Vieux 05/05/2018, 23h04   #31
j'aime bien ta façon d'appréhender les choses ! c'etait pareil avec l'autre calculateur ! mode dégradé !! activé !!!
si le probleme venait d’ailleurs ?? que dit le nouveau diag ???
@ passe une bonne soirée
rotax (06/05/2018)
Vieux 05/05/2018, 23h12   #32
hatem006
Avatar de hatem006
Pouvoir de réputation: 23
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
salut, voila un off ok 100% edc15c2 0281010137. 1 broche xsara picasso 2.0hdi 90cv moteur RHY le off es okkk testé aujourdhui et la voiture tourne nikel
Type de fichier : rar immo off 5p08 edc15c2 0281010137 1plug xsara picasso 2.0 hdi teste ok.rar (398 octets, 36 affichages)
hatem006 est déconnecté   Réponse avec citation
The Following User Says Thank You to hatem006 For This Useful Post:
jo-11 (06/05/2018)
Vieux 06/05/2018, 01h29   #33
rotax
Avatar de rotax
Pouvoir de réputation: 36
rotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond repute
donne le chassis de ta 206 ca va allez plus vite... je vais te trouver le bon calculateur!!
ca sera au moins une chose de régler.
---------- Post added at 01:23 AM ---------- Previous post was at 01:20 AM ----------
je t'ai envoyer flash+eeprom edc15c2 206 2.0 hdi 90 , je t'ai précision le type calculateur etc ....
si ca va pas donne les ref direct tourne pas autour du pot..
---------- Post added at 01:29 AM ---------- Previous post was at 01:23 AM ----------
ca fait presque 3 pages et tu sais toujours pas dire si par exemple 0 281 001 866
rotax est déconnecté   Réponse avec citation
The Following User Says Thank You to rotax For This Useful Post:
jo-11 (06/05/2018)
Vieux 06/05/2018, 07h51   #34
jo-11
Avatar de jo-11
jo-11 will become famous soon enough
Bonjour, alors mon cher rotax je te remercie pour le pot. Gentil mais si tu avais bien lu tous mes post, ce que je doutes, car sinon tu ne poserais pas la question. Donc pour toi je vais le dire encore une fois (x3) unh peut plus fort JE N'AI PAS D'AUTRES INFOS, L’ÉTIQUETTE EST ABSENTE SEUL EST INSCRIT "EDC15C2". Si je doit le répéter a chaque fois je ferais un copier collé. Et tant mëme il y aurais 30 pages a mon grand regret l’étiquette ne serais pas revenue pour autant tu sais.
jo-11 est déconnecté   Réponse avec citation
Vieux 06/05/2018, 08h13   #35
jo-11
Avatar de jo-11
Pour toi rotax:
206 HDI 90.pdf et merci.
Vieux 06/05/2018, 08h23   #36
jo-11
Avatar de jo-11
Ref du 2° calculateur que j'ai pu tester qu'hier : 0 281 010 500.
Vieux 06/05/2018, 18h39   #37
rotax
Avatar de rotax
ton nouveau calculateur 0 281 010 500 est ok
http://www.bosch-automotive-catalog....26autoLoad%3D1
sinon mon message précédent il ne faut pas le prendre mal, il n'y a rien de méchant ou autre.. autrement je serai pas ici en train de t'aider.
excuse moi pour ma maladresse.
---------- Post added at 06:39 PM ---------- Previous post was at 06:33 PM ----------
j'ai oublier ref Peugeot de ton calculateur 1938R6 sans mux ref Bosch 0 281 010 767
le 0 281 010 767 remplace le 0 281 010 500.
donc c'est bon.
jo-11 (07/05/2018)
Vieux 07/05/2018, 21h56   #38
jo-11
Avatar de jo-11
Merci a toi rot
Vieux 07/05/2018, 22h21   #39
jo-11
Avatar de jo-11
Oups j'ai ma bécane qui beugue donc je disait merci a toi rotax et pour clore le débat parallèle j'ai été surpris du ton que tu as employé ou s'est moi qui me suis donné de mauvaises impressions.Ne t’inquiètes pas j'en suis nullement offusqué de mon coté me débat est clos (celui la au moins est "résolu"). Bon déjà une bonne nouvelle mais avec celui-la je suis coincé a 3000 Trs/Mn. Il me ressort a l’interrogation du pp2000 "Mauvaise affectation du calculateur" monté sur 406 S2 moteur RHZ. En code défaut hormis l'immo il me demande le capteur de pression turbo. Mince y en as pas sur mon auto. Il y as aussi un défaut de calibrage je crois j'ai un trou la, sa par contre je n'arrives pas a le calibrer , il ne serais pas verrouillé par hazard ? qu'en pense tu ?HHAAARRRGG que faire pour regler le premier problème je changerais bien le monogramme en lui octroyant du galon mais je doutes que sa solutionne mon problème. Pour l'autre calculateur j'ai fait l'immo tout marchait pas trop mal jusqu’à ce que je décide de copier la cartographie je pensait l'avoir enregistré quelque part mais elle s'est évaporé impossible de la retrouver. Donc je suis a la peche d'une carto origine de pref. Sa ref est la suivante: 0 281 010 249 toujours en EDC plug. Merci encore. Si tu as une idée pour le premier je suis pendu a mon écran.
---------- Post added at 22h21 ---------- Previous post was at 22h15 ----------
Merci pour le lien vers le site Bosch il me seras utile.
Vieux 08/05/2018, 09h50   #40
fedge
Avatar de fedge
Salut.
Voila
Type de fichier : zip Peugeot 307 2.0HDI 90HP 0281010249 359145.zip (157,6 Ko, 20 affichages)
The Following 2 Users Say Thank You to fedge For This Useful Post:
jo-11 (14/05/2018), jphp (08/05/2018)
IMMO OFF 316 cdi edc15 hgrs HexTool.Net 4 13/01/2017 17h28
Immo off edc15 p+ theseyoo Immobilizer dumps/solutions 7 07/01/2017 11h25
immo off edc15 vm+ MomoDiag35 Immobilizer dumps/solutions 5 30/11/2015 22h57
immo off sur edc15 3 prises recherche killer d'immo!! Nico Immobilizer dumps/solutions 13 27/02/2015 22h50
immo edc15 c2 obmarine Immobilizer dumps/solutions 8 05/02/2014 11h57
Fuseau horaire GMT +1. Il est actuellement 12h26.
