Précédent   Tlemcen Car electronics > Outils & Diag > Agricultures / Construction > Cummins
Vieux 03/08/2022, 20h49   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut Cummins InPower Pro 14 (installation files)
InPower provides the following functions for monitored equipment:
• Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls; For details on devices supported refer Technical Details tab.
• Allows the monitored equipment to send alarm information to a connected computer.
• Configurable for units of measurement, and level of user access (read only, read/change values, administrator).
• Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points and other values.
• Convenient programming of configurable inputs in the controllers.
• Viewing of equipment history, fault codes, and data associated with fault codes.
• Generates reports of monitored data
• Allows released firmware upgrades on Power Command genset controls.
• Plot critical parameters in a strip chart format, and export data to 3rd party software tools for manipulation and viewing.
• Simulate fault conditions in genset controls in compliance to NFPA 110 requirements to demonstrate functionality of the controller and monitoring equipment in a facility.
Type de fichier : txt Cummins InPower Pro.txt (54 octets, 4 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
darkboybeyond (02/12/2023), MecaTech (08/04/2025)
Vieux 03/11/2022, 10h07   #2
Aleksey-MS
The link was updated
Type de fichier : txt Cummins InPower Pro.txt (54 octets, 3 affichages)
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 30/12/2022, 20h42   #3
Aleksey-MS
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Type de fichier : txt Cummins InPower Pro.txt (137 octets, 1 affichages)
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
BAB62 (30/12/2022), darkboybeyond (02/12/2023), MecaTech (08/04/2025)
Vieux 30/12/2022, 20h51   #4
BAB62
Avatar de BAB62
Pouvoir de réputation: 9
BAB62 will become famous soon enoughBAB62 will become famous soon enough
Hi my friend,
Many thanks for your soft, but i think 90 percent of people on this forum Will not use this Last one.
i know some people who works with Cummins motors [emoji6].
If you have same for caterpilar i take[emoji6].
Have a Nice day.
Envoyé de mon SM-A125F en utilisant Tapatalk
un petit thanks, please :)
BAB62 est déconnecté   Réponse avec citation
Vieux 22/09/2023, 15h38   #5
Aleksey-MS
Vieux 22/09/2023, 15h56   #6
Aleksey-MS
Par défaut Cummins InPower Pro 14.5 (installation files)
added Cummins InPower Pro 14.5 (installation files)
Type de fichier : txt Cummins InPower Pro - Mega.txt (137 octets, 2 affichages)
Vieux 06/03/2024, 15h21   #7
mihv
Avatar de mihv
mihv can only hope to improve
mihv est déconnecté   Réponse avec citation
Vieux 29/07/2024, 12h11   #8
Aleksey-MS
New working link
Type de fichier : txt Cummins InPower.txt (32 octets, 1 affichages)
Vieux 07/07/2026, 15h06   #9
Aleksey-MS
Par défaut Cummins InPower Pro: Generator & Power System Diagnostic Software
WHAT INSIDE:
* InPower_16.rar
1. MAIN FUNCTIONS AND COMPATIBILITY
DIAGNOSTICS & TESTING
* Live Data Monitoring – displays real-time operational parameters of the power station (voltage, frequency, engine RPM, oil pressure, temperature).
* Fault Code Management (DTC) – viewing and clearing active/stored fault codes and associated historical data.
* Testing & Simulation – simulates fault conditions (NFPA 110 compliance) and tests Automatic Transfer Switch (ATS) mechanisms.
* Plotting & Reporting – plots critical parameters in a strip chart format, saves operation logs, and generates detailed diagnostic reports.
CALIBRATION & PROGRAMMING
* Parameter Adjustment – modifies nearly every operating parameter of the connected controller (voltage, frequency levels, protection set-points, overloads).
* Convenient programming of configurable inputs in the controllers.
* Enables official firmware upgrades for PowerCommand genset controls.
SUPPORTED EQUIPMENT & MODELS
* PowerCommand Controls (PCC 1301, 1302, 2100, 2300, 3100, 3201, 3300, etc.).
* Detector and Sentinel control systems.
* Engine Control Modules (ECM) on diesel and gas generator sets.
* Used on standby domestic generators, industrial container stations, gas piston power plants, marine generators, and stationary pumping/fire stations.
2. PACK FEATURES
PROFESSIONAL ENGINEERING TOOL
* Offers multi-level user access capabilities (Read-only, Read/Change, Administrator).
* Connects directly from a PC to genset, transfer, and system controls.
* Hardware Requirements: Requires a standard RP1210 diagnostic interface (e.g., Nexiq USB Link) or an original Cummins INLINE (6, 7, or 8) adapter.
DESCRIPTION:
Cummins InPower Pro is a highly advanced diagnostic, calibration, and configuration software for Cummins Power Generation equipment. Designed for industrial use, it allows technicians to connect directly to electronic control systems of diesel and gas generator sets. The software provides deep-level access for adjusting protection parameters, monitoring real-time data, simulating fault conditions, and flashing firmware, making it an essential tool for maintaining and repairing stationary power systems.
Need it? Push button Thanks, PM for pass | or by email right now.
Type de fichier : txt Cummins InPower Pro new.txt (34 octets, 0 affichages)
Cummins Insite 8.8. 8.7, 8.5.2 - Mega + Cummins Incal (without pass) Aleksey-MS Cummins 18 12/11/2026 15h46
cummins pinceau cimetière de présentation 1 02/09/2019 20h45
BMW ISTA 4.13.3x Installation Files Truc BMW, Mini, Rolls-Royce 1 08/10/2018 16h34
Inpower 11.5 FULL mod-files.com Autres marques 5 31/03/2017 20h31
Fuseau horaire GMT +1. Il est actuellement 06h13.
