Vieux 05/02/2014, 07h19   #1
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 183
Arrow Toyota 4D Key Tool v1.2 (immo repair & Syncro ECU)
Toyota 2005-2010
immobilizer repair and synchronization with motor ECU utility.
VERSION 1.2
Merci à Luis Andre
How immobilizer works on Toyota 2005-2010 with Texas Crypto 4D transponder :
Immobilizer data (immo) on these cars are stored in the Transponder ID ECU, located under dashboard panel and heater - see help to find Transponder ID ECU. Immobilizer (Transponder ID ECU) receive transponder key signal from immobilizer coil and if key data is equal to car,send synchronization signal to motor ECU. If transponder key is stored in immobilizer and synchronization data IMMO-ECU is correct, engine start permanently. Motor not starting or starting for 2 sec. when immobilizer system is not ok.
How to use this program:
  • - is no car transponder key:
    remove immo (Transponder ID ECU) from car. Open it and read EEPROM. Open immo dump with "TOYOTA 4D KEY TOOL" and push "Generate keys". Now using any transponder tool (Codereader, ZedBull, RW4 or other) write transponder data to TPX3 or EH (electronic 4D emulator). This transponder will be car Master (Black) key.
  • - car not start - unknown problem:
    first make car immobilizer and motor ECU diagnostic. If Immobilizer have error code "wrong transponder" or "transponder ID is not registered" - generate new transponder from immobilizer dump. If is no fault codes in immobilizer and in motor ECU is fault code "immobilizer fault B2799" - you need synchronize immo-motor ECU.
Type de fichier : txt Toyota4DKeyTool1.2.txt (73 octets, 688 affichages)
Type de fichier : txt Password.txt (65 octets, 516 affichages)
Dernière modification par cedrsan ; 17/03/2015 à 12h34.
The Following 90 Users Say Thank You to cedrsan For This Useful Post:
abdourahman2010 (05/04/2015), AHMED@UTO (08/05/2015), amarpop (04/01/2015), amateur23 (02/03/2020), amourh59 (23/06/2014), anasco (11/08/2014), auto diag1 (30/08/2014), autodiagauto (27/06/2026), aza (10/10/2014), bej 974 (24/02/2014), cardiag16 (23/06/2014), carspeed (28/01/2015), charifcharif (22/02/2015), dancar (15/05/2019), delangue (18/01/2021), diago2001 (13/04/2026), diagprog (29/03/2014), dounga (31/12/2022), drissdiag (11/04/2014), ECU diag (12/01/2015), ecuturk (10/10/2014), electro_bordeaux1 (13/12/2014), ElTurco (25/01/2021), enzo84 (08/05/2014), Farouest (28/06/2026), fenix5 (05/04/2015), flash (29/03/2014), GUESSABOSS (01/01/2025), Honda (09/08/2020), hydrofrein (25/05/2014), izouf (10/12/2014), jah83 (11/07/2022), jardini (04/11/2014), jpay2 (05/02/2014), Jul971 (19/07/2014), juned (07/11/2023), kamel2003 (23/06/2014), kevin22 (02/04/2014), labase (05/02/2014), lake777 (31/01/2018), leraj (05/02/2014), Licokite (24/05/2014), martinracing (04/09/2014), meca (14/08/2014), mecanodiag93 (05/01/2015), miloud_slt2014 (24/06/2017), mindouza (30/06/2026), mohhizbar (24/05/2014), momo59490 (08/03/2019), morran (25/04/2015), mosnfet (26/05/2014), MOURAD SPCMAX (12/06/2014), Msila19 (20/04/2024), nabiiil (24/01/2020), nasisamy (09/02/2023), neojeorex (07/03/2015), nimbus (14/12/2014), perso69 (19/11/2014), PIC16F84 (17/09/2018), pitouille83 (06/02/2014), PRODIAG75 (09/01/2022), progdebutant (20/08/2016), psavw (08/04/2015), r1lef (03/04/2014), rapou30 (03/01/2024), rayad (13/02/2018), ricou 81 (21/05/2019), sahnoun363 (19/01/2015), Saidiag (27/11/2019), Saïdus (26/06/2026), salamat (10/10/2025), saleh (09/09/2019), sametelec2003 (24/09/2019), samsai (28/12/2021), sawadogo2 (13/12/2014), Scanworld2020 (26/01/2021), sebdetours (08/12/2014), selouan (25/04/2015), Shadab (18/09/2014), skens (28/11/2014), smt (09/02/2014), taxi300 (05/05/2015), Tidus97 (22/06/2014), vivi91r (03/04/2025), Yhoni (27/06/2026), youcef_trik (02/04/2014), yousfi (05/03/2015), zourson (23/12/2021)
Vieux 02/04/2014, 20h05   #2
kevin22
Avatar de kevin22
kevin22 is just really nicekevin22 is just really nicekevin22 is just really nicekevin22 is just really nice
bonsoir cedrsan,
pendant que j'y suis !
pourrais tu me dire quelle câble utiliser avec ce programme ? et je cherche par ailleurs le nom de l'adaptateur a utiliser avec immo universal decoder ?
kevin22 est déconnecté   Réponse avec citation
Vieux 03/04/2014, 08h42   #3
Drogo
Avatar de Drogo
Pouvoir de réputation: 90
Smile Super
Merci cedrsan pour se post je peux en avoir besoin pour ma toyota , on sait jamais.
The Following 2 Users Say Thank You to Drogo For This Useful Post:
saleh (08/05/2015), Shadab (25/04/2015)
Vieux 20/06/2014, 22h22   #4
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Envoyé par marsiksky Voir le message
А где сама программа?
Hi ,
Please respect the rules and please write in french or english
I have delate your post in russian.
Thanks
___________________________
www.123diagauto.com
Vieux 22/06/2014, 22h31   #5
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 37
Interessant! Je savais même pas que ça pouvait exister! Par contre ils en parlent très peu pour la méthode de synchro ecu-immobox, juste un schéma de ce qu'il faut faire au niveau de la prise diag. Moi ce qui m'intéresserait ce serait les bytes de synchro entre ecu/immobox! Quelqu'un saurait il de quels bytes il s'agit?
The Following User Says Thank You to Tidus97 For This Useful Post:
Vieux 11/07/2014, 12h45   #6
Licokite
Avatar de Licokite
Licokite has a spectacular aura aboutLicokite has a spectacular aura aboutLicokite has a spectacular aura about
Quel programmeur utilisez vous pour produire une clé. J'ai un ZED-Bull (clone) et je n'arrive pas à programmer de clé MASTER (4D67). Je n'arrive pas à écrire le Pg 4, après lecture, j'ai toujours 00 00 00 00 00.
Je pense acheter un ND900, est-ce quelqu'un connait ce produit ?
Licokite est déconnecté   Réponse avec citation
The Following User Says Thank You to Licokite For This Useful Post:
Vieux 29/07/2014, 06h08   #7
Licokite
Avatar de Licokite
J'ai acheté le ND900 de chez TJECU --> impeccable, programmation de nouveau transponder avec lecture du dump de l'immobox avant.
Super appareil !
Tout ça combiné aux logiciels comme Toyota4DKeyTool1.2, BENZ_Key Creator, etc. C'est un régal.
Sinon pour info, le SKP900 programme de nouveaux transpondeurs sur TOYOTA Hilux D4D sans clé MASTER. Il virginise l'immobox et enregistre la première clé insérée comme clé MASTER puis toutes les autres.
Il met "Communication Failed" mais c'est enregistré.
Testé sur 2 véhicules --> 100% OK
Dernière modification par cedrsan ; 29/07/2014 à 16h57.
The Following 2 Users Say Thank You to Licokite For This Useful Post:
diagnosis29 (28/01/2015), Shadab (25/04/2015)
Vieux 26/06/2026, 23h26   #8
Saïdus
Avatar de Saïdus
Saïdus is an unknown quantity at this point
Envoyé par cedrsan Voir le message
Toyota 2005-2010
VERSION 1.2
Pièce jointe 18522
Merci à Luis Andre
Merci beaucoup pour ce partage et à Luis Andre pour le développement de cet outil. C'est une excellente contribution pour la communauté Toyota, surtout pour la réparation de l'antidémarrage et la synchronisation IMMO/ECU.
Un grand merci pour le temps consacré à le mettre à disposition de tous.
Saïdus est déconnecté   Réponse avec citation
Vieux 27/06/2026, 23h42   #9
Yhoni
Avatar de Yhoni
Yhoni is on a distinguished road
Toyota 2005-2010
VERSION 1.2
Pièce jointe 18522
Merci à Luis Andre
Thanks for sharing it.
Kr,
Yhoni est déconnecté   Réponse avec citation
TOYOTA-COROLLA Repair Manual 2010-11 TAGRART Logiciel & autres documentations général 0 19/06/2013 23h33
procedure de syncro telecomande c3 zbilou60 PSA Group Peugeot, Citroën 2 17/06/2012 19h49
syncro plip modus doudou241 Renault, Dacia, Nissan 0 13/04/2011 23h13
Fuseau horaire GMT +1. Il est actuellement 06h23.
