| Autoradio et Navigateur GPS Astuce, dump, aide pour décodage d'autoradio et navigateur. |
![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
[size=large]Audi MMI3G High (HNav) MMI 3GP (HN+) 6.33.1 8R0051884JD - 2021/2022 + Activator Europe [/size]
[size=large]Car list:[/size]
[size=large]For those with a BOSE system[/size] [size=large]You cannot update the BOSE amplifier. By up****** BOSE - you can get a lot of problems with subsequent settings and parameterization of BOSE. What should be done?[/size]
[size=large]- Next, insert your media (CD or SD) into the head of the MMI. Everything is ready for up******.[/size] [size=large]Important! The update takes about 40 minutes, so it’s recommended to either start the car or connect an additional charger to the battery during the update.[/size]
[size=large]Here is the same as with the update. Copy the cards to the root of the memory card. Insert the card into MMI. Press SETUP + RETURN and perform the same actions as during the update. Cards will be loaded for several hours, so be patient. After the cards are loaded, they will work for 5 minutes and will be blocked. Then you need to activate. Unzip the previously downloaded archive with the card activator and put it in the root of the memory card. Next is the usual update procedure. Press SETUP + RETURN, etc.[/size] [size=large]If you have problems installing the cards, you can first remove the old cards from the MMI hard drive, and then install new ones. How to do this, read on.[/size] [size=large]The "hidden" menu is activated, go to it by pressing and holding the SETUP + CAR buttons.[/size]
![]() [size=large]Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.[/size]
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 10 Users Say Thank You to Aleksey-MS For This Useful Post: | dvb_gsm (24/04/2022), Ismaillanasri (12/05/2023), juju94 (27/03/2023), MartyMcFly (30/05/2023), maximin (27/05/2022), MECASOLUTION (23/04/2022), MecaTech (08/04/2025), Quattro899 (26/05/2022), samii1955 (11/05/2023), sebea33 (15/05/2023) |
Added new version Audi MMI3G High (HNav) MMI 3GP (HN+) 6.34.1 8R0051884JN - 2022
Added Audi MMI3G High (HNav) MMI 3GP (HN+) 6.35.1 Europe 2022-2023 + Activator
| The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post: |
Added Audi MMI3G High (HNav) MMI 3GP (HN+) 6.36.0 8R0051884KL - 2023 Europe
Pouvoir de réputation: 16 ![]() |
Bonjour Aleksey-MS, comment faire pour activer le GPS d'une Audi A1,je résume le gps est dans l'autoradio mais il faut l'activer par le constructeur.Cordialement
| The Following User Says Thank You to samii1955 For This Useful Post: | Ismaillanasri (12/05/2023) |
THe link was updated
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
Audi MMI 3G High & 3G Plus Europe Navigation Maps Update + Activator
Software Information: Complete update package for Audi MMI 3G High (HNav) and MMI 3G Plus (HN+) multimedia systems. Includes the latest Europe navigation maps, firmware updates, and the necessary activator. Strictly Supported Vehicles (MMI 3G High / 3G Plus ONLY): Important: Audi A1 and Q3 are NOT supported (they use RMC/3G Basic). Older 2007-2008 models with MMI 2G are NOT supported. - Audi A4 / S4 / RS4 (B8 / 8K): 2008–2015 - Audi A4 Allroad: 2010–2016 - Audi A5 / S5 / RS5 (8T / 8F): 2008–2017 - Audi A6 / S6 / RS6 (C6 Facelift): 2009–2011 - Audi A6 / S6 / RS6 (C7 / 4G): 2011–2015 - Audi A6 Allroad: 2009–2015 - Audi A7 / S7 / RS7 (4G): 2010–2015 - Audi A8 / S8 (D4 / 4H): 2010–2017 - Audi Q5 / SQ5 (8R): 2009–2017 - Audi Q7 (4L Facelift): 2010–2015 How to check compatibility: Go to your car's "Software Version" menu. It MUST start with: - HNav_... (MMI 3G High) - HN+_... or HN+R_... (MMI 3G Plus) If your version starts with BNav_ or RMC_, DO NOT install these maps! Important Installation Notes: - For HN+ systems (SDHC 32GB): DELETE folder LIT1-3 inside \pkgdb\ - For HNav systems (SDHC 32GB): DELETE folder LIT3GP1-4 inside \pkgdb\ - Use WinRAR 5.8 or newer to extract. - BOSE System Warning: DO NOT update the BOSE amplifier (it can cause parameterization issues). Remove all connectors from the BOSE amp and loop the optical MOST bus (part No. 4E0973802) before up****** firmware. Installation Process Summary: 1. Connect a battery charger or keep the engine running (update takes ~40 mins). 2. Insert SD card. Hold SETUP + RETURN to check version, then select source and start download. 3. For Map installation: Extract maps to the root of a fresh SD card, insert into MMI, press SETUP + RETURN. (Map loading takes hours). 4. Activation: Maps will block after 5 minutes. Extract the activator to an SD card, insert, press SETUP + RETURN to activate. Tip: If maps fail to install, activate the "Hidden Menu" (SETUP + CAR), enable "user mode", and delete old maps/navigation database first. ![]() Need it? Push button Thanks, PM for pass | or by email right now.
Correction & Update:
Identified issue: Package folder list was missing from the header, and unsupported models (A1, Q3) were erroneously listed. Fix applied: - Added verified folder contents: Audi HN+ Map 6.36.0 8R0051884KL 2023 and Audi HNav Map 6.36.0 8R0051884KL 2023. - Removed A1 and Q3 from vehicle list (both use RMC or 3G Basic hardware). - Restored complete step-by-step update routine and mandatory BOSE amplifier MOST bus bypass (plug 4E0973802).
| Audi MMI 3G BNav 5.31.2 Europe - 2021 | Aleksey-MS | Autoradio et Navigateur GPS | 7 | 22/09/2026 17h10 |
| MAP KIA Hyundai Europe 2021 | itinerance | Autoradio et Navigateur GPS | 0 | 30/08/2021 04h31 |
| Audi MAP Europe V 2021 | itinerance | Autoradio et Navigateur GPS | 2 | 29/08/2021 19h08 |
| Audi MMI3G Plus MAPS 2020-2021 | prt93 | Autoradio et Navigateur GPS | 6 | 14/07/2021 07h46 |
| Recherche DVD navigation MMI3G pour Audi | audi_siline | Autoradio et Navigateur GPS | 0 | 25/03/2014 22h42 |
