![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BMW ISTA-P 3.74.0.930 + ISTA+ 4.56.32 + Toyota ISTA 4.52.44
BMW ISTA-P 3.74.0.930 For programming, coding, and up****** ECUs in all BMW E-series models. BMW ISTA+ 4.56.32 For diagnostics, troubleshooting, and programming. This version is compatible with all modern F, G, and I-series vehicles, and also supports diagnostics for the E-series. Toyota ISTA 4.52.44 For servicing the Toyota Supra (J29/A90 generation), which is built on the BMW platform. Since this model's electronics are completely identical to the BMW G-series, the standard Toyota Techstream program does not work with it; the ISTA interface is required. The program allows for full diagnostics, software updates (I-Step), coding of control units, and component adaptation for the Supra, and also includes technical manuals and wiring diagrams. ![]() Download link. Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 5 Users Say Thank You to Aleksey-MS For This Useful Post: | Abdelrais (05/09/2026), ishams2002 (31/07/2026), jarod (18/08/2026), joe28052707 (09/03/2026), vortex (16/08/2026) |
BMW ISTA+ Rheingold, ISTA-P & Toyota ISTA – Installation Files
What inside • BMW ISTA-P 3.75.0.400 • BMW ISTA+ (Rheingold) 4.60.20 • Toyota ISTA 4.52.44 • Installation files only. • And without additional databases—PSdZdata, SQLiteDBs. BMW ISTA-P BMW's factory programming platform for E-Series vehicles. Functions: • ECU programming and software updates • Control unit coding • Retrofit coding • Vehicle Order (VO/FA) processing • Replacement module programming • Firmware updates Supports BMW E-Series, MINI R-Series, and related Rolls-Royce models. BMW ISTA+ Rheingold BMW's dealer diagnostic system for E, F, G, and I-Series vehicles. Functions: • Full vehicle diagnostics • Fault code reading and clearing • Live data monitoring • Service functions and adaptations • Actuator tests • Guided troubleshooting • Programming and coding support • DoIP diagnostics • Technical information and repair procedures Compatible with ICOM, ENET, K+DCAN, VXDIAG, and J2534 interfaces. Toyota ISTA Specialized ISTA version for Toyota GR Supra A90/A91 (J29), which uses BMW electronics and control systems. Functions: • Full diagnostics • ECU coding and programming • Software updates (I-Step) • Adaptations and service procedures • Technical documentation • Wiring diagrams Unlike standard Toyota Techstream, ISTA provides access to BMW-based systems used in the Supra platform. ![]() Need it? Push button Thanks, PM for pass | or by email right now.
What's new in Toyota ISTA
* Version Update: Software updated to the latest 4.58.41 release. * Vehicle Coverage: Added diagnostic support for the newest Toyota models. * Database Update: Integrated the latest diagnostic routines, offline repair manuals, and wiring diagram updates.
What's New in BMW ISTA v4.60.42 & ISTA-P v3.75.0.400
* Updated core system application: ISTA+ (Rheingold) to v4.60.42 and ISTA-P to v3.75.0.400. * Enhanced vehicle identification speed and DoIP communication stability for newer F, G, and I-Series models. * Improved support for Secure Token handling and Component Theft Protection (CP) unlocking procedures. * Optimized ICOM and K+DCAN connection protocols for legacy E-Series programming and coding via ISTA-P. * Updated guided troubleshooting trees, service functions, and adaptation routines for the latest chassis. * Resolved bugs related to specific ECU fault code reading and wiring diagram rendering.
What's new in BMW ISTA+?
Major update in the topic! We have added the complete installation package: BMW ISTA+ 4.60.1x (full). Also, the previous update package was renamed to BMW ISTA+ 4.60.42 (updates only) to avoid confusion. Check the first post for download links!
| SQlites french pour ISTA-D 4.13.14_ ISTA-P 3.65.1.002. | luizon | BMW, Mini, Rolls-Royce | 6 | 07/11/2021 17h55 |
| ISTA-D 4.21.12 (Rheingold ISTA +) Français décembre 2019 | omarzoro | BMW, Mini, Rolls-Royce | 49 | 03/10/2020 11h00 |
| ISTA-D 4.13.14_ ISTA-P 3.65.1.002 + Frensh SQLiteDBS | omarzoro | BMW, Mini, Rolls-Royce | 61 | 14/09/2020 19h59 |
| Probléme suppression dtc avec ISTA/P ISTA/D 4.04 | danyparis | BMW, Mini, Rolls-Royce | 4 | 14/03/2018 07h18 |
