Vieux 24/06/2014, 15h11   #1
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Talking PSA pin calculator
qui aurait un lien valide pour ce logiciel ?
il y en a bien sur le forum mais tous HS
Merci d'avance
salutations
___________________________
www.123diagauto.com
The Following 2 Users Say Thank You to diagnosis29 For This Useful Post:
autodiagauto (15/11/2017), hexwoodstock (08/11/2014)
Vieux 24/06/2014, 16h15   #2
electro_bordeaux1
Avatar de electro_bordeaux1
voila ce que tu cherche mp ds ta boite
Type de fichier : rar PSA_Cracked.rar (419,8 Ko, 278 affichages)
l union fait la force
The Following 21 Users Say Thank You to electro_bordeaux1 For This Useful Post:
autodiagauto (15/11/2017), ben6901 (27/05/2019), bouche79 (29/07/2014), DIAGAUTO33 (10/07/2014), diagnosis29 (24/06/2014), djrusskof (25/06/2014), drissdiag (17/07/2014), eric35430 (11/06/2019), juju94 (26/11/2014), layerdiv (13/07/2014), nasisamy (27/10/2014), prinzo57 (10/07/2014), ricou 81 (27/06/2014), sametelec2003 (22/01/2019), sandy976 (13/07/2014), sossa (16/07/2014), The noob (11/05/2026), thiam58 (04/08/2014), Truc (25/05/2019), TYTY 974 (23/07/2014), vortex (24/06/2014)
Vieux 26/06/2014, 23h58   #3
jojo01170
Avatar de jojo01170
jojo01170 is an unknown quantity at this point
est ce que cela fonctionne
car le PIN commander chez Peugeot ne correspond pas a mon bsi
jojo01170 est déconnecté   Réponse avec citation
Vieux 27/06/2014, 00h04   #4
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Envoyé par jojo01170 Voir le message
Salut jojo01170,
Tu peux poster le dump du bsi et quelqu'un va te donne le pin exact.
A++
diagprog est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to diagprog For This Useful Post:
jojo01170 (27/06/2014), smarelo (27/01/2015)
Vieux 27/06/2014, 00h31   #5
jojo01170
Avatar de jojo01170
merci diagprog
ou trouver le numero du dump de la bsi
est il inscrit sur l etiquette de la bsi
Vieux 27/06/2014, 00h37   #6
diagprog
Avatar de diagprog
merci diagprog
Donne plus d'info sur ton BSI, marque+modele..de la voiture..
Vieux 27/06/2014, 00h40   #7
jojo01170
Avatar de jojo01170
alors le bsi était sur une 307
le numero de serie je te l envoi par mp
Vieux 27/06/2014, 01h13   #8
diagprog
Avatar de diagprog
Tu dois savoir le nom du bsi si:
bsi JhonsonControl eeprom=95128
BSI VALEO eeprom 95160 ou bien PROCESSEUR MC68HC912
Vieux 27/06/2014, 01h35   #9
diagprog
Avatar de diagprog
Par défaut Bsi 307
Voici les photos.
Type de fichier : jpg Valeo 95160.jpg (22,4 Ko, 82 affichages)
Type de fichier : jpg Valeo hc912.jpg (18,7 Ko, 76 affichages)
Type de fichier : jpg bsi jc 95128.jpg (21,6 Ko, 74 affichages)
jojo01170 (27/06/2014), mecanodiag93 (08/05/2015)
Vieux 27/06/2014, 01h46   #10
jojo01170
Avatar de jojo01170
voici l interieur de mon bsi
si tu pouvais me dire laquel est ce
Type de fichier : jpg P1010053.jpg (97,1 Ko, 69 affichages)
Vieux 27/06/2014, 01h57   #11
diagprog
Avatar de diagprog
Je pense que c'est un bsi valeo avec mcu MC68HC912,
Alors tu peux pas swaper.
Tu dois récupérer les donnes avec un programmeur et tu les réinjecte dans le nouveau bsi.
Vieux 27/06/2014, 11h43   #12
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 51
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
merci diagprog
Bonjour frère le dump c'est un fichier injecter dans une petite pièce Electronique s'appel eeprom
tu dois être équipe d'un programmeur d'eeprom pour lire et Ecrire sur ce dump
amrougafsa est déconnecté   Réponse avec citation
The Following User Says Thank You to amrougafsa For This Useful Post:
Vieux 27/06/2014, 13h11   #13
Meziane93
Avatar de Meziane93
pas sur ce type de bsi c un processeur
The Following User Says Thank You to Meziane93 For This Useful Post:
fifi59530 (24/05/2019)
psa calculator nacerweb Transponder, code pin 0 18/01/2013 22h34
Audi calculator 2 alfaris_8877 Autoradio et Navigateur GPS 0 18/12/2012 15h40
Audi calculator 1 alfaris_8877 Autoradio et Navigateur GPS 0 18/12/2012 15h38
railpressure calculator oussasa Logiciel & autres documentations général 0 15/02/2012 11h10
Fuseau horaire GMT +1. Il est actuellement 07h21.
