Vieux 13/09/2014, 21h34   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Par défaut code vw navigation system
bonsoir si c est possible code vw navigation system
VWZ1Z7B65663843
3B0 035 191D
et merci beaucoup
l union fait la force
Vieux 13/09/2014, 22h39   #2
volavka
Avatar de volavka
Pouvoir de réputation: 23
volavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to beholdvolavka is a splendid one to behold
Envoyé par electro_bordeaux1 Voir le message
VWZ1Z7B65663843
3B0 035 191D
et merci beaucoup
Code inside FIS Module , read and post ur dump
bon chance
Br. Mouad Amenchar
volavka est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to volavka For This Useful Post:
cedrsan (13/09/2014), diagprog (13/09/2014), electro_bordeaux1 (13/09/2014), Nizar-maoukil (13/09/2014)
Vieux 13/09/2014, 22h45   #3
electro_bordeaux1
quelle dump qu il faut lire ,?
Vieux 13/09/2014, 23h11   #4
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Salut l'ami,
Je pense que volavka parle de leep 24C32...
peut etre ca va vous aider ce shema, lisez l'eeprom avec 24c32
Type de fichier : jpg 4950092800_1360574690.jpg (103,3 Ko, 49 affichages)
Dernière modification par cedrsan ; 14/09/2014 à 13h03.
diagprog est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to diagprog For This Useful Post:
cedrsan (14/09/2014), electro_bordeaux1 (14/09/2014), Nizar-maoukil (28/11/2014), volavka (13/09/2014)
Vieux 13/09/2014, 23h34   #5
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
salut diag
le pinout que t'as poster et pour upa usb
cldt
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to Nizar-maoukil For This Useful Post:
cedrsan (14/09/2014), diagprog (14/09/2014), electro_bordeaux1 (14/09/2014), volavka (13/09/2014)
Vieux 13/09/2014, 23h38   #6
volavka
Avatar de volavka
Envoyé par diagprog Voir le message
Salut l'ami,
Good Job Friend @diagprog , also can be read by c16 & c64
the important is 8 bytes where Code Stored
cheers
Br. Mouad Amenchar
cedrsan (14/09/2014), diagprog (13/09/2014), electro_bordeaux1 (14/09/2014), Nizar-maoukil (13/09/2014)
Vieux 14/09/2014, 02h39   #7
electro_bordeaux1
merci a tous les particippants a mon sujet demain je vais voir est ce qu il y a un eprom dedans
The Following 2 Users Say Thank You to electro_bordeaux1 For This Useful Post:
diagprog (14/09/2014), Nizar-maoukil (14/09/2014)
Vieux 14/09/2014, 13h02   #8
Joladouil
Avatar de Joladouil
Joladouil is on a distinguished road
Il y a pas d'eeprom dedans mais un module FIS que tu peux lire en tant que 24C32 en soudant les 4 fils sur la platine selon schéma de diagprog
Pour y accéder suffit de retourner le MFD et retirer le capot du bas, pas besoin de démontage
Envoyé de mon iPhone à l'aide de Tapatalk
Joladouil est déconnecté   Réponse avec citation
The Following User Says Thank You to Joladouil For This Useful Post:
electro_bordeaux1 (15/09/2014)
Vieux 15/09/2014, 13h18   #9
electro_bordeaux1
est ce que le x-prog peut faire cette lecture?
Vieux 15/09/2014, 13h58   #10
Joladouil
Avatar de Joladouil
Si le xprog peut lire une 24C32 ça passe sans soucis.
Moi j'ai un vieux lecteur see it tout basique avec ponyprog et ça fonctionne impeccable sur les MFD
Vw radio navigation system shasse Autoradio et Navigateur GPS 18 19/06/2013 13h29
code PLZ vw radio navigation system MFD bencho2007 Autoradio et Navigateur GPS 1 13/03/2013 17h08
true code programin system 2.3.1 radialva Vente, Achat, Echange 0 06/12/2012 22h42
code autoradio navigation system electro_bordeaux1 Autoradio et Navigateur GPS 8 05/09/2012 21h17
code radio navigation system diagauto Autoradio et Navigateur GPS 3 05/03/2011 17h26
Fuseau horaire GMT +1. Il est actuellement 18h36.
