Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 12/09/2014, 00h11   #1
sauzee1
Avatar de sauzee1
sauzee1 is an unknown quantity at this point
Par défaut Peugeot 206 immo
Hi i have a peugeot 206 1.4 51plate came in with non starting due to ecu failure
i changed the ecu,bsi and decoder ring but i didn't have the pod for the key.
Originally the fuel pump wouldn't operate as the ecu was not working the parts were from a donor car but the keys were away pump operates fine now but must be immobilized as pod wont match
My question is can i bypass immo to check it will run or do i need to have it reprogrammed or which diagnostic machine can i use to get it running
Thanks for any help
sauzee1 est déconnecté   Réponse avec citation
The Following User Says Thank You to sauzee1 For This Useful Post:
Vieux 12/09/2014, 19h31   #2
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1335
hi,
first you need to give us a diag report,
then after it will be easy to find the solution, give me the ref for ecu to tell you if possible to bypass immo or not !
🚀 MOD-FILES.COM
Vieux 12/09/2014, 21h17   #3
sauzee1
Avatar de sauzee1
Thanks for your reply i will look at the motor on Monday i have a Autocom i will try and read the codes with that i also have a Lexia 3 but have never managed to get it to connect to a car since i bought it
I installed all the software (Diagbox 5.29) as i was told i cant use any higher software every time i used it said it there was no communication It all lights up correctly so i dont know whats wrong with it
Thanks
Vieux 15/09/2014, 21h19   #4
sauzee1
Avatar de sauzee1
Envoyé par Ecuserver.net Voir le message
hi,
Hi i forgot to lift the paper with the ECU number on it but i tried to read the codes with my autocom it would not recognise the Ecu but i got it to work on the Multifunction tab where it said
- Key programming not done
- Present
- - Key programming not done
- Intermittent
- - Communication, engine management unit
- Present
- Intermittent
- - Remote control programming not done
- Intermittent
- - Battery in remote controller exhausted
- Intermittent
I then put in the old Ecu,Bsi and ring decoder read the codes again still no communication apart for Multifunction where i cleared the codes but no sound from the fuel pump and wouldn't start
Thanks for any help
Vieux 13/10/2014, 23h45   #5
CbRnT
Avatar de CbRnT
CbRnT is an unknown quantity at this point
What year of car it is? With Com2000?
CbRnT est déconnecté   Réponse avec citation
Vieux 16/10/2014, 00h16   #6
sauzee1
Avatar de sauzee1
Envoyé par CbRnT Voir le message
As said in post it is a 51 plate (2001) i have a new donor car that i will try a complete swap on bsi,ecu ring decoder and key i will keep you posted
Thanks
Vieux 22/10/2014, 14h42   #7
teuton
Avatar de teuton
teuton is an unknown quantity at this point
Check com lines from/to ecu. Without com it just can't start.
teuton est déconnecté   Réponse avec citation
Vieux 24/10/2014, 23h51   #8
sauzee1
Avatar de sauzee1
Envoyé par teuton Voir le message
Hi thanks for your reply the donor car was no use i have ordered a new Lexia 3 with a C revision so hopefully i will be able to reprogramme a new key with the Bsi unit i have but i don't have the chip for the key
Vieux 25/10/2014, 23h35   #9
sauzee1
Avatar de sauzee1
Hi sorry to keep repeating Lexia 3 (revision c) arrived today plugged it into Peugeot 206 no communication with ECU tried Citroen Xsara Picasso same result green light flashes 4 times then solid if i unplug it then connect again it will see the ECU for about 10 seconds then no communication again.This is the second VCI i have bought with the same results.The latest one is supposed to have full chip and original octocuplers
Can it be a software issue or is it another defective unit
Thanks for any pointers
Vieux 01/11/2014, 19h27   #10
kele
Avatar de kele
kele is an unknown quantity at this point
Some psa cars when ecu is locked you can not diagnose that module.First you must make keys or match to bsi,then check can-van lines from bsi to ecu and power supply from bsm module to ecu.
kele est déconnecté   Réponse avec citation
Vieux 02/11/2014, 18h51   #11
betrescudan
Avatar de betrescudan
betrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to behold
you must to know the pin code from ECU...then virginize BSI (ALL eeprom must to be FFFFFFF)...then recodem bsi with VIN and pincod finded on ecu,recode keys,and voila
betrescudan est déconnecté   Réponse avec citation
The Following User Says Thank You to betrescudan For This Useful Post:
sauzee1 (03/11/2014)
Vieux 03/11/2014, 00h58   #12
sauzee1
Avatar de sauzee1
Envoyé par betrescudan Voir le message
Hi thanks for the reply when you say ecu pin code is that the 4 digit security code. I don't have the security code and as i said the second Lexia (clone) that i bought wont connect to the ECU i have tried it on a 2001 307,2002 xsara picasso and a 2001 206 none of them have any dialogue with the car i did manage to get a 2004 xsara picasso see the BSI but that was all
I sent traces of the connections to the seller who said their technician would look at them
so i will have to wait till then
Thanks
Vieux 07/11/2014, 18h28   #13
vanya86
Avatar de vanya86
vanya86 is on a distinguished road
Envoyé par sauzee1 Voir le message
Thanks
I had simillar problem,
Those cars have NEC BSI , and usualy water get inside and damage data in nec or HW.
reset new BSI and adapt keys.
vanya86 est déconnecté   Réponse avec citation
The Following User Says Thank You to vanya86 For This Useful Post:
sauzee1 (09/11/2014)
Vieux 10/11/2014, 00h02   #14
sauzee1
Avatar de sauzee1
The problem i have is that i still can't get any dialogue with any ECU i am sick of the seller telling me to try older software or other ways but still no connection i have asked the seller for a replacement board for the VCI but still waiting on a reply
If i unplug it i get it to work for about 10 seconds (relays click) then for it to read anything else i have to unplug then in at the usb then it stops again
I have even installed Lexia 3-45 and PP2000 in another laptop with a fresh install of XP
Thanks for any help
Vieux 10/11/2014, 09h50   #15
bangbong
Avatar de bangbong
bangbong is an unknown quantity at this point
Thanks for any help
It seems that PP2000 and Diagbox software can not be installed in the same PC, you did that? install them in different computer please, if your lexia-3 can not work,you can have a look at SVDI PSA
bangbong est déconnecté   Réponse avec citation
Immo off peugeot 406 hassini Immobilizer dumps/solutions 3 28/05/2014 21h19
peugeot 106 MA3.1 immo moky Immobilizer dumps/solutions 17 10/04/2014 16h22
peugeot 206 1.9 D immo off dybou Immobilizer dumps/solutions 1 07/04/2011 23h22
Immo off peugeot 206 serge Immobilizer dumps/solutions 6 20/10/2010 23h16
Peugeot 307 immo off bluedid Immobilizer dumps/solutions 4 16/08/2009 22h37
Fuseau horaire GMT +1. Il est actuellement 04h33.
