Précédent   Tlemcen Car electronics > Categorie principale > Tutoriels
Tutoriels Tutoriels pour vous aider.
Vieux 16/10/2016, 18h34   #31
DDJAM
Avatar de DDJAM
DDJAM is on a distinguished road
Envoyé par Criptic Voir le message
Antenna will work after a simple operation. Remove the capacitors 1, 2, 3, 5. Change the capacitor 4 to 10 nF. Change the resistor 5 to 15 kOhm.
hi,is this safe for other operations of carprog? ( i mean reading eeprom or mcu or doing dashboard...does not been altered by the modification of the hw?)regards
DDJAM est déconnecté   Réponse avec citation
Vieux 19/10/2016, 05h20   #32
mara07
Avatar de mara07
mara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond reputemara07 has a reputation beyond repute
Envoyé par DDJAM Voir le message
I tested that method too but after we have the problem with reading the eeprom
skype: obd.planet; telegram: @obdturning;
l'assistance: https://t.me/thinkdiag
mara07 est déconnecté   Réponse avec citation
Vieux 19/10/2016, 23h15   #33
mara07
Avatar de mara07
Today I tested again and now everything is fine. The capacitors must be chosen correctly
Vieux 30/12/2017, 19h29   #34
nacerweb
Avatar de nacerweb
nacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud of
bonsoir j ai voulu flasher mon carprog et j ai un message d' erreur avec le jlink quelqu'un aurai t ' il une idee?
Type de fichier : jpg IMG_0281.jpg (97,5 Ko, 54 affichages)
Type de fichier : jpg IMG_0282.jpg (91,3 Ko, 50 affichages)
nacerweb est déconnecté   Réponse avec citation
Vieux 30/12/2017, 20h10   #35
REDZONE31
Avatar de REDZONE31
Pouvoir de réputation: 82
SLM Nacer essayer de trouver Une autre version de jlink si je me rappelle la plus stable 4.26 ou 4.85 quelques choses comme ça essai frère
Envoyé de mon SLIDE en utilisant Tapatalk
The Following User Says Thank You to REDZONE31 For This Useful Post:
nacerweb (30/12/2017)
Vieux 30/12/2017, 21h14   #36
nacerweb
Avatar de nacerweb
merci mon ami amor89 probleme resolu avec la version jlink 4.24c .
The Following 2 Users Say Thank You to nacerweb For This Useful Post:
ecutech (30/12/2017), REDZONE31 (30/12/2017)
Vieux 30/12/2017, 21h21   #37
REDZONE31
Avatar de REDZONE31
Je suis content pour toi que l'aide été positif donc en peut dire que le sujet et clos
Vieux 29/01/2018, 05h33   #38
SIMSIMAFIA
Avatar de SIMSIMAFIA
SIMSIMAFIA is on a distinguished road
bonjour et merci
j'ai le model 9.31
il na jamais fonction puis c'est bloqué
La manipulation est compatible a mon appareil ?
Ou trouver le ficher 9.31 a injecter ?
Possible d'injecter le 8.21 ou 10.05 ?
Il me manque un composent vu sur la (ST MRC C913 LF33) une protection qui est sur votre model.
---------- Post added at 20h33 ---------- Previous post was at 20h30 ----------
SIMSIMAFIA est déconnecté   Réponse avec citation
Vieux 24/06/2020, 18h34   #39
SIMSIMAFIA
Envoyé par SIMSIMAFIA Voir le message
bonjour et merci
j'ai le model 9.31
problème résolut avec la 10.93 FREE
Procedure reparation edc16u1 jah83 Réparation & Programmation 46 04/05/2025 12h38
Procedure immo off de A à Z thiam58 Immobilizer dumps/solutions 20 15/05/2022 22h44
BMW Key Initialization Procedure VAMPERNIGHT programmation & synchronisation de clé 0 09/08/2012 20h02
reflash vagcom dichar VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 0 11/05/2011 22h04
Fuseau horaire GMT +1. Il est actuellement 05h19.
