Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > Launch X431
Vieux 09/03/2025, 12h03   #1
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut interface thinkdiag
J'ai.. interface thinkdiag deja activé sur aplication thinkdiag .
Puis-je installer Diazone dessus ?
Serial 9798xx
tarik_electronic est déconnecté   Réponse avec citation
Vieux 10/03/2025, 11h32   #2
tarik_electronic
je veux des informations avant d achat de l activación
oublié pas le petit " thanks "
Vieux 10/03/2025, 11h58   #3
jcb31100
Avatar de jcb31100
Bjr je croit que c est pas le meme firmware ( programme interne) . Donc il faudra peut-être le flasher pour pouvoir utiliser Diagzone?
tarik_electronic (10/03/2025)
Vieux 10/03/2025, 22h42   #4
tarik_electronic
Danc il faut un dump DZ et les pinout pcb
Vieux 11/03/2025, 09h09   #5
jcb31100
Avatar de jcb31100
Bjr Fait des recherche ( mais risque de grille ton boitier ) .
ce sera plus simple que tu achete une interface avec ancien bootloader
tarik_electronic (12/03/2025)
Vieux 12/03/2025, 07h53   #6
reda75
Avatar de reda75
Pouvoir de réputation: 67
reda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond repute
Bonjour ça marche directement sur diag zone pas obligé de flasher l'interface
Je ne suis pas ici pour de la pub ou de la concurrence,
je dois être aidé et aider les autres.
reda75 est déconnecté   Réponse avec citation
Vieux 12/03/2025, 10h04   #7
tarik_electronic
Envoyé par reda75 Voir le message
Reda Merci pour la réponse.
Es-tu sûr?
Vieux 12/03/2025, 18h11   #8
reda75
Avatar de reda75
Salut oui je suis sûr j'ai déjà le même cas
Vieux 12/03/2025, 18h44   #9
zebulons
Avatar de zebulons
zebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of light
Salut, il faut juste que ton firmware soit en 1.23.004, il me semble. Après, tu peux contacter Xdols ou Diagzone, ils pourront te le confirmer rapidement.
---------- Post added at 18h44 ---------- Previous post was at 18h36 ----------
Pour vérifier la version de ton firmware, utilise launch fw checker
zebulons est déconnecté   Réponse avec citation
Vieux 12/03/2025, 21h02   #10
Snatsh
Avatar de Snatsh
+1 avec reda j'ai cette interface et fonctionne direct avec diagzone
Vieux 13/03/2025, 00h18   #11
tarik_electronic
Your device is has locked main chip . It is not work as pro .
Cela signifie qu'il est verrouillé. Il ne peut pas être exécuté sur diagzone.
Merci a tt
Démontage thinkdiag zefirin Café du forum 8 02/12/2022 19h42
Interface Thinkdiag Warry Launch X431 1 26/02/2022 20h44
4 pcs thinkdiag DIAGZONE Vente, Achat, Echange 23 16/07/2021 01h26
Thinkdiag djspike Launch X431 15 06/09/2020 21h54
thinkdiag guigui525 Launch X431 16 10/07/2020 15h48
Fuseau horaire GMT +1. Il est actuellement 13h31.
