Discussion fermée
Vieux 25/07/2009, 03h27   #1
toumi111
Avatar de toumi111
toumi111 is an unknown quantity at this point
Par défaut Scania multi (02-2009)Trucks, Buses, Industrial, Marines and etc.
The chassis number says it all: Scania Multi for shorter workshop visits
Scania Multi is one of the most advanced workshop information systems on the market. Using the chassis number, it is possible to individually tailor all the information needed to carry out servicing, fault-tracing and repairs on each individual vehicle, thus enhancing the quality and precision of the workshop's operations. At the same time, the customer benefits from a shorter standstill time.
Scania Multi is a PC program distributed on DVD-ROM. Scania Multi contains information about parts, workshop operations, time required and necessary instructions, and this information is structured according to the specific needs of each user category. The system Scania Multi saves time on several fronts, which is of major benefit to the customer in the form of shorter standstill times.
Time savings and better quality for the customer
 Precision: the right parts, times and operations from the very outset.
 Easily accessible information: quick searching, only relevant information.
 Rapid response: cost estimate at the first contact.
 Many languages: information in 9 languages increases precision and speed.
 Simple up******: only current information is found in the system.
 The workshop of the future: everyone at the Scania workshop has access to the information in Scania Multi, which makes for a flexible organisation.
 Local modifications are simple: Scania Multi is structured so that special adaptations can be integrated for each specific market.
Here is a typical sequence of events when visiting a Scania workshop which uses Scania Multi:
A driver observes a brake fault on his truck and drives to a Scania workshop. With the help of the chassis number, the customer receptionist calls up the truck's specification and uses Scania Multi to determine the work which needs to be carried out. The customer receptionist can thus immediately offer the customer a time and cost estimate.
The mechanic who takes on the job looks up Scania Multi to find out how it should be tackled on this particular truck, and verifies exactly which parts will be needed for this chassis number. The system despatches an order to the parts store, which fetches the relevant parts. The truck is repaired and the Scania Multi system then automatically produces the necessary documentation for invoicing the customer.
Many areas of use in the Scania workshop
Scania Multi is intended primarily for the following users within the Scania dealership organisation:
 Customer receptionists or workshop supervisors: they use the standard times list, fault-tracing diagrams, technical descriptions and bulletins, package activities.
 Mechanics: look up the function descriptions, operational descriptions, specifications and service bulletins.
 Parts personnel: they refer to the parts catalogue.
 Warranty personnel: they use the standard times list as their primary tool.
All this information is easily accessible to all users of Scania Multi. The system opens the door to a restructuring of workshop operations. The mechanic can if necessary act as a customer receptionist and can even handle invoicing and other follow-up processes.
Easy decision
The investment is a modest one for the Scania workshop. Scania Multi is run on a standard PC, which can be used for other tasks in the workshop. The program can also be run in a network. Its information is updated via CD-ROM discs which are sent to the workshops four times a year. Any supplements in between these four scheduled updates are provided in the form of paper printouts. The entire process is thus far simpler than trying to keep paper or microfiche copies of each individual publication up to date.
Parts catalogues, standard times lists and package price lists are included in Scania Multi as of November 2003. Workshop manuals with functional descriptions, operational descriptions, specifications and service bulletins will be fully entered into the system from autumn 2003.
VERSIN CRACKED
price 5000DA
toumi111 est déconnecté
Vieux 25/07/2009, 13h15   #2
toumi111
Avatar de toumi111
Le numéro de châssis dit tout: Scania Multi pour de courtes visites d'atelier
Multi Scania est un des plus avancés des systèmes d'information atelier sur le marché. Utiliser le numéro de châssis, il est possible d'adapter individuellement toutes les informations nécessaires pour mener à bien le service, faute de dépistage et de réparation sur chaque véhicule, renforçant ainsi la qualité et la précision de l'atelier de l'exploitation. Dans le même temps, le client bénéficie d'un temps plus court quo.
Scania Multi est un programme distribué sur PC DVD-ROM. Scania Multi contient des informations sur les pièces, les opérations de l'atelier, le temps requis et les instructions nécessaires, et cette information est structurée selon les besoins spécifiques de chaque catégorie d'utilisateurs. Le système Multi Scania de gagner du temps sur plusieurs fronts, ce qui est des principaux avantages pour le client sous la forme de courts délais de statu quo.
Les économies de temps et de meilleure qualité pour le client
? Précision: le droit des parties, les heures et les opérations dès le début.
? Une information facilement accessible: La recherche rapide, seulement les informations pertinentes.
? Réponse rapide: estimation des coûts au premier contact.
? De nombreuses langues: l'information en 9 langues augmente la précision et la vitesse.
? Simple mise à jour: seulement de l'information se trouve dans le système.
? L'atelier de l'avenir: tout le monde à l'atelier Scania a accès à l'information dans Scania Multi, qui permet une organisation souple.
? Les modifications locales sont simples: Multi Scania est structuré de façon que les adaptations spéciales peuvent être intégrées pour chaque marché spécifique.
Ici est un exemple typique de la séquence des événements lors de la visite d'un atelier qui utilise Scania Scania Multi:
Un conducteur observe un frein à la faute sur son camion et des lecteurs à un atelier de Scania. Avec l'aide du numéro de châssis, le client appelle la réceptionniste du camion Scania spécifications et les utilisations multiples de déterminer le travail qui doit être effectuée. Le client peut donc immédiatement réceptionniste offrir au client une estimation des coûts et de temps.
Le mécanicien qui prend sur le tas regarde Multi Scania pour savoir comment il devrait être abordé sur ce camion, et vérifie exactement quelles parties seront nécessaires pour ce numéro de châssis. Le système envoie un ordre de conserver les pièces, qui récupère les parties pertinentes. Le camion a été réparé et le Scania Multi système produit alors automatiquement de la documentation nécessaire pour la facturation au client.
De nombreux domaines d'utilisation dans les ateliers Scania
Multi Scania est conçu principalement pour les utilisateurs suivants dans le concessionnaire Scania organisation:
? Réceptionnistes client ou d'un atelier surveillants: ils utilisent la norme fois la liste, faute de traçage des diagrammes, des descriptions techniques et des bulletins, forfait activités.
? Mécanique: rechercher la fonction des descriptions, des descriptions opérationnelles, les spécifications et les bulletins de service.
? Parts du personnel: elles se réfèrent à la partie catalogue.
? Garantie du personnel: ils utilisent la norme fois leur liste comme outil principal.
Toutes ces informations sont facilement accessibles à tous les utilisateurs de Scania Multi. Le système ouvre la porte à une restructuration des opérations de l'atelier. Le mécanicien peut le cas échéant, agir en tant que réceptionniste d'un client et peut même gérer la facturation et les autres processus de suivi.
Easy décision
L'investissement est modeste pour l'atelier de Scania. Scania Multi est exécuté sur un PC standard, qui peut être utilisé pour d'autres tâches dans l'atelier. Le programme peut également être utilisé dans un réseau. Son information est mise à jour via un CD-ROM qui sont envoyés aux ateliers de quatre fois par an. Les suppléments réguliers entre ces quatre mises à jour sont fournis sous forme de papier imprimés. L'ensemble du processus est donc beaucoup plus simple que d'essayer de conserver des copies papier ou de microfiches de chaque publication à jour.
Catalogues de pièces, les listes et les temps standard ensemble des listes de prix sont inclus dans Scania Multi de Novembre 2003. Atelier manuels avec descriptions fonctionnelles, descriptions opérationnelles, les spécifications et les bulletins de service seront pleinement entrés dans le système à partir de l'automne 2003.
Discussion fermée
actia multi kmol Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 34 20/03/2020 06h15
actia multi diag baste59 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 8 01/07/2009 11h24
Renault Trucks Consult 02/2009 bencho2007 Renault clip, DDT2000, Nissan consult 0 26/03/2009 01h13
Multi-Di@g Auto-Diag Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 1 20/02/2009 19h56
Fuseau horaire GMT +1. Il est actuellement 07h55.
