Pouvoir de réputation: 113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Hello
Pour utilisateur de Panasonic L'état des batterie est difficile a connaitre vu impossible a lire en SMbus sur le connecteur. Dispo pour membre confirmes selectionnés, tool de panasonic pour le faire en windows. (pas la peine de me souler ni envoyer 50 messages je répond a qui j'ai envie...) Cherchez vous même si cela va pas assez vite lol. Tester sur CF54 CF53 et CFD1, 1 clic et hop Exemple de read : System Information EC Ver : xxxxxxxxxxxxxxxxxxxxxxx BIOS Ver : xxxxxxxxxxxxxxxxxxxxxxx ModelNumber : xxxxxxxxxxxxxxxxxxxxxxx Date : 2025/04/22 09:19 Battery1 EEPROM EEPROM Static data (0100) = 0006 EEPROM Design Capacity (0102) = 4080(mAh) EEPROM Design Voltage (0104) = 11100(mV) EEPROM ChargingCurrent (0106) = 1428(mA) EEPROM ChargingVoltage (0108) = 12600(mV) EEPROM ChargingVoltage HTP (010A) = 12000(mV) EEPROM DeviceName (0110) = CF-VZSU0P EEPROM ManufactureDate (S/N)(0120) = 2019/05/23 (1420) EEPROM PackRevision (0129) = F EEPROM BattLow3 Voltage (0130) = 9000(mV) EEPROM ChgVoltageFull (0132) = 12000(mV) EEPROM ChgVoltageFull HTP (0134) = 11400(mV) EEPROM ChargingCurrent HTP (0136) = 1500(mV) Rev3 Charging Voltage (01E0) = 0(mV) Rev3 Charging Voltage HTP (01E2) = 0(mV) Rev3 Full Detect Voltage (01E4) = 0(mV) Rev3 Full Detect Voltage HTP(01E6) = 0(mV) Rev4 Quick Charging Current1(01E8) = 80(0.01C) Rev4 Quick Charging Current2(01E9) = 70(0.01C) Rev3 Quick Charging Voltage1(01EA) = 12000(mV) Rev4 Quick Charging Voltage2(01EC) = 12300(mV) EEPROM Battery Status (0000) = 0000 EEPROM Full Charge Capacity (0004) = 4080(mAh) EEPROM Remaining Capacity (0008) = (*unused*) EEPROM Cycle Count OLD (000C) = (*unused*) EEPROM Cycle Count (0044) = 16 EEPROM StartDate OLD (0010) = (*unused*) EEPROM StartDate (0048) = 2024/09/06 vs. 00/00/00 EEPROM FullChargeCapacity_H (0014) = 0(mAh) EEPROM Sum of Charge_mAh (0018) = 801(mAh) EEPROM ChargeVoltDynamic (001C) = 12000(mV) EEPROM Auto High temp. (0020) = 0000 EEPROM BattTemp. Min/Max (0024) = -60/194(deg.) EEPROM AutoHighTempLastDate (0028) = (*unused*) EEPROM RefreshLastDate (002C) = 00/00/00 EEPROM OnlyChg80StartDate (003C) = (*unused*) EEPROM BattDegradation (0040) = 0000 Battery1 Status Power Unit = (10mWh) Design Capacity = 3623(10mWh) Last Full Charge Capacity = 0(10mWh) Battery Technology = Secondary Design Voltage = 11100(mV) Battery Status = 01 Battery Present Rate = 1452(10mWh) Battery Remaining Capacity = 0(10mWh) (0%) Battery Trip Point = 0(10mWh) Battery Present Voltage = 11196(mV) Battery capacity of Warning = 326(10mWh) Battery capacity of Low = 144(10mWh) Battery Temperature = 24.5(deg.) Battery model number field = CF-VZSU0P Manufacture Date = 2019/05/23 Battery Serial Number = 1420 Battery Type = LION Cycle count = 16 Battery Condition = 5 Error Code = 0 Battery1 Misc Power Unit = (10mWh) Battery Type = Log(PEC) Voltage = 11196(mV) Current = -1296(mA) ChargingVoltage = 12000(mV) ChargingCurrent = 1500(mA) VH = 3732(mV) VM = 3756(mV) VL = 3743(mV) VoltageFull detect = 11400(mV) LowBatt3 setting = 9000(mV) sumOfCharge_mA = 801(mAs) sumOfDischarge_mA = 817(mAs) AmountOfCharge_mA = 65535(mAs) on-charging time = 652(min) off-charging time = 953(min) discharging time = 673(min) Start Date(RAM) = 2024/09/06 Last Recalibration Date(RAM)= 00/00/00 Charge PWM value = 0h Step Charge Status = Init. Revision = 6 LogBattery1 EEPROM 0x1F8 : 00 00 AF 00 00 00 00 00 Registers PRTC_MODE (0x10) = 5 PACK_STATUS (0x15) = 0 Battery2 EEPROM Battery2 Not Present Battery2 Status Power Unit = (10mWh) Design Capacity = 0(10mWh) Last Full Charge Capacity = 65535(10mWh) Battery Technology = Primary Design Voltage = 0(mV) Battery Status = 00 Battery Present Rate = 65535(10mWh) Battery Remaining Capacity = 65535(10mWh) (0%) Battery Trip Point = 0(10mWh) Battery Present Voltage = 65535(mV) Battery capacity of Warning = 0(10mWh) Battery capacity of Low = 0(10mWh) Battery Temperature = -273.2(deg.) Battery model number field = Manufacture Date = 00/00/00 Battery Serial Number = 0 Battery Type = Cycle count = 0 Battery Condition = 0 Error Code = 0 Battery2 Misc Power Unit = (10mWh) Battery Type = Log Voltage = 65535(mV) Current = 0(mA) ChargingVoltage = 0(mV) ChargingCurrent = 0(mA) VH = 65535(mV) VM = 65535(mV) VL = 65535(mV) VoltageFull detect = 0(mV) LowBatt3 setting = 0(mV) sumOfCharge_mA = 0(mAs) sumOfDischarge_mA = 0(mAs) AmountOfCharge_mA = 0(mAs) on-charging time = 0(min) off-charging time = 0(min) discharging time = 0(min) Start Date(RAM) = FF/FF/FF Last Recalibration Date(RAM)= FF/FF/FF Charge PWM value = FFh Step Charge Status = Init. Revision = 0 LogBattery2 EEPROM 0x1F8 : 00 F4 00 00 18 F4 52 16 Registers PRTC_MODE (0x10) = FF PACK_STATUS (0x15) = FF Bridge Battery Bridge Battery Exist : 0x00 Main Battery Lid : close Bridge Battery Voltage : 72(mV) Bridge Battery Temperture : 3002.8(deg.) Bridge Battery Deterio Judge : 0x0000 Bridge Battery Pin Status : 0x03 |
| The Following User Says Thank You to fils For This Useful Post: | thomas (22/04/2025) |
Pouvoir de réputation: 25 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
je ne sais pas si ça fonctionne sur mes vieux CF19, mais je t'envoi un mp. c'est toujours mieux de pouvoir anticiper le chgt de la batterie. en tout cas, je suis étonné par le nombre d'infos que cela peut sortir !!! merci |
Sa dépend du bms de la batterie Je vais regarder pour le 19 Tu connais le type de bms ? |
Ok post une photo avec les références quand tu as le temps je préfère vérifier plutôt qu exécuter outil non étudié pour lol
SAlut
la batterie étant scellée.. c'est pas facile .. j'en ai dépioté une fois, le bms est dedans, mais tout est parti à la poubelle, irréparrable. |
| IMAGE windows 7 pour panasonic cf-54 mk3 | S-keys | Systeme d'exploitation | 23 | 21/12/2024 14h27 |
| Read write renesas avec le dev tool | fils | Programmateur de composant (flasher) | 8 | 21/10/2024 17h08 |
| Renault ecu tool " wrong transponder data " | progdebutant | Outil de programmation | 6 | 03/06/2018 19h15 |
| AirBag CAN Service Tool - SmartOBD - CRASH DATA FIXED BY OBD2 | CPT | CarProTool Programmer | 4 | 08/05/2018 08h23 |
| Read Point BSI C5 pour lecture HC912 | Ols | PSA Group Peugeot, Citroën | 7 | 14/05/2012 13h02 |
