Discussion fermée
Vieux 19/12/2012, 21h07   #1
ziregue
Représentant T-E
Avatar de ziregue
ziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to behold
Arrow Peugeot Service Box Documentation Backup + Sedre 11.2012
Fichier torrent
Année: 2012
Développeur: Peugeot
Plate-forme: Windows
compatibilité XP Vista WIN7
Type de fichier : rar Peugeot service box 11.2012.rar (29,4 Ko, 313 affichages)
Dernière modification par cedrsan ; 15/01/2014 à 03h02.
ziregue est déconnecté
The Following 37 Users Say Thank You to ziregue For This Useful Post:
Aflou-diag (22/05/2013), aladinno (27/12/2014), autodiagauto (23/04/2013), azqec (28/09/2013), barbenzingue (08/08/2013), CED300482 (23/01/2014), Cocobanana (02/12/2013), cristal (05/06/2013), DIAGAUTO33 (31/05/2013), dollarbill (13/05/2013), fibrosud34 (13/06/2013), Fougerit (20/01/2014), Funnyboy (08/06/2013), h tech (29/06/2013), kamal59500 (06/02/2014), kamikaz_tn (22/07/2013), marvine (24/12/2014), may4002001 (18/01/2014), medi2as3 (29/03/2015), menzoulou (04/06/2013), mohalhel (24/06/2013), MomoDiag35 (27/01/2014), multi290 (23/02/2014), mustaphcl (02/07/2014), NAJIBBB (28/06/2013), nasisamy (24/12/2012), passion-auto (23/01/2013), pip32 (19/06/2013), pitouille83 (27/01/2014), redpoker (22/01/2014), sam93 (18/02/2014), tanopierna (02/11/2013), taz22 (07/04/2013), wes62 (10/06/2013), Yassu18 (06/06/2022), youcef_trik (19/12/2012)
Vieux 03/06/2013, 20h54   #2
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Merci pour ton partage ziregue !
J'ai installé mais probleme pour le faire fonctionner .
Sedre fonctionne mais docs backup , impossible de selectionner des véhicules .
Quelqu'un d'autres à ce probleme ?
DIAGAUTO33 est déconnecté
The Following 2 Users Say Thank You to DIAGAUTO33 For This Useful Post:
Vieux 03/06/2013, 21h29   #3
Breizhelec
Avatar de Breizhelec
Pouvoir de réputation: 56
essaye sa , sa a marcher pour moi
Tu édites le registre par la commande regedit
Tu vas dans HKEY_LOCAL_MACHINE/SOFTWARE
Puis dans BackupAC et là tu modifies ce qui a trait à Appllocale c'est à dire tu changes locale en fr_FR
Breizhelec est déconnecté
DIAGAUTO33 (03/06/2013), marvine (24/12/2014)
Vieux 03/06/2013, 23h37   #4
DIAGAUTO33
Merci damdam pour ton aide mais je n'ai pas de dossier backup ni même sedre sous l'onglet software.
J'ai chercher un peu partout et je n'ai pas trouver ses dossiers.
Pense tu que mon installation est corrompu ?
J'ai aussi un problème avec sedre : pas d'affichage de schéma . J'ai exécuté svg viewer , même problème.j'ai essayé aussi avec isoview , même problème !
Je commence vraiment à désespérer !
Au secours ...
Vieux 04/06/2013, 07h46   #5
Breizhelec
houla , étonnant que tu n'est pas cela , l'installe a du mal se passer , sinon j'ai eu le cas
aussi ou il me manquait un dll , par contre peugeot sedre et docbackup s'ouvre avec IE
DIAGAUTO33 (05/06/2013)
Vieux 05/06/2013, 08h01   #6
ziregue
Représentant T-E
Avatar de ziregue
Afin de pallier les problèmes d'affichage des schémas électriques(SEDRE) notamment pour les utilisateurs
de Windows Seven 64 bits Edition Intégrale(Ultimate) et qui ont IE9 comme navigateur par défaut,
copier/coller le lien de la barre d'adresse dans un autre navigateur, par ex. Chrome, Firefox...
Si vous avez besoin de réinstaller, avant de recommencer l'installation supprimé les clefs de registre :
Peugeot:
[HKEY_LOCAL_MACHINE\SOFTWARE\BackupAP]
[HKEY_LOCAL_MACHINE\SOFTWARE\DocBackupAP]
[HKEY_LOCAL_MACHINE\SOFTWARE\SEDREAP]
[HKEY_LOCAL_MACHINE\SOFTWARE\ZDB]
[HKEY_CURRENT_USER\Software\ZDB]
The Following User Says Thank You to ziregue For This Useful Post:
DIAGAUTO33 (06/06/2013)
Vieux 06/06/2013, 22h46   #7
DIAGAUTO33
Merci ziregue pour ces infos.
J'ai essayé de copier dans un autre navigateur que ie (firefox) mais j'ai toujours le probleme d'affichage.
Aurais tu une idée ?
Envoyé par DIAGAUTO33 Voir le message
Quelqu'un pour m'aider pour mon probleme d'affichage des schemas ?
Dernière modification par cedrsan ; 20/01/2014 à 23h25.
Vieux 22/07/2013, 18h51   #8
mvl
Avatar de mvl
mvl will become famous soon enough
salut merci pour le partage j installer Sedre 11.2012 depuis 6 mois sur win7 et xp3 elle fonctionne normale la premier fois que je l'ouvre mais a partir de 2eme démarrage docbackupAP , impossible de selectionner des véhicules meme sur docbackupAC (ciroen) je pense pb de java ou d’installation car un msg dit:
(vous n’êtes pas connecté au réseau local. la documentation ne sera pas accessible depuis un autre poste)
j copier le lien vers un autre navigateur (firefox) le meme
mais sur le sedre aucun pb merci les amis
mvl est déconnecté
The Following User Says Thank You to mvl For This Useful Post:
kayl (26/07/2014)
Discussion fermée
Citroen Service Documentation Backup 2008 + SEDRE Amine-TE PSA Group Peugeot, Citroën 2 06/11/2010 17h31
Citroen Service Documentation Backup 2008+SEDRE alilou PSA Group Peugeot, Citroën 0 03/08/2009 12h09
Fuseau horaire GMT +1. Il est actuellement 05h37.
