Vieux 03/10/2021, 19h47   #121
bassh
Avatar de bassh
bassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud of
C est vrai que ça semble à l arrêt depuis un moment.
Vieux 03/10/2021, 22h37   #122
belle-palestine
Avatar de belle-palestine
belle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant future
Salut non les gars il était occupé à remettre le site des ecu bosch compatible, il fait ça à chaque fois qu un membre en fait un.
belle-palestine est déconnecté   Réponse avec citation
The Following User Says Thank You to belle-palestine For This Useful Post:
jah83 (04/10/2021)
Vieux 16/09/2022, 19h32   #123
kmtech
Avatar de kmtech
Pouvoir de réputation: 67
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
Nouvelle update du jour rajoutant les algos suivants pour les marques du groupe PSA (Peugeot, Citroen, DS) :
- IMMO OFF BOSCH MD1CSxxx (ex MD1CS003)
- IMMO OFF BOSCH MG1
- IMMO OFF DELPHI DCM7.1
- IMMO OFF VALEO V56.12
- IMMO OFF VALEO VD56
Bonne fin de journée à tous.
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ...
Dernière modification par kmtech ; 16/09/2022 à 19h34.
kmtech est déconnecté   Réponse avec citation
The Following 18 Users Say Thank You to kmtech For This Useful Post:
2CVkatia (16/09/2022), Auto16 (08/11/2023), chafi (19/09/2022), chatgris08 (17/09/2022), CHATONDU38 (20/09/2022), DIAG.ECO.POWER (18/09/2022), DIAGSYSTEM25 (16/09/2022), dounga (13/03/2025), fils (19/09/2022), fruky (19/09/2022), j-sky (16/09/2022), mindouza (17/09/2022), nasisamy (16/09/2022), pompuy (17/09/2022), reda75 (19/09/2022), tech-auto (16/09/2022), Tristan25 (17/09/2022), yoyomartin2003 (16/09/2022)
Vieux 18/09/2022, 23h36   #124
BARY42
Avatar de BARY42
BARY42 is a glorious beacon of lightBARY42 is a glorious beacon of lightBARY42 is a glorious beacon of lightBARY42 is a glorious beacon of lightBARY42 is a glorious beacon of light
salut tout le monde quelqu'un a ester la solution md1CS003 sa fonctionne
BARY42 est déconnecté   Réponse avec citation
Vieux 19/09/2022, 15h53   #125
Pouvoir de réputation: 113
Envoyé par kmtech Voir le message
Slt Kmtech,
Sympa ta mise à jour.
Peux tu nous indiquer comment contrôler le off car au diag il reste verrouillé en adc ?
Merci :-)
duroi (19/09/2022)
Vieux 20/09/2022, 07h35   #126
kmtech
Avatar de kmtech
Slt Kmtech,
Merci :-)
Salut, merci à toi.
Pas de support technique sur le forum. Viens avec ton code client sur Skype (pseudo ath3si) et je t’expliquerais.
Cordialement
The Following 2 Users Say Thank You to kmtech For This Useful Post:
fils (20/09/2022), nimbus (20/09/2022)
Vieux 20/09/2022, 18h39   #127
kmtech
Avatar de kmtech
Bonjour à tous !
Il semble que suivant l'interface et suivant la version (ex ktag) le MCUID peut varier. Nous avons mis à jour aujourd'hui permettant un plus grand support des MCUID et des différents formats.
Si le MCUID n'est pas reconnu correctement par le logiciel le off ne fonctionnera pas ! C'est donc une étape importante et il ne faut pas y inscrire n'importe quelle valeur ou en prendre d'un autre calculateur que celui sur lequel vous intervenez.
Un MCUID est le numéro de série du TriCore soudé sur votre calculateur, donc 1 calculateur = 1 MCUID unique. En général un MCUID d'un Tricore TC29x commence par 40 et fini par plusieurs 0. Il fait toujours 32 caractères hexa (16 octets) donc à ne pas confondre avec les CHIPID qui font 16 caractères hexa (8 octets). Pour le FLEX il semble que le MCUID soit dans le nom du fichier entre deux caractères underscores ( _ ). Pour le KESS3 il est affiché dans le champ identification.
Cette mise à jour est passée à 18h20 ce jour donc je vous invite à refaire les tests pour ceux pour qui cela n'a pas fonctionné. Ce OFF est 100% fonctionnel mais est lié au MCUID donc il est indispensable que cela soit OK et en attendant d'être confrontés à tous les formats existants il faut nous contacter au support si jamais vous avez une difficulté et nous le rajouterons pour que tout soit ok !
Pour information, l'état déverrouillé (ou "après-vente") doit être présent au diag (donc vérifiable sur table). Si ce n'est pas le cas c'est un problème de MCUID donc réessayez avec cette nouvelle mise à jour ou contactez-nous et nous vous aiderons à le trouver.
Bonne fin de journée à tous !
Dernière modification par kmtech ; 20/09/2022 à 18h45.
The Following 6 Users Say Thank You to kmtech For This Useful Post:
boul27 (20/09/2022), DAVID02620 (21/09/2022), duroi (20/09/2022), nasisamy (20/09/2022), nimbus (20/09/2022), pompuy (21/09/2022)
Vieux 20/09/2022, 22h36   #128
kmtech
Avatar de kmtech
Pour ceux qui veulent voir de leurs yeux que le off md1 est Ok sur RocketDump voici une capture d’ecran de Diagbox qu’un client m’a envoyé pour confirmer.
The Following 9 Users Say Thank You to kmtech For This Useful Post:
Auto16 (13/01/2023), chafi (22/09/2022), DAVID02620 (21/09/2022), delphi38 (22/01/2026), duroi (01/01/2023), garageducentre (02/01/2023), pompuy (21/09/2022), reda75 (21/09/2022), zav_ze_best (28/09/2022)
Vieux 01/01/2023, 15h03   #129
uncleseb
Avatar de uncleseb
Pouvoir de réputation: 42
Salut ,
depuis hier , Rocketdump est out chez moi testé sur 2 pc ,
super lent a s'ouvrir a la limite du plantage et ca cherche comme si le serveur était down .
D'autre dans ce cas ?
Pas de thanks , pas d'aide - Pas de bras , pas de chocolat
The Following 3 Users Say Thank You to uncleseb For This Useful Post:
Fastdiag (01/01/2023), pompuy (03/01/2023), Quattro899 (01/01/2023)
Vieux 01/01/2023, 15h13   #130
Quattro899
Avatar de Quattro899
Pouvoir de réputation: 74
Envoyé par uncleseb Voir le message
Salut ,
salut seb idem pour moi
The Following 3 Users Say Thank You to Quattro899 For This Useful Post:
Fastdiag (01/01/2023), mindouza (02/01/2023), uncleseb (01/01/2023)
Vieux 02/01/2023, 08h30   #131
mindouza
Avatar de mindouza
mindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to all
Salut a tous
je soupçonnais le dongle au départ
n'applaudissez jamais a l'injustice humaine
mindouza est déconnecté   Réponse avec citation
Vieux 02/01/2023, 14h50   #132
uncleseb
Avatar de uncleseb
ca refonctionne a nouveau.
The Following 4 Users Say Thank You to uncleseb For This Useful Post:
Fastdiag (02/01/2023), nasisamy (03/01/2023), Quattro899 (02/01/2023)
Vieux 02/01/2023, 21h19   #133
nasisamy
Avatar de nasisamy
nasisamy is a splendid one to beholdnasisamy is a splendid one to beholdnasisamy is a splendid one to beholdnasisamy is a splendid one to beholdnasisamy is a splendid one to beholdnasisamy is a splendid one to beholdnasisamy is a splendid one to behold
salut idem et aujourd'hui tous refonctionne
nasisamy est déconnecté   Réponse avec citation
The Following User Says Thank You to nasisamy For This Useful Post:
uncleseb (03/01/2023)
Vieux 03/01/2023, 11h26   #134
repcles
Avatar de repcles
repcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to behold
SLT sa refonctonne ras
repcles est déconnecté   Réponse avec citation
Vieux 03/01/2023, 21h19   #135
zatazk
Avatar de zatazk
zatazk is just really nicezatazk is just really nicezatazk is just really nicezatazk is just really nicezatazk is just really nice
super ton soft .
toujours pas de delphi DDCR???
zatazk est déconnecté   Réponse avec citation
Nouvelle version de can clip oui/non cedmtech Renault clip, DDT2000, Nissan consult 16 19/04/2019 23h22
Exclusivité T-E : Nouvelle version FindStringsInBin v0.2 kmtech Fichiers d'origine, carto, dump, fullbackup 2 26/02/2019 14h11
Nouvelle version ATLAS HD-200 [B1.28] Electrode DVB 1 13/04/2017 22h05
nouvelle version FVDI 2015 walteck Café du forum 8 14/11/2014 13h47
Megaupload nouvelle version ! samigravano Café du forum 4 01/02/2013 22h56
Fuseau horaire GMT +1. Il est actuellement 11h52.
