Vieux 08/02/2014, 20h57   #1
rickymix
Avatar de rickymix
rickymix has a spectacular aura aboutrickymix has a spectacular aura aboutrickymix has a spectacular aura about
Par défaut Galletto 2 et 3 V53 sans dongle
Salut a tous,
voici le lien pour utiliser le galletto 2 et 3 v53 sans dongle :
https://mega.co.nz/#!AEohRagC!aCtfsQ...E1Z86d0yMxJfxU
pass en mP
enjoy !
https://www.autodiagperformance.com
rickymix est déconnecté   Réponse avec citation
The Following 17 Users Say Thank You to rickymix For This Useful Post:
BILAUTO (09/02/2014), CED300482 (20/03/2014), DIAGAUTO33 (17/02/2014), dounga (14/04/2014), easydiag (27/09/2014), enzo84 (22/03/2014), fedge (18/03/2014), Geri (09/02/2014), HURLEVENT (12/03/2014), kevin22 (07/07/2014), Nico66 (15/02/2014), nomdezeus (09/02/2014), RIMKACHIP (09/02/2014), skikdi13 (20/02/2014), sntyad (26/03/2014), solution auto (22/02/2014), willy14 (01/03/2014)
Vieux 09/02/2014, 11h57   #2
RIMKACHIP
Avatar de RIMKACHIP
RIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to all
ptit pb sur mega il bloque a 73% c normal ??
RIMKACHIP est déconnecté   Réponse avec citation
Vieux 09/02/2014, 23h25   #3
kitten13
Guest
Avatar de kitten13
Messages: n/a
rickymix peut ton mettre a jour l'interface v51 en en version 53 ?
Vieux 10/02/2014, 13h08   #4
rickymix
Avatar de rickymix
non ce n est pas normal !!
normalement oui(sous reserve)
(je decline tte responsabilité de cette operation)
Dernière modification par cedrsan ; 10/02/2014 à 17h50.
Vieux 15/02/2014, 14h09   #5
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Salut à tous et merci rickymix pour ton partage !
Quelqu'un à réussi à se servir de ce soft ?
Je compte acheter un galletto 2 clone mais j'hésite entre le v50 et v53 .
Si on peut utiliser ton v53 avec une interface v50, je suis preneur !
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 20/02/2014, 12h54   #6
DIAGAUTO33
Salut à tous !
Mise à part l'apparence de l'interface, quelqu'un peut me dire la ou les différences entre un galletto 2 V53 et un galletto 3 v53 ?
Je pense prendre un G3 v53 (merci rickymix pour ton conseil) mais si quelqu'un peut me renseigner un peu plus sur ces 2 modèles ???
Merci à tous !
Vieux 20/02/2014, 16h19   #7
Geri
Avatar de Geri
Geri has a spectacular aura aboutGeri has a spectacular aura aboutGeri has a spectacular aura about
Envoyé par DIAGAUTO33 Voir le message
Salut à tous !
Merci à tous !
J'ai le FGtech Master 3 V53. Marche impeccable sans dongle. Cherchez sur Google FGtech master 3 V53 Quality A. Quality A est un peu plus cher mais j'ai des bonnes expériences. Les clones, il faut un peu de chance.
Le DVD qui vient avec la commande est plein de malware et virus. Vous pouvez télécharger le soft depuis des forums.
Geri est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Geri For This Useful Post:
DIAGAUTO33 (20/02/2014), mecanodiag93 (07/03/2014), willy14 (18/03/2014)
Vieux 06/03/2014, 22h42   #8
DIAGAUTO33
Merci Geri pour l'info !
Comment je fais pour savoir si le soft V53 que je vais trouvé sera bon ou comme celui des chinois ?
Je me pose aussi une autre petite question : puisque le galletto à une fonction bdm , peut on lire des fichiers sur des bsi ou des calculateurs d'airbags ou autres ?
The Following User Says Thank You to DIAGAUTO33 For This Useful Post:
Geri (17/03/2014)
Vieux 12/03/2014, 06h39   #9
DIAGAUTO33
Personnes peut répondre ?
Geri (17/03/2014)
Vieux 12/03/2014, 13h10   #10
willy14
Avatar de willy14
willy14 is a splendid one to beholdwilly14 is a splendid one to beholdwilly14 is a splendid one to beholdwilly14 is a splendid one to beholdwilly14 is a splendid one to beholdwilly14 is a splendid one to beholdwilly14 is a splendid one to behold
Salut rickymix,
Malgré ma demande via mp, je n'ai pas de réponse de ta part
willy14 est déconnecté   Réponse avec citation
Vieux 12/03/2014, 15h32   #11
sofiane78
Avatar de sofiane78
sofiane78 is just really nicesofiane78 is just really nicesofiane78 is just really nicesofiane78 is just really nice
non ça ne doit pas etre faisable!....
bon courage!
sofiane78 est déconnecté   Réponse avec citation
The Following User Says Thank You to sofiane78 For This Useful Post:
DIAGAUTO33 (13/03/2014)
Vieux 12/03/2014, 17h01   #12
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 183
Envoyé par willy14 Voir le message
Salut rickymix,
Il ne s'est pas connecté depuis :
Dernière activité: 20/02/2014 02h16
Donc il n'a pas vu vos MP ;)
The Following User Says Thank You to cedrsan For This Useful Post:
willy14 (12/03/2014)
Vieux 12/03/2014, 20h58   #13
HURLEVENT
Avatar de HURLEVENT
HURLEVENT will become famous soon enough
je te remercie d avance pour ton mp je suis professeur en lycee pro en maintenance des véhicules et mes élèves souhaite egalement faire un immo off sur un véhicule qui nous a été offert mais sans clé c'est pour cela que je recherche un logiciel immo killer je te remercie pour ton aide et chapeau meme en etant prof ici j'apprends toujours plus merci a vous c'est un régale christian du hurlevent
HURLEVENT est déconnecté   Réponse avec citation
Vieux 12/03/2014, 21h14   #14
sylvain02120
Avatar de sylvain02120
Salut, c'est pour quelle voiture?
Vieux 17/03/2014, 16h29   #15
DIAGAUTO33
Quelle qu'un à testé la version de Rickymix ?
Je cherche une version sans virus mais apparemment , ça court pas les rues !
Dongle PSA dav62 Transponder, code pin 6 20/10/2023 18h48
galletto v53 dongle ou pas? sylvain02120 Programmateur de composant (flasher) 3 09/05/2013 12h55
dongle icc a vendre 1.9.7.0 Amine-TE Vente, Achat, Echange 1 22/11/2012 21h14
ICC Dongle abdel_ren Transponder, code pin 0 19/03/2012 16h55
Tester dongle tonton mel-k Tableau de bord (Dashboard) 2 22/11/2011 03h20
Fuseau horaire GMT +1. Il est actuellement 12h47.
