Vieux 23/09/2020, 15h07   #46
gpv
Avatar de gpv
gpv is on a distinguished road
hmm attachement was reduced in size, so it is not readable anymore.
Here is a second attempt, with only the remote type options, depending on RPO number.
Type de fichier : jpg Peugeot 308 T9 - Central Door Locking.jpg (70,5 Ko, 27 affichages)
gpv est déconnecté   Réponse avec citation
Vieux 23/09/2020, 17h24   #47
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 66
Envoyé par gpv Voir le message
Hi dear friend you show different frequency 315mhz is out of Europe
In Europe it’s 433mhz
On different RPO
But it’s not the problem to turn on remote control
Some BSI need other procedure to make operating remote when you programming a new key
Vieux 23/09/2020, 20h49   #48
barthdu22
Avatar de barthdu22
Salut, est ce que le N° de serie est identique dans le BSi + pare brise+ carte grise + frappe a froid (derriere le bocal de liquide de refroidissement sur le support amortisseur)?
barthdu22 est déconnecté   Réponse avec citation
Vieux 24/09/2020, 02h59   #49
BlackWar
Avatar de BlackWar
BlackWar is an unknown quantity at this point
Envoyé par barthdu22 Voir le message
Bien sûr. Sinon, qui voudrait acheter une voiture pareil =) Elle passera jamais au contrôle technique.
---------- Post added at 02h59 ---------- Previous post was at 02h58 ----------
When i look up the remotes in Service Box i see that there are multiple systems available, see attachement. I know with old BSI from 206 around the year 2000, the BSI could work with 4 different type of remotes, but the correct type must be configured in the BSI. Else, the BSI wouldn't learn the remote (resulting in anti-jamming after a few tries).
Maybe this also applies to the 308? Can you configure a remote type?
Also, most of the times, diagbox shows a procedure to match remotes. I don't know the procedure for the 308 (T9) specifically, but did you try to put the car on ignition and then press and hold the lock or unlock button for a few seconds? (This is not a program, but synchronize action. The programming of the code should be done during configuration with diagbox)
There's no possibility to change remote key model.
I have followed Diag-box procedure to sync remote. Without success.
BlackWar est déconnecté   Réponse avec citation
Vieux 24/09/2020, 03h12   #50
BlackWar
Avatar de BlackWar
Envoyé par louay Voir le message
salut je viens de changer sur 308 2017 bsi et clés et pareil je me retrouve dans le même cas impossible de synchroniser les télécommandes. Voiture demarre et keyless fonctionne.
Programmation et codage en ligne avec Diagbox jeton.
Je me retrouve dans la même situation que toi
---------- Post added at 12:52 PM ---------- Previous post was at 12:50 PM ----------
... et pareil j'ai OUI sur "réception d'un message non identifié
Idem, il y a rien à faire ))) Tu vas rigoler, j'ai déjà changé : BSI, module ADML, lecteur des clés électroniques et les clés.
Maintenant, j'ai deux kit : BSI + module ADML + lecteur + télécommande...
Un dans la voiture et le deuxième sur la table.
Je m'amuse avec le second sur la table : effacer les eeproms, télécoder, flasher,...
Même scénario que dans la voiture.
J'ai pressentiment qu'avant de rajouter la nouvelle télécommande avec diag-box, il faut la coder spécifiquement pour le BSI donné (=sécurité).
PS. j'en ai plein les boules ))))) de ce système ))))
The Following User Says Thank You to BlackWar For This Useful Post:
louay (24/09/2020)
Vieux 24/09/2020, 04h12   #51
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Pouvoir de réputation: 44
Slt tu as regardé du côté des portières.....les serrures
Vieux 24/09/2020, 14h32   #52
BlackWar
Avatar de BlackWar
Envoyé par DIAGSYSTEM25 Voir le message
Salut, que faut-il regarder au niveau des serrures ? Merci :)
Vieux 24/09/2020, 17h43   #53
DIAGSYSTEM25
D après se que j'ai compris il y a une info la dessus chez Peugeot concernant le main libre
Vieux 29/09/2020, 00h27   #54
momo78100
Avatar de momo78100
momo78100 is a splendid one to beholdmomo78100 is a splendid one to beholdmomo78100 is a splendid one to beholdmomo78100 is a splendid one to beholdmomo78100 is a splendid one to beholdmomo78100 is a splendid one to behold
Est ce que le pin appris est celui donner par le concessionaire ? Ou tu a mis le pin de la voiture ?
Pour ma part tu dois bigo oser le verrou de colonne
n'oubliez pas le thanks !!!!!! ca fait plaisir :iagree:
momo78100 est déconnecté   Réponse avec citation
programmation telecommande peugeot 2/3 boutons Autoprogkey Outil de programmation 15 22/12/2020 18h48
Impossible de synchroniser 406 II motor programmation & synchronisation de clé 28 22/02/2018 19h20
comment synchroniser telecommande hf twingo repcles programmation & synchronisation de clé 7 21/02/2017 08h57
Diagnostic incomplet sur Peugeot 308 avec ADML Thom@s PSA Group Peugeot, Citroën 13 05/01/2017 21h57
Comment synchroniser télécommande citroen xsara ahmed_ahmed programmation & synchronisation de clé 3 30/08/2013 19h18
Fuseau horaire GMT +1. Il est actuellement 02h36.
