| Section for english users English talking about cars, problems and solutions ... |
Hi !
I hope someone can answer me at these question: Question : Is it possible to remove the EEPROM 95160 from at partly damaged BSI and solder/mount it in a new(used) BSI and resolve the immobilizer problem. (After browsing the web I understands that all the immobilizer data are saved in the EEPROM 95160, - but maybe are the immobilizer data stored in several places in the BSI unit, I haven't found a proper solution) ? Thanks for your interest ! ![]() Reg. Rune S. - Norway |
Fondateur
![]() Date d'inscription: novembre 2008
Pouvoir de réputation: 1335 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
On most of bsi it's possible, exept that one in 99% of case when you desolder the eprom ic it will be blank, need to recode with diag tool !
I got this many times. Please don't forget to read rules and put an avatar and full location.
🚀 MOD-FILES.COM Service de fichiers Chiptuning Haute Performance Stage 1, 2, 3 | FlexFuel - DPF - EGR - AdBlue - Pop&Bang CLIQUEZ ICI POUR ACCÉDER AU SERVICE 24/7 |
Thanks Fondateur, may I should give it a try ?
Anything I can do to avoid erasing the eeprom, maybe proper wire to earth ? Reg. Rune S. - Norway |
Fondateur
You have to try, no warantee anyway.
Hi !
Of note: I have changed eeprom95160 from a BSI(1) to another BSI(2) with the result that eeprom95160 data was deleted. This work is NOT recommended....... :twisted: re. Rune S. - Norway |
need an access code for immobilization and any device that can register keys. Code can be obtained from the engine or vin. BSI in the dump all in FF and encoding device, old keys are stored
Hi Runsun, the only way to get it back up and running now it to flash a 'virgin' BSI file to the 95160 EEPROM the re-configure with PP2000 or Lexia.
You will need the security code tho, you can get that from the ECU, which is stored on a small EEPROM in there. You'll need to read it and pop the file into ImmoTool or similar program and get the code from that. |
some cars run and some not, delete eeprom, really not a good way
| cherche PINOUT BSI 206 eeprom 95160 | beka1975 | Programmateur de composant (flasher) | 1 | 06/12/2013 19h20 |
| delphi eeprom 95160 | autodiagnos kamal | Immobilizer dumps/solutions | 5 | 14/01/2013 10h56 |
| clio 3 rs Eeprom 95160 S3000 | powermap | Immobilizer dumps/solutions | 7 | 19/12/2012 00h50 |
| Seeprog et eeprom 95160 | benaknoun | Programmateur de composant (flasher) | 3 | 09/06/2010 14h05 |
