Vieux 25/09/2019, 21h44   #31
fractal007
Avatar de fractal007
Pouvoir de réputation: 9
fractal007 will become famous soon enoughfractal007 will become famous soon enough
Byte 0:
HEX - Chassis type
11 - Ibiza Hatch
13 - Ibiza ST
21 - Polo hatchback
41 - Fabia Hatch
51 - Polo Sedan
As you can see, there might be some options for Fabia station, Audi A1, etc. Therefore it's always good to google scans of similar cars to your own.
Byte 1:
HEX - Chassis type
01 - Fabia
02 - Polo and Ibiza
Byte 2:
HEX - Brake diameter
24 - Front 256mm disc - rear 200mm drums
28 - Front 256mm disc - rear 230mm disc
44 - Front 288mm disc - rear 200mm drums
48 - Front 288mm disc - rear 230mm disc
Byte 3:
HEX - Chassis type
DB - Fabia, Ibiza
C2 - Polo
Byte 4:
HEX - Transmission
21 - DSG
41 - Manual
83 - Manual 2.0 TDI
Byte 5:
HEX 6D + VIN digit #13
Byte 6:
HEX 00
Byte 7:
HEX B2 + VIN digit #14
Byte 8:
The inverse of Byte 0.
You'll convert the HEX value to binary, i.e. HEX 21 = BIN 00100001. Then you invert the binary value, so 00100001 becomes 10000100. Finally you convert 10000100 to HEX, making 84.
Byte 9:
HEX 25 + VIN digit + 15
Byte 10:
Inverse of byte 2 (see byte 8 for description)
Byte 11:
HEX E2 + VIN digit # 16
Byte 12:
Inverse of byte 4 (see byte 8 for description)
Byte 13:
HEX D1 + VIN digit # 17
Byte 14:
Inverse of byte 6 (see byte 8 for description)
Byte 15:
HEX - Engine type
40 - BXW, CGGB, CBZB, CGPA, CBZA, CFHA + LHD
41 - CAVE + LHD
42 - CAYA, CAYB, CAYC, CFHD + LHD
52 - CFWA + LHD
82 - CFHD + LHD
Byte 16:
bit 0 = HHC active
bit 1 = TPMS active
bit 2 = XDS (electronic virtual differential) active (works on any car!)
bit 4 = 2.0 TDI engine installed
Byte 17:
HEX 00
Keep in mind, you should always use your head when making a code, and it never hurts to cross-check with the google method. The list is probably not complete, i.e. some RHD vehicles are missing from the list.
Soon to come:
ABS8.2
ESP9.0i PQ
ESP9.0i MQB
ESC 7E0
fractal007 est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to fractal007 For This Useful Post:
DrDG (18/01/2021), matt978 (01/05/2026), midou1973 (23/09/2022), Nextrick (24/09/2022), tvk974 (01/05/2026), youcef_trik (22/11/2019), zenata (22/11/2019)
Vieux 25/09/2019, 22h45   #32
yvespapou
Avatar de yvespapou
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Launch le fait par internet
yvespapou est déconnecté   Réponse avec citation
Vieux 26/09/2019, 05h49   #33
Black gees
Avatar de Black gees
Black gees has a spectacular aura aboutBlack gees has a spectacular aura about
Peur de tout confondre, et surtout pour mieux comprendre voila ce que j'ai comme defauts
côté moteur
1 Code défaut trouvé:
6117 - Fonctionnement limité en raison de message non plausible
U1112 00 [047] - -
Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 2
Fréquence du défaut: 1
Kilométrage: 134057 km
Date: 2090.14.08
Temps: 0008
Régime moteur: 1894.75 /min
Valeur de charge normée: 50.6 %
Vitesse du véhicule: 0 km/h
Température du liquide de refroidissem.: 39 °C
Température air d'admission: 29 °C
Pression de l'air ambiant: 870 mbar
Tension borne 30: 13.892 V
Compteur de désapprentissage selon OBD: 40
Position de l'accélérateur: normalisée-Position de pédale d'accélérateur: Régulateur de vitesse: position de la commande-STATE_CRU_SWI_POS: 00000010
Tests passés: 1000 0000
et coté ABS
Adresse 03: Freins ABS (J104) Labels:. 6R0-907-37x-ESP82.clb
No. pièce Log: 6R0 907 379 AK Mat: 6R0 907 379 AF
Pièce: ESP8.2i front H05 0001
Révision: --------
Codage: 210228E3416D00B5842A14E782D200421300
No. Atelier: WSC 00788 648 00255
VCID: 071CA380B22D357ECB-8052
00778 - Transmetteur d´angle de braquage (G85)
005 - Réglage de base / adaptation inexistant ou erroné
Capture:
Etat du défaut: 01100101
Priorité du défaut: 0
Compteur de RAZ: 221
Kilométrage: 81920 km
Heure: 0
Date: 2014.02.15
Temps: 07:08:39
Capture:
Valeur hex: 0x0007
Valeur hex: 0x0002
Valeur hex: 0x1251
Valeur hex: 0x1BA1
Valeur hex: 0x00FF
Valeur hex: 0x7F7F
Valeur hex: 0x7F00
Au vue de ces defauts, mon ABS est bien codé et l'erreur 6117 n'a rien a voir avec l'ABS, cependant, j'ai essayé de faire un etalonnage mais aucun changement, j'ai aussi essayé de desactivé l'angle de braquage mais aucun changement
mon but etant d'enlever le temoin
par la même occasion j'ai essayé de voir les procedure sur rosstech pour enlever l'antipatinage mais apparament il n'y a rien sur les 6R et dans le Codage long il n'accepte pas le changement
Black gees est déconnecté   Réponse avec citation
Vieux 26/09/2019, 12h19   #34
zenata
Avatar de zenata
Pouvoir de réputation: 175
00778 - Capteur d'angle de direction (G85): signal non plausible
Causes possibles
Capteur d'angle de direction (G85) Réglage de base perdu
Capteur d'angle de direction (G85) Position d'installation incorrecte
Pas de communication entre le capteur d'angle de direction (G85) et l'électronique de freinage (J104)
les roues pointant tout droit, assurez-vous que le G85 affiche 0 ° +/- 5 °. Si une lecture de +360 ou - 360 degrés est trouvée. Retirez le volant et tournez le ressort de l'horloge 1 tour dans la direction nécessaire pour réparer.
Vieux 21/11/2019, 23h26   #35
julien34560
Avatar de julien34560
julien34560 will become famous soon enoughjulien34560 will become famous soon enough
apparement souvent si le bloc Abs n'est pas exactement le même ça peut faire se problème , du coup j'ai mis exactement le meme et le bon codage et c'est bon
julien34560 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to julien34560 For This Useful Post:
Vieux 22/11/2019, 09h22   #36
zenata
Avatar de zenata
En ligne avec launch pour codage
Avec vcds , ça passe mais il te faut le long coding
Dans tous les cas , le mieux pour pas perdre de temps
Le faire en ligne
Vieux 30/11/2019, 23h41   #37
1 6 D
Avatar de 1 6 D
1 6 D is an unknown quantity at this point
If you have problems I can make coding for ABS/ESP 6R0/1K0 pumps with long coding.
---------- Post added at 23h41 ---------- Previous post was at 23h38 ----------
Envoyé par fractal007 Voir le message
Byte 0:
HEX - Chassis type
11 - Ibiza Hatch
13 - Ibiza ST
21 - Polo hatchback
41 - Fabia Hatch
51 - Polo Sedan
Byte 1:
HEX - Chassis type
01 - Fabia
02 - Polo and Ibiza
Byte 2:
Byte 3:
HEX - Chassis type
DB - Fabia, Ibiza
C2 - Polo
Byte 4:
HEX - Transmission
21 - DSG
41 - Manual
83 - Manual 2.0 TDI
Byte 5:
Byte 6:
HEX 00
Byte 7:
Byte 8:
Byte 9:
Byte 10:
Byte 11:
Byte 12:
Byte 13:
Byte 14:
Byte 15:
HEX - Engine type
41 - CAVE + LHD
52 - CFWA + LHD
82 - CFHD + LHD
Byte 16:
bit 0 = HHC active
bit 1 = TPMS active
Byte 17:
HEX 00
Soon to come:
ABS8.2
ESP9.0i PQ
ESP9.0i MQB
ESC 7E0
Byte 1 and Byte 3 are 7 and 8 VIN mark
1 6 D est déconnecté   Réponse avec citation
Vieux 27/01/2020, 20h55   #38
hams
Avatar de hams
hams is an unknown quantity at this point
SALUT , JE DETER UN VIEUX SUJET , TOUT DABORD MERCI A ZENATA CAR J'ai pue generer mon long conding abs mais seulement je mexplique
J'utilise VCDS et je n'arrive pas a recoder mon abs j'ai le message erreur 31
CODAGE REJETÉ
ERREUR 31
DEMANDE HORS DE PORTÉE
Quelqu'un pourrait me venir en aide svp merci
hams est déconnecté   Réponse avec citation
Vieux 27/01/2020, 20h57   #39
zouaoui mohamed
Avatar de zouaoui mohamed
Pouvoir de réputation: 23
zouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to behold
slt amis poste tes informations pour t'aider
zouaoui mohamed est déconnecté   Réponse avec citation
Vieux 27/01/2020, 21h03   #40
hams
Avatar de hams
YES !!!
Address 03: ABS Brakes
Control Module Part Number: 6R0 907 379 AS
Component and/or Version: ESP9.0i front H02 0002
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 01383
VCID: 0F2C8BA0D65D6D3E03-805A
Advanced Identification/FAZIT
Serial number: --------------
Identification: BPA-085
Date: 10.05.13
Manufacturer number: 0060
Test stand number: 4316
Flash Status
Programming Attempts(application): 1/0
Flash Date: 00.01.01
Misc.
Hardware number: 6R0 907 379 AS
Workshop System Name: J104
ASAM Dataset: EV_Brake1ESP90iBOSCH
ASAM Dataset Revision: 003020
VCDS Info:
Labels: 6R0-907-37x-ESP90.clb
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
Vieux 27/01/2020, 21h06   #41
zouaoui mohamed
ton n vin svp
The Following User Says Thank You to zouaoui mohamed For This Useful Post:
Vieux 27/01/2020, 21h07   #42
hams
Avatar de hams
Wvwzzz6rzey012995
Vieux 27/01/2020, 21h12   #43
zouaoui mohamed
voila ton codage amis rend la réponse
21DD2485212400C2841D2472845600400904
hams (27/01/2020)
Vieux 27/01/2020, 21h44   #44
hams
Avatar de hams
MERCI
Comment a tu générer le code stp ?
moi j'avais 21DD2C85212400C2841D3472845600401401 avec esp calculator
Vieux 27/01/2020, 23h09   #45
hams
Avatar de hams
Merci nickel !! Comment tu a pue generer le bon code svp moi javais
21dd2c85212400c2841d3472845600401401
avec esp calculator
The Following User Says Thank You to hams For This Useful Post:
youcef_trik (28/01/2020)
codage ecu calixo22 Airbag 2 14/07/2017 14h34
Codage abs Jean23 ABS, ESP, DSC 2 05/07/2017 14h42
codage abs,esp,asr christ ABS, ESP, DSC 0 06/12/2015 09h27
codage injecteur polo 1.6 tdi nas33 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 5 30/11/2015 07h49
Codage ABS Polo 2011 newfree VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 10 11/02/2015 18h57
Fuseau horaire GMT +1. Il est actuellement 19h10.
