![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Xentry OpenShell 25.12.5
Xentry PassThru 25.12.4 Daimler Truck Diagnostic DTPID 24.4.3 Daimler Truck Diagnostic PassThru DTDPT 25.1.3 Xentry OpenShell: Dealer software for passenger cars (versions up to 09.2023 and for trucks), compatible with scanners (SD Connect and similar). Xentry PassThru: A lightweight version that works via the j2534-PassThru VCI, with limitations for some vehicle bodies. Daimler Truck Diagnostic DTPID: Dealer software for trucks (Actros, Arocs, etc.) and buses, compatible with scanners (SD Connect and similar). Daimler Truck Diagnostic PassThru DTDPT: Similar to the above, but designed for use via the PassThru VCI. ![]() Need it? Push buttons Rate+Thanks and private message for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 6 Users Say Thank You to Aleksey-MS For This Useful Post: | Amine-TE (20/03/2026), jeanalitre (28/05/2026), papoose063 (05/07/2026), sami47 (04/07/2026), ToNy68 (02/05/2026), zeubest (23/06/2026) |
Added a new versions.
What's new in Xentry OpenShell 25.12.5 Mandatory MFA: Logging in to all services (WIS, Tips) now requires multi-factor authentication. Cloud Integration: Enhanced connection with B2B Connect for quick parts ordering directly from the diagnostics session. Xentry Tips: Completely moved into the diagnostics interface (the separate app is being decommissioned). Smart Cart: Automatic suggestion of related parts and consumables when selecting parts. Stability: Improved compatibility with Windows 11 and faster loading of online add-ons. This means greater online control and simplified parts ordering. Xentry PassThru 25.12.4 What's new in Xentry PassThru 25.12.4 Mandatory MFA: Access to diagnostic functions, XENTRY Flash, and WIS now requires multi-factor authentication via a smartphone or token. XENTRY Flash Role: Stricter access control has been introduced. Coding and programming (flashing) units now requires the extended "XENTRY Flash" role, which is linked to a specific user. Dynamic Wiring Diagrams (DWD): Integration of up-to-date online wiring diagrams that are loaded for a specific VIN in real time. J2534 Optimization: Improved data exchange stability with popular adapters (Tactrix Openport 2.0, Scanmatik 2 Pro) for new 2024-2025 models using DoIP protocols. Online Dependency: A persistent internet connection is now required to start a session and verify the license (StartKey). Offline work is severely limited. This means the primary focus is on cybersecurity (MFA) and a complete transition to the Mercedes-Benz B2B Connect cloud environment.
| The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post: |
#3 | |
Need it? Push button Thanks, PM for pass | or by email right now for OpenShell or Passthru.
| The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post: | Amine-TE (20/03/2026), jeanalitre (28/05/2026) |
#4 | |
Online login only: Mandatory two-factor authentication (2FA) has been implemented. Updated 2026 certificates: Fixed crashes caused by outdated certificates (including C003). New databases: Added firmware and protocols for the latest 2025–2026 Mercedes-Benz models and electric vehicles (EQ series). Purchasing credits (PassThru): A button for quickly purchasing temporary licenses (Time Credits) has been added directly to the menu. B2B Connect: Improved VIN search and integration with the RMI documentation portal. In short: Up****** is only worthwhile for diagnosing the newest vehicles (2025–2026) and obtaining current certificates for online access. There are no changes for older vehicles.
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | jeanalitre (28/05/2026) |
XENTRY OpenShell & PassThru + Daimler Truck Diagnostic
WHAT INSIDE: * Xentry OpenShell 26.6.4 * Xentry PassThru 26.6.4 * Daimler Truck Diagnostic DTPID 24.4.3 * Daimler Truck Diagnostic PassThru DTDPT 25.1.3 1. MAIN FUNCTIONS AND MODULE ACCESS PASSENGER CARS & LIGHT VANS (XENTRY) * Xentry OpenShell: Dealer software for passenger cars (versions up to 09.2023 also cover trucks), compatible with dedicated scanners (SD Connect and similar). * Xentry PassThru: A lightweight version that works via the J2534-PassThru VCI, with some limitations for specific vehicle bodies. HEAVY COMMERCIAL VEHICLES (DAIMLER TRUCK) * Daimler Truck Diagnostic DTPID: Dealer software explicitly for trucks (Actros, Arocs, etc.) and buses, compatible with multiplexers (SD Connect and similar). * Daimler Truck Diagnostic PassThru DTDPT: Dealer software for trucks and buses designed specifically for use via the PassThru VCI standard. ![]() Need it? Push button Thanks, PM for pass | or by email right now for OpenShell or Passthru.
faut-il le VCI absoulement ou bien une autre interface peut faire le taff pour se connecter sur XENTRY ? Merci |
| Xentry Passthru OpenShell 2021.12 | boukrama | MBStar, Xentry, DAS | 13 | 11/07/2022 21h59 |
| Xentry Passthru OpenShell 2022.03 | boukrama | MBStar, Xentry, DAS | 11 | 09/03/2022 22h37 |
| Xentry Passthru OpenShell 2021.06 | boukrama | MBStar, Xentry, DAS | 1 | 09/06/2021 19h51 |
| XENTRY OPENSHELL XD EU & USA PassThru 2017-12 | nastradini | MBStar, Xentry, DAS | 9 | 19/06/2018 12h47 |
| Xentry OpenShell PassThru 05-06.2016 | Montassar Ben Mabrouk | Outils de diagnostique | 0 | 06/07/2017 15h36 |
