Précédent   Tlemcen Car electronics > Tableau de bord, Habitacle & securité conducteur > Boite de vitesse > DSG
Vieux 20/02/2025, 23h24   #1
danyparis
Avatar de danyparis
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Par défaut Info compatibilités et interchangeabilités DQ250 DSG6
Voila des informations très utiles (qui ne sont pas de moi je precise) concernant les compatibilités et interchangeabilités des DQ250 DSG6.
Here some informations about 02E Hardware Numbers assignment
GROUP "Cxx" EARLY UNITS all with analog inputs (for speed signal, shift paddles or reverse light control) (used moslty 2003-2004 some of them have additional pins in connector
02E927770 E
02E927770 G
02E927770 K
02E927770 L
02E927770 M
02E927770 AA
GROUP "Cxx" (2004 - 2006)
02E927770 AD - replaces all EARLY analog units because can EMULATE analog inputs.
02E927770 AE - used only on cars from year 2004 which DO NOT use analog signals anymore.
GROUP "Exx" (2007 - 2008)
02E927770 AJ - used as replacement for AE, CAN only, no K-Line anymore.
02E927770 AK - no information nor experiences til now. Very rare unit.
GROUP "Fxx" (2008 - 2015)
02E927770 AL - replacement for AE, AJ
02E927770 AM - theoretically can be used on some cars which still needs AD, but special software versions are required.
02E927770 AT - replace AL
IMMOBILIZED UNITS used on MQB cars with UDS diagnostic protokoll.
Cannot replace NON-IMMO units, because of bootloader incompability.
02E927770 AN
02E927770 AQ
02E927770 AS
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
Vos besoin sur DSG6 DQ250 /DSG7 DQ200 brahimlamgarbi DSG 43 30/01/2025 00h33
Swap DSG7 dq200 vers DSG6 dq250 Roller93 DSG 25 06/09/2024 17h50
P0776 dq250 dsg6 CARPE13IEM DSG 0 30/05/2024 08h51
Cherche mesures / plan outil de blocage DSG6 DQ250 WJon DSG 16 03/07/2022 09h58
Compatibilité mécatronic dsg6 DQ250 everson29 DSG 0 23/06/2022 20h01
Fuseau horaire GMT +1. Il est actuellement 15h49.
