Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Toyota, Lexus
Vieux 11/04/2022, 19h12   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut Toyota, Lexus Reprogramming / Calibration CUW files
Flash reprogramming allows the ECU software to be updated without replacing the ECU. Flash calibration updates for specific vehicle models/ECUs are released as field-fix procedures described in individual Service Bulletins. This bulletin details the Techstream ECU flash reprogramming process and outlines the use of the Technical Information System (TIS) and the Calibration Update Wizard (CUW). Flash calibration updates can only be applied to the vehicle/ECU combination for which they are intended. ECUs have internal security that will not allow them to be programmed with another ECU’s information.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Toyota, Lexus Reprogramming Calibration CUW files.rar
Car list CUW files.rar
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 8 Users Say Thank You to Aleksey-MS For This Useful Post:
attefco (25/04/2023), iesawyx (30/03/2024), jah83 (29/10/2022), MecaTech (08/04/2025), sydiguvi (14/05/2025), transitforum (15/04/2023), WJon (04/03/2023)
Vieux 11/04/2022, 19h17   #2
Aleksey-MS
Added Toyota Corolla 2009 302a4200 + Calibration Supersession Notice
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
attefco (25/04/2023), MecaTech (08/04/2025)
Vieux 29/10/2022, 12h15   #3
Aleksey-MS
The link was updated
Type de fichier : txt Toyota, Lexus Reprogramming Calibration CUW files.txt (137 octets, 15 affichages)
Vieux 31/01/2023, 10h53   #4
Aleksey-MS
Type de fichier : txt Toyota, Lexus Reprogramming Calibration CUW files.txt (137 octets, 6 affichages)
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
attefco (25/04/2023), MecaTech (08/04/2025), WJon (04/03/2023)
Vieux 31/03/2023, 16h39   #5
Aleksey-MS
Type de fichier : txt Toyota, Lexus Reprogramming Calibration CUW files.txt (137 octets, 13 affichages)
attefco (25/04/2023), MecaTech (08/04/2025), scooter (01/04/2024)
Vieux 31/03/2023, 16h58   #6
Pouvoir de réputation: 113
Hi,
Européen
---------- Post added at 14h58 ---------- Previous post was at 14h56 ----------
For Europe Cars ?
Vieux 30/04/2024, 12h27   #7
Aleksey-MS
Type de fichier : txt Toyota Lexus Reprogramming.txt (33 octets, 8 affichages)
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 07/07/2026, 15h11   #8
Aleksey-MS
Par défaut Toyota & Lexus Reprogramming CUW Files: Official ECU Calibration Updates
WHAT INSIDE:
* Toyota-Lexus TIS Calibration Files part 1-3.7z
* Toyota Tacoma CUW 30433300.zip
* Toyota Prado, Hilux, Fortuner (Diesel with problem Clogged DPF bulletin inside).zip
* Toyota LC150 AT.7z
* Toyota Corolla 2009 302a4200 + Calibration Supersession Notice.rar
1. MAIN FUNCTIONS AND COMPATIBILITY
OFFICIAL ECU FLASHING & BUG FIXING
* Engine ECU (ECM) Updates – optimizes fuel consumption, fixes sensor-related bugs, and improves emission standards.
* Transmission ECU (TCM) Updates – eliminates shifting jerks, resolves delays, and adapts transmission behavior.
* Other Systems Updates – fixes factory bugs in Climate Control, ABS/ESP, Body ECU, and Hybrid drive systems.
MODEL COVERAGE
* Compatible with any Toyota/Lexus vehicle equipped with Electronic Control Units (ECUs) that technically support OBD2 Flash Reprogramming.
* Note: This database is assembled manually, so coverage is partial. Please download and check for your specific vehicle.
2. PACK FEATURES
SAFE & TARGETED REPROGRAMMING
* Allows the ECU software to be updated without physically replacing the ECU itself.
* Flash calibration updates can only be applied to the specific vehicle/ECU combination for which they are intended.
* Built-in ECU internal security prevents programming with incorrect or incompatible files.
DESCRIPTION:
Toyota & Lexus Reprogramming / Calibration CUW files package is an essential collection of factory flash updates and Technical Service Bulletins (TSBs). It is designed to perform official field-fix procedures, eliminating known factory bugs in engine, transmission, and body control units. Using the included Calibration Update Wizard (CUW) and a compatible J2534 interface, specialists can safely update vehicle software to the latest official manufacturer versions without replacing the hardware.
Need it? Push button Thanks, PM for pass | or by email right now.
Type de fichier : txt Toyota and Lexus Reprogramming CUW files new.txt (34 octets, 0 affichages)
Vieux 09/07/2026, 13h30   #9
Aleksey-MS
Car list CUW Files
Schéma électrique Toyota & Lexus trash2013 Toyota, Lexus 4 25/01/2022 09h26
Mazda IDS v100.04 + VCM II Manager v2.3.87.8 + Calibration Files v93 mod-files.com Ford, Mazda, Land Rover, Jeep, Jaguar 0 04/03/2017 22h56
diag toyota/lexus vortex Vente, Achat, Echange 2 02/10/2015 09h10
diag Toyota/Lexus vortex Vente, Achat, Echange 0 04/04/2014 15h12
VCM DVD V2009.11 - 64 with the current calibration files MAXIMUS1000 VCMII, IDS, JLR ...etc 0 15/01/2010 16h42
Fuseau horaire GMT +1. Il est actuellement 16h41.
