Vieux 01/12/2009, 14h36   #1
hugopinho
Avatar de hugopinho
hugopinho is on a distinguished road
Par défaut airbag clear - Peugeot 206
Hi,
I've got a problem to clean this module, I've tried to used mine clean dumps, but the light stills on and it doesn't appears no error in the diagnostic.
Can anyone send me a dump for this crash:
AUTOLIV
602327300
9652275980
2004 (year)
eep 95080
thanks
Hugo Pinho
Type de fichier : rar 602327300.rar (271 octets, 18 affichages)
hugopinho est déconnecté   Réponse avec citation
The Following User Says Thank You to hugopinho For This Useful Post:
Fouadtl (11/06/2023)
Vieux 01/12/2009, 15h25   #2
Mrpromega
Avatar de Mrpromega
Mrpromega is a jewel in the roughMrpromega is a jewel in the roughMrpromega is a jewel in the roughMrpromega is a jewel in the rough
try this !
Type de fichier : rar Airbag.rar (622 octets, 23 affichages)
Mrpromega est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Mrpromega For This Useful Post:
Fouadtl (11/06/2023), hugopinho (01/12/2009)
Vieux 01/12/2009, 16h13   #3
hugopinho
Avatar de hugopinho
thanks!
I will test it and then I report.
hugopinho
Vieux 01/12/2009, 17h23   #4
hugopinho
Avatar de hugopinho
friend,
I've verify both, and they are equal to mines. It does't appears any error in diagnose, but the light doesn't turn off.
thanks again
Vieux 01/12/2009, 18h47   #5
Amine13
Avatar de Amine13
Amine13 will become famous soon enough
Try to have look at parameters, and check whether resistances are good or high.
Amine13 est déconnecté   Réponse avec citation
The Following User Says Thank You to Amine13 For This Useful Post:
Vieux 01/12/2009, 19h51   #6
hugopinho
Avatar de hugopinho
hi,
At parameters it appears absence of switch on/off and belt pretensor
Vieux 01/12/2009, 20h17   #7
Amine13
Avatar de Amine13
so, in this case, it may be a configuration problem, so go to configuration, and check whether all components are PRESENT, at least those present in the car...
The Following 2 Users Say Thank You to Amine13 For This Useful Post:
Fouadtl (11/06/2023), hugopinho (02/12/2009)
Vieux 02/12/2009, 12h30   #8
hugopinho
Avatar de hugopinho
Hi
I've tryed both dumps from the tachsoft 6.4 and the airbag light is always on. It doesn't have any fault code. The Unit is not blocked with diag, but in The configuration it apears the following:
conductor airbag - present
passenger airbag - present
Pretensers - absent
switch on/off for the passenger - absent.
And it doesn't let me configurate it.
Does anyone had a problem like this?
Thank you all
Vieux 02/12/2009, 14h34   #9
Amine13
Avatar de Amine13
try to paste th ORIGINAL airbag dump and get into configuration, using a clip renault will be better....
Vieux 03/01/2012, 20h08   #10
mounirflash
Banned
Avatar de mounirflash
mounirflash is on a distinguished road
salut j'ai le meme probleme sur ma voiture 206 car j'ai perdus ds trasse sur ma carte autoliv apres une penetration d'eau dans la boite apres j'ais constaté que les 2 voiyant airbag reste alumer mais j'ai recuperer une autre boite autolive a 4 voix j'ai enlever le flash et l'eeprom 95080 de ma boite d'origine et je les souder sur l'autre boite recuperer j'ais ramener ma voiture chezun electricien qui possede pps je l'ais programmer le deuziemme voiyant c'est eitin le'autre reste alumer quoi faire merci
mounirflash est déconnecté   Réponse avec citation
The Following User Says Thank You to mounirflash For This Useful Post:
Vieux 03/01/2012, 22h11   #11
ptitom33
Avatar de ptitom33
ptitom33 is on a distinguished road
salut, envoi ton dump.
ptitom33 est déconnecté   Réponse avec citation
The Following User Says Thank You to ptitom33 For This Useful Post:
Vieux 04/01/2012, 19h21   #12
mounirflash
Banned
Par défaut dump
voila le fichier dump je l'avais lis avec topmax
Type de fichier : bin st95080airbag206.bin (1,0 Ko, 8 affichages)
Vieux 04/01/2012, 20h47   #13
ptitom33
Avatar de ptitom33
donne moi les ref de ton boitier.
The Following 2 Users Say Thank You to ptitom33 For This Useful Post:
Fouadtl (11/06/2023), mounirflash (19/01/2012)
Vieux 04/01/2012, 22h18   #14
crenshaw
Avatar de crenshaw
crenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nice
voici pour toi
Type de fichier : rar st95080airbag206.rar (684 octets, 14 affichages)
crenshaw est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to crenshaw For This Useful Post:
Fouadtl (11/06/2023), mounirflash (05/01/2012)
Vieux 05/01/2012, 12h53   #15
mounirflash
Banned
merci crenshaw
clear airbag peugeot 207 hugopinho Airbag 4 22/11/2009 21h27
clear 207 airbag everson29 Airbag 16 04/10/2009 10h23
Peugeot expert clear dump LphantMan Airbag 1 18/08/2009 22h55
Airbag clear tigra temic tuareg Airbag 1 17/07/2009 20h03
Nissan Sentra 2006 Clear Airbag ECU SSOMSergey Airbag 1 19/02/2009 22h39
Fuseau horaire GMT +1. Il est actuellement 04h09.
