de diagprog
alors avant de faire un immo off, vérifier le calculo a l’intérieur peut être il a pris de l'eau..en sais jamais et essayer de le nettoyer..
Vieux 15/09/2014, 19h09   #15
amrougafsa
voila l'histoire frère suit a un lavage le bsi a tomber HS ya plus d'affichage sur le dash ni essuie glace ni feux mais la voiture démarre et le calculo moteur repond sur pp2000 bon j'ai essayer avec un testeur de 12 v sur le bsi ya pas de réponse du bsi bon apres j'ai changer le BSI mais pas de même référence la voiture ne veut pas demarrer et sur pp2000 ya pas de reponse biensur j'ai injecter un vierge dans le bsi .
alors je réussi a réparer l’ancien bsi j'ai télécoder et tous va bien ya plus de default sur bsi afficheur et dash tous fonctionne impeccable mais toujours pas de réponse de calculo la voiture ne démarre plus .
peut Etre c'est a cause de testeur le calculateur moteur a u un problème
Confirmation pin 307 prodlt Transponder, code pin 2 28/08/2014 17h59
confirmation de code pin xsara shasse Transponder, code pin 1 17/02/2014 17h02
confirmation code pin filou2411 Transponder, code pin 6 04/01/2014 21h23
besoin confirmation code PIN BSI valeo M95128 angels59 Transponder, code pin 4 31/05/2013 10h06
Confirmation de code pin sosauto Transponder, code pin 4 15/05/2012 12h36
Fuseau horaire GMT +1. Il est actuellement 08h20.
