Vieux 02/01/2022, 04h19   #1
MOUS25
Avatar de MOUS25
MOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud of
Par défaut Besoin off edc15c2
Salam bonjour a tous
besoin d un immo off de cet ecu edc15c2 3Plug 307 RHS merci les amis.
Type de fichier : rar 3072LHDIRHSepr__PIN_CT27.bin -.rar (509 octets, 7 affichages)
MOUS25 est déconnecté   Réponse avec citation
Vieux 02/01/2022, 07h01   #2
rosaire974
Avatar de rosaire974
Pouvoir de réputation: 22
rosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to beholdrosaire974 is a splendid one to behold
slt il faut poster le flash
rosaire974 est déconnecté   Réponse avec citation
The Following User Says Thank You to rosaire974 For This Useful Post:
MOUS25 (02/01/2022)
Vieux 02/01/2022, 07h15   #3
Ecom
Avatar de Ecom
Ecom is a name known to allEcom is a name known to allEcom is a name known to allEcom is a name known to allEcom is a name known to allEcom is a name known to all
Salam
.bin corrompu
Poste le bon fichier.
Ecom est déconnecté   Réponse avec citation
The Following User Says Thank You to Ecom For This Useful Post:
MOUS25 (02/01/2022)
Vieux 02/01/2022, 14h20   #4
boris93600
Avatar de boris93600
Pouvoir de réputation: 52
C'est un raccourci qui a été posté ...
MOUS25 (02/01/2022), yahiadiag (02/01/2022)
Vieux 02/01/2022, 15h10   #5
mehdi_idhem
Avatar de mehdi_idhem
mehdi_idhem is on a distinguished road
.bin corrompu
Mais ok fait
L'entreaide c'est bien! Mais quand ça va dans les deux sens c'est mieux!
mehdi_idhem est déconnecté   Réponse avec citation
The Following User Says Thank You to mehdi_idhem For This Useful Post:
MOUS25 (02/01/2022)
Vieux 02/01/2022, 18h57   #6
MOUS25
Avatar de MOUS25
Merci les gars projet abondonnè,ecu hs ,j ai prigrammè une clè demarre mais bridè a 3000 tours ,avec défaut problème mémoire ou configuration calculateur,
Vieux 02/01/2022, 19h04   #7
Pouvoir de réputation: 279
hello la ref de l ecu sais quoi...
Y faut récrire eeprom ok faire off proprement ..
Dernière modification par akasa67 ; 02/01/2022 à 19h24.
MOUS25 (02/01/2022), vilebrequin (08/02/2022)
Vieux 02/01/2022, 19h22   #8
mehdi_idhem
Envoyé par MOUS25 Voir le message
Mince dommage !
MOUS25 (02/01/2022)
Vieux 02/01/2022, 19h41   #9
yann3
Avatar de yann3
Pouvoir de réputation: 76
oui c'est normal si eeprom corrompu ou mal ressoudé ou encore ,mal ecrit
a verifier tout ca
http://www.armoreprog.fr
MOUS25 (02/01/2022)
Vieux 02/01/2022, 20h15   #10
MOUS25
Avatar de MOUS25
Je n ai pas fais de off j l ai simplement lu récupérer le pin avec le soft de sky j ai programmer une clè ,car au début j n arrivais pas à sortir le pin avec Autel par obd ,c est la première fois que autel n arrive pas donc j avais un doute sur l' état de l ecu ,le client préfère acheter un kit complet le client est roi lol..
The Following 2 Users Say Thank You to MOUS25 For This Useful Post:
akasa67 (02/01/2022), rosaire974 (03/01/2022)
Vieux 02/01/2022, 21h35   #11
Tof02770
Avatar de Tof02770
Serieux les amis en 2022 en cherche encor off edc15c2 ce sujet et traiter plus que 300 foix sur le site un peux recherche mon ami
ggvaniou (03/01/2022)
Vieux 02/01/2022, 21h45   #12
MOUS25
Avatar de MOUS25
Envoyé par Tof02770 Voir le message
J ai arrêtè de chercher mon ami !!!
Merci pour le message très fraternel...
Vieux 03/01/2022, 00h01   #13
Macan
Avatar de Macan
Pouvoir de réputation: 8
Macan has a spectacular aura aboutMacan has a spectacular aura aboutMacan has a spectacular aura about
Salut oublie autel sur les 307 ph1 tu ne peux rien extraire ni du bsi ni de l'ecu edc15
Macan est déconnecté   Réponse avec citation
Vieux 03/01/2022, 09h55   #14
yann3
Avatar de yann3
version VAN
DEBOUGNA67 (05/02/2022)
besoin off EDC15C2 sergyu2006 Immobilizer dumps/solutions 7 02/03/2017 17h28
besoin fap off 607 edc15c2 sergyu2006 Fichiers d'origine, carto, dump, fullbackup 3 19/10/2016 10h56
besoin dtc off psa 307 2.0 hdi 110 edc15c2 rapha Fichiers d'origine, carto, dump, fullbackup 3 18/04/2016 19h43
besoin off edc15c2 foulques Immobilizer dumps/solutions 1 08/10/2015 07h55
Besoin d'un FAP off et egr off 307 hdi EDC15C2 HURLEVENT Préparations moteur 1 17/04/2014 16h45
Fuseau horaire GMT +1. Il est actuellement 23h14.
