Vieux 24/06/2022, 21h45   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut AlfaOBD 2.3.5.0 (for Android) Patched
AlfaOBD is a software for the diagnostics of the vehicles produced by Fiat Chrysler Automobiles (FCA) group. Fiat / Alfa Romeo / Lancia, Chrysler / Dodge / Ram / Jeep. Although the software is primarily targeted for car owners, it provides many of the features of the professional scanners.
The software supported:
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
  • K-Line USB interface.
AlfaOBD features include:
  • monitoring various dynamic parameters of the body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots.
  • reading of static data: ECU id, system status, fault codes with probable causes and environment information where applicable.
  • clearing fault codes, monitoring the system for the appearance of new faults.
  • active diagnostics and configuration procedures for various equipment controlled by engine, gearbox, body computer, climate control, ABS, airbag, code control, other ECUs. Service light reset, engine oil change, DPF regeneration and many more.
  • electronic key and RF remote control programming.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Type de fichier : txt AlfaOBD.txt (137 octets, 35 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 16 Users Say Thank You to Aleksey-MS For This Useful Post:
dziadzia82 (02/01/2024), fastboy974 (29/10/2024), gecko42 (12/04/2025), gtors (04/01/2024), herve971 (02/01/2025), jeanmi33 (09/06/2025), lazersate (13/01/2024), leprinceakh (26/07/2023), makif (01/08/2022), MecaTech (08/04/2025), mohaalba (09/09/2022), poloo20 (17/12/2023), SAMSAM69 (23/08/2023), thob33 (16/01/2023), zenata (24/06/2022), zzza (03/04/2024)
Vieux 02/05/2023, 15h21   #2
Aleksey-MS
Added AlfaOBD 2.3.8.0 for PC + AlfaOBD 2.3.2 for Android
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
adiago (02/05/2023), [email protected] (25/11/2025), MecaTech (08/04/2025)
Vieux 29/08/2023, 18h02   #3
Aleksey-MS
Added AlfaOBD 2.3.9.0 for PC + AlfaOBD 2.3.3 for Android
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
Vieux 19/09/2023, 21h06   #4
Aleksey-MS
Added AlfaOBD 2.4.4.0
Vieux 26/10/2023, 22h31   #5
Aleksey-MS
The link was updated
Type de fichier : txt AlfaOBD.txt (137 octets, 6 affichages)
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 20/02/2024, 07h33   #6
Aleksey-MS
Type de fichier : txt AlfaOBD.txt (24 octets, 7 affichages)
Vieux 10/05/2024, 10h23   #7
Aleksey-MS
Added alternative link
Type de fichier : txt AlfaOBD.txt (93 octets, 13 affichages)
[email protected] (19/06/2024), MecaTech (08/04/2025)
Vieux 23/06/2026, 13h20   #8
Aleksey-MS
Par défaut AlfaOBD: Advanced OBD2 Diagnostic Tools for Fiat, Chrysler, Jeep & Dodge
WHAT INSIDE:
* AlfaOBD for PC (version 2.4.4.0)
* AlfaOBD for Android (version 2.3.3, Patched)
1. MAIN FUNCTIONS AND MODULE ACCESS
ADVANCED DIAGNOSTICS AND HARDWARE SUPPORT
* Professional-level diagnostics for car owners and mechanics, supporting OBDLink, OBDKey, ELM327, Kiwi 3, and K-Line USB interfaces.
* Monitors dynamic parameters of the body, dash, engine, gearbox, ABS, and climate control, presenting data as adjustable graphical plots.
* Reads static data such as ECU ID, system status, and faults with probable causes.
* Clears errors and monitors the system for the appearance of new faults.
CONFIGURATION AND ACTIVE TESTING
* Performs active diagnostics and configuration procedures for equipment controlled by the engine, gearbox, body computer, climate control, ABS, airbags, security modules, and other ECUs.
* Executes service functions including service light reset, engine oil change, and DPF regeneration.
* Supports electronic key and RF remote programming.
2. PACK FEATURES
SUPPORTED VEHICLES (FCA GROUP)
* Fiat / Abarth: 500, Panda, Punto, Bravo, Tipo, Ducato, Doblo, and more.
* Alfa Romeo: Giulia, Stelvio, Giulietta, MiTo, 159, and more.
* Lancia: Ypsilon, Delta, Thema, and more.
* Chrysler: 300, Pacifica, Voyager, PT Cruiser, and more.
* Dodge / Ram: Challenger, Charger, Durango, Journey, Ram trucks (1500, 2500, 3500), and more.
* Jeep: Grand Cherokee, Wrangler, Cherokee, Compass, Renegade, and more.
* Peugeot / Citroen: FCA-based commercial vehicles (Boxer, Jumper).
DESCRIPTION:
AlfaOBD is an advanced diagnostic software tailored for vehicles produced by the Fiat Chrysler Automobiles (FCA) group. While accessible to everyday car owners, it delivers powerful features typically reserved for professional scanners. The application allows users to read and clear faults, monitor real-time sensor data, perform module configurations, and execute complex service resets across a vast lineup of Fiat, Alfa Romeo, Lancia, Chrysler, Dodge, Ram, and Jeep models.
Need it? Push button Thanks, PM for pass | or by email right now
Type de fichier : txt AlfaOBD new.txt (34 octets, 1 affichages)
Vieux 20/07/2026, 21h27   #9
rgeneral
Avatar de rgeneral
rgeneral is an unknown quantity at this point
Tu m'a appris un truc, je ne savais même pas qu'il y'avait une version mobile, peut être pratique en étant dehors juste avec le tél mulet sous android
Merci !
rgeneral est déconnecté   Réponse avec citation
Update PSA DiagBox WITHOUT Internet! V7.64 Allready PATCHED scarymistake LEXIA, PP2000, DiagBox 213 28/08/2026 17h08
AlfaOBD 2.2.8.0 FR + Activation Full X marques SaTouF Fiat, Alfaromeo, Lancia, Ferrari 43 23/03/2023 19h27
différence entre clear et patched Faridovitche Café du forum 6 15/02/2022 14h42
FORScan Lite v1.5.0 [Patched] pour Androïde zenata Ford, Mazda, Land Rover, Jeep, Jaguar 11 05/02/2020 10h55
logiciel diag alfaobd 1.9 stephane Fiat, Alfaromeo, Lancia, Ferrari 9 08/05/2017 02h09
Fuseau horaire GMT +1. Il est actuellement 17h22.
