![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
SZ Viewer: read DTC for Suzuki App A1-2022-03-31 Update
A diagnostic application especially for Suzuki vehicles. SZ Viewer uses original protocols (via K-Line and CAN) instead of standard OBDII ones. It allows reading data and DTCs of almost all control modules (including extended Suzuki codes and historical errors). Japanese domestic market (JDM) Suzuki cars are also supported, even if they do not support OBDII. ELM327 adapter (Bluetooth or WiFi) version 1.4 or later is required. ![]() Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 11 Users Say Thank You to Aleksey-MS For This Useful Post: |
Added new version SZ Viewer: read DTC for Suzuki App A1-2022-06-02 Update
Added Suzuki Android App - SZ Viewer for read DTC from 09.2022
Added SZ Viewer vA1-2022-09-21
Addedd SZ Viewer from 15.10.2022
Added SZ Viewer from 27.10.2022
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
Added SZ Viewer for read DTC from 07.2023
Added SZ Viewer from 11.2023
Added SZ Viewer A1 2024-04-23
Added Suzuki Android App - SZ Viewer for read DTC from 08.2024
Added
Suzuki Android App - SZ Viewer for read DTC from 01.2025
SZ Viewer for Android: Suzuki ELM327 Diagnostic Software
DESCRIPTION: A diagnostic application especially for Suzuki vehicles. SZ Viewer uses original protocols (via K-Line and CAN) instead of standard OBDII ones. It allows reading data and DTCs of almost all control modules (including extended Suzuki codes and historical errors). Japanese domestic market (JDM) Suzuki cars are also supported, even if they do not support OBDII. ELM327 adapter (Bluetooth or WiFi) version 1.4 or later is required. MANUFACTURER-SPECIFIC DIAGNOSTICS AND DTC READING * Designed to read and clear diagnostic trouble codes (DTCs) across almost all internal control modules, including extended Suzuki-specific fault codes and historical error logs. * Utilizes original manufacturer communication protocols via K-Line and CAN buses instead of restricted standard OBDII parameters. ![]() Need it? Push button Thanks, PM for pass | or by email right now
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | nono75 (13/08/2026) |
| Diagbox v9.167 [09/2023] | Amine-TE | LEXIA, PP2000, DiagBox | 218 | 01/09/2026 04h44 |
| Le Mans moto 2022 | WJon | Café du forum | 6 | 15/04/2022 14h15 |
| psa 2022 | boris93600 | programmation & synchronisation de clé | 4 | 13/02/2022 14h14 |
| La technologie en 2022 | pimo | Café du forum | 1 | 13/01/2022 13h22 |
| Bonne anneee 2022 | Tof02770 | Café du forum | 1 | 01/01/2022 12h37 |
