Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Autres marques
Vieux 23/05/2026, 08h17   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Arrow Kobelco Service + Repair: Technical Manual Database
List of Kobelco Hydraulic Excavator Models:
▪ SK09SR
▪ SK15SR / SK20SR
▪ SK25SR / SK30SR / SK35SR
▪ SK40SR / SK45SR
▪ SK50SR
▪ SK60
▪ SK70SR / SK75UR / SK80CS
▪ SK100 / SK120 / SK120LC
▪ SK115SRDZ / SK135SRLC / SK135SRL
▪ SK140SRLC
▪ SK170-8
▪ SK200 / SK200LC
▪ SK200-8 / SK210LC-8
▪ SK210 / SK210LC
▪ SK235SR / SK235SRLC
▪ SK250 / SK250LC
▪ SK250-8 / SK260LC-8
▪ SK310 / SK310LC
▪ SK330 / SK330LC
▪ SK350-8 / SK350LC-8
▪ SK480 / SK480LC
Dealer Service Documentation (Kobelco Shop Manuals)
This archive represents a database of professional dealer service manuals (Shop Manuals) for Kobelco hydraulic excavators — ranging from compact SR series to heavy crawler machines.
The documentation is designed for in-depth diagnostics, maintenance, calibrations, and component repair. The manual structure is standardized and consists of four main sections:
I. GENERAL
Basic data required to start working with the machine and assess its condition.
▪ Specification: Technical characteristics of the machine.
▪ Location and Weight of Components: Layouts of main assemblies and their weight (critical for safe dismantling and removal).
▪ Maintenance Standard and Test Procedure: Reference values (circuit pressures, flow rates, clearances) and step-by-step procedures for their verification.
▪ Working Standard & Standard Man-Hour Table: Standard hours allocated for repair operations.
II. SYSTEMS
Section for system diagnostics and understanding the operational logic of the excavator.
▪ Hydraulic, Travel, Swing/Upper Structure: Hydraulic circuit diagrams and operating principles of hydraulic lines.
▪ Electrical & Control System: Wiring diagrams, pinouts, and controller logic.
▪ Troubleshooting: The most important diagnostic section. Contains algorithms for finding the root cause of failures based on symptoms or error codes.
III. COMPONENTS
Instructions for component repair (disassembly, inspection, assembly).
▪ Hydraulic Pump, Motor: Repair of the main pump, travel, and swing motors.
▪ Control Valve: Overhaul and adjustment of the main control valve.
▪ Other components: Swivel Joint, hydraulic cylinders, Reduction Unit, and basic Engine work.
IV. PROCEDURE
Step-by-step algorithms for safe removal, installation, and adjustment of equipment.
SUMMARY:
This documentation enables comprehensive service support for Kobelco excavators. It covers all specialist needs: from checking hydraulic pressure with testing gauges and reading wiring diagrams to the complete overhaul of main hydraulic components and travel reduction units.
Need it? Push button Thanks, PM for pass | or by email right now.
Type de fichier : txt Kobelco Service + Repair Manuals new.txt (34 octets, 3 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
mahfoud lichani (23/05/2026), Truc (23/05/2026)
Scania Service, Operators, Installation Manual, Parts Manual, Fault Codes Aleksey-MS Autres marques 1 05/08/2026 15h22
Renault Truck - Service Manual, Repair and Operation Manual, Engine Manuals Aleksey-MS Renault-Trucks 1 05/08/2026 15h15
Claas - Service, Repair, Operators, Technical Systems, Hydraulic System manuals Aleksey-MS Logiciel & autres documentations général 2 04/07/2026 11h53
Bobcat Service Manuals, Operators Manual, Parts Manual, Fault Codes Aleksey-MS Autres marques 2 16/06/2026 14h10
Toyota 2005-2013 Hilux Workshop Repair Service Manual TAGRART Toyota, Lexus 0 18/12/2014 12h52
Fuseau horaire GMT +1. Il est actuellement 03h45.
