![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Cummins Calterm 5.16
It's an engineering program for advanced tuning of Cummins engine ECUs. Unlike standard dealer scanners, it allows you to modify hidden factory calibrations: remove power and speed limits, and disable emissions control systems (EGR, DPF, SCR). Why are metafiles (.ecfg / .ecf) needed? These are configuration “translation maps” for a specific firmware version. Calterm will not work without them. They are needed for: Navigation: they specify the exact address of the desired parameter in the ECU’s memory. Decoding: converting raw machine code into human-readable text labels. Conversion: translating numerical values into physical quantities (RPM, bar, degrees). Conclusion: without the correct metafile, Calterm simply won’t understand the ECU’s data structure and won’t allow you to read or change settings. ![]() Need it? Push button Thanks, PM for pass | or by email right now.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | zourson (17/11/2026) |
Cummins Calterm 5.16 + MetaFiles
It's an engineering program for advanced tuning of Cummins engine ECUs. Unlike standard dealer scanners, it allows you to modify hidden factory calibrations: remove power and speed limits, and disable emissions control systems (EGR, DPF, SCR). Why are metafiles (.ecfg / .ecf) needed? These are configuration “translation maps” for a specific firmware version. Calterm will not work without them. They are needed for: Navigation: they specify the exact address of the desired parameter in the ECU’s memory. Decoding: converting raw machine code into human-readable text labels. Conversion: translating numerical values into ****** physical quantities (RPM, bar, degrees). Conclusion: without the correct metafile, Calterm simply won’t understand the ECU’s data structure and won’t allow you to read or change settings. Full list of updated metafiles ![]() Need it? Push button Thanks, PM for pass | or by email right now.
| Cummins Insite 8.8. 8.7, 8.5.2 - Mega + Cummins Incal (without pass) | Aleksey-MS | Cummins | 18 | 12/11/2026 15h46 |
| Cummins Calterm 4.7 et MetaFiles | mod-files.com | Cummins | 0 | 28/09/2025 22h52 |
| Cummins Calterm 5.3 (juste programmer sans activation) - Mega | Aleksey-MS | Cummins | 14 | 22/02/2025 14h58 |
| Cummins Calterm 4.7 et MetaFiles | mod-files.com | Cummins | 0 | 15/02/2020 12h35 |
| Calterm 3.8 + kg +instructions | mod-files.com | Caterpillar | 1 | 02/04/2017 08h19 |
