Vieux 02/07/2023, 20h06   #1
SRA
Avatar de SRA
Pouvoir de réputation: 8
SRA will become famous soon enoughSRA will become famous soon enough
Arrow SERMI unlock-Key Calculator for Official PSA DIAGBOX
Calculator to access code protection for Manual Telecoding SERMI
the RMI (SERMI) keygen or calculator for the telematic and all other EX devices.
The original DiagBox like the agents needs a 16 digit sermi code, they unlock online to do manual telecoding Before you can telecode you get an RMI protection code with 16 chars (XXXX-XXXX-XXXX-XXXX) that needs to be unlocked first.
Normally you can buy tokens from pinonline.net but in the long run, that will be pretty expensive.
Official DIAGBOX SERMI:
Key Calculator cost: 250$/1-pc
1-Code cost : 30$/1-code
[img=393x393]https://diagautosolutions.com/wp-content/uploads/2022/06/SERMI-Calculator.jpg[/img]
__________________________________________________ _____________
SRA est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to SRA For This Useful Post:
diago2001 (11/07/2023), Jenetik (12/02/2024), pp08 (03/07/2023), sasa (02/07/2023), Snatsh (02/07/2023)
Vieux 02/07/2023, 23h56   #2
OILC93
Avatar de OILC93
Pouvoir de réputation: 40
Si je comprends bien c'est pour le télécodage en ligne le numero de série la ?
C'est quoi un logiciel qui calcul ce code pour telecoder en ligne ?
sasa (03/07/2023)
Vieux 03/07/2023, 09h46   #3
adiago
Avatar de adiago
Pouvoir de réputation: 35
cela permet de faire du téléchargement/télécodage hors ligne ,par contre je crois que cela fonctionne avec diagbox original ?
---------- Post added at 06h46 ---------- Previous post was at 06h43 ----------
PSA FN Unlock User Manual:
https://mega.nz/file/PMlxlBYT#-noIPL...9H8NYunTcPLIjM
https://pin-online.net/psa
The Following 2 Users Say Thank You to adiago For This Useful Post:
OILC93 (03/07/2023), sasa (03/07/2023)
Vieux 03/07/2023, 10h42   #4
akos421
Avatar de akos421
akos421 is a glorious beacon of lightakos421 is a glorious beacon of lightakos421 is a glorious beacon of lightakos421 is a glorious beacon of lightakos421 is a glorious beacon of lightakos421 is a glorious beacon of light
J'ai diagbox original j'avais l'accès en ligne sur un véhicule et quand on m'a demandé ce serial c'est en voulant faire telecodage manuel du BSI sur les Delphi il me semble, du coup c'est juste pour passer ce serial ?
Envoyé de mon SM-G780G en utilisant Tapatalk
akos421 est déconnecté   Réponse avec citation
The Following User Says Thank You to akos421 For This Useful Post:
OILC93 (03/07/2023)
Vieux 03/07/2023, 10h51   #5
adiago
Avatar de adiago
ce logiciel donne en réponse le code pour faire le télécodage.
OILC93 (03/07/2023), pp08 (03/07/2023)
Vieux 03/07/2023, 12h23   #6
electronico
Avatar de electronico
Hello tout le monde,
Donc @SRA :
Pour 250 balles on télécode avec Diagbox autant qu'on veut à partir d'un seul PC ??
Hi @SRA,
So : USD250. for unlimited Diagbox telecoding for 1 PC ??
Thanks to clarify.
adiago (06/10/2023)
Vieux 03/07/2023, 12h31   #7
Pouvoir de réputation: 113
Envoyé par electronico Voir le message
Donc @SRA :
Hi @SRA,
Thanks to clarify.
Slt
Non pas vraiment c est pour dbox OI
D abord passage token
J avais ouvert un post dessus
Sûrement son appli est lié au hwid du pc en plus :-(
electronico (03/07/2023), jah83 (11/07/2023)
Vieux 03/07/2023, 13h15   #8
adiago
Avatar de adiago
pour faire simple diagbox version Rorry et autres dérivés ne peut pas fonctionner avec .
il faut une version OI pour opérateur indépendant
Vieux 03/07/2023, 17h23   #9
akos421
Avatar de akos421
C'est juste pour pouvoir faire certain telecodage manuel qui demande un serial mais avec une interface original et un token
The Following 2 Users Say Thank You to akos421 For This Useful Post:
adiago (03/07/2023), youcar (03/07/2023)
Vieux 04/07/2023, 07h26   #10
Je pense c était nécessaire de faire ta pub sur son annonce de vente :-( sachant ton tool est loin d être gratuit.
En plus soyons réaliste ce truc SERMI est loin d être magique tu le sais bien...
adiago (04/07/2023), jah83 (11/07/2023)
Vieux 08/07/2023, 12h10   #11
SRA
Avatar de SRA
Salut frére, c'est pas hors ligne, le contraire...
c'est pour l'official Diagbox en ligne, et le télecodage ce fais par un télechargement depuis le serveur de PSA Group.
C'est pas pour les versions hors ligne.
Bientôt je vais mettre un video d'operation
Vieux 08/07/2023, 12h17   #12
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
kmtech merci de ne plus intervenir sur les posts de vente pour t en servir a te faire de la pub !!!
pas d autre avertissement ah bon entendeur
cdlt
Pas de Thank's plus d aides
seadoo831 est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to seadoo831 For This Useful Post:
Bollide (11/07/2023), jah83 (11/07/2023)
Vieux 11/07/2023, 00h06   #13
kmtech
Avatar de kmtech
Pouvoir de réputation: 67
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
cdlt
Ce n’était pas de la pub simplement pour indiquer que c’est une des nombreuses fonctions du soft. Si un autre logiciel le faisait je l’aurai également fait remarquer, tout le monde ne sait pas que RD le fait donc c’est surtout pour informer les utilisateurs actuels.
Bien à toi.
kmtech est déconnecté   Réponse avec citation
Vieux 11/07/2023, 00h21   #14
kmtech
Avatar de kmtech
Seadoo, je ne vois pas non plus une règle dans la charte du forum qui indique qu’il est interdit de faire de la promotion. Il serait peut-être bon de le rajouter sauf si tu fais du cas par cas ;) sur le thread de RocketDump tu laisses allègrement faire quiconque la promotion d’autres solutions ça te gêne moins dans ce sens.
Je laisse à ton bon soin de voir avec Amine. Bonne soirée
Dernière modification par kmtech ; 11/07/2023 à 00h25.
Vieux 11/07/2023, 07h40   #15
jah83
Avatar de jah83
Pouvoir de réputation: 245
Mdr.... C était pas de la pub.... Et la marmotte elle met le chocolat dans le papier alu.....
La différence de traitement provient peut etre du fait que tu prennes les gens pour des jambons depuis déjà bien longtemps sur le forum.
adiago (20/06/2024), dalco (16/07/2023)
SERMI générateur clé fils PSA Group Peugeot, Citroën 1 13/10/2025 09h51
ALPHANUMERIC CODE CALCULATOR v0.1 UNLOCK For Iveco guyguy307 Iveco 11 27/10/2024 02h24
SETUP DiagBox Official 9.58 maitresox LEXIA, PP2000, DiagBox 3 09/11/2020 15h24
WinOLS 2.24+ WinOLS ECU File Unlock ORI+MODWinOLS ECU File Unlock + DAMOS Files hmicco Automobile en général 5 28/03/2020 17h02
ezs/elv unlock REDZONE31 Abrites France 32 02/03/2017 07h46
Fuseau horaire GMT +1. Il est actuellement 16h48.
