Vieux 09/10/2014, 01h22   #16
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
hi morito
first of all make ur avatar and read the rules
for the dump post more info about the dae ref.
and we will help
regatds
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
Vieux 09/10/2014, 01h25   #17
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 51
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
Envoyé par morito Voir le message
hi
can clear this dump clio 3
how cost??
regards
Bonsoir, voici ton vierge.
Je t'envoie le mot de passe après la mise à jour de votre profil, votre inscription depuis 2009
Good evening, this is your virgin.
I send you the password after up****** your profile, your registration since 2009
Type de fichier : rar colonne-vierge clio 3.bin.rar (174 octets, 32 affichages)
amrougafsa est déconnecté   Réponse avec citation
Vieux 31/12/2014, 18h01   #18
Manu08f
Banned
Avatar de Manu08f
Manu08f is an unknown quantity at this point
Bonjour, est-il possible de rendre sans erreur mon dump de direction assitée sur scenic II 1.9dci de 2004. Défaut canclip DEF055 : Mémoire EEPROM = erreur 30. J'ai essayé d'injecter un dump d'une autre colonne mais problème avec VIN, que je ne sais pas modifier. Un grand Merci !!
Type de fichier : bin 24c16origine.bin (2,0 Ko, 8 affichages)
Manu08f est déconnecté   Réponse avec citation
Vieux 06/01/2015, 15h08   #19
Diagsysteme
Avatar de Diagsysteme
Diagsysteme has a spectacular aura aboutDiagsysteme has a spectacular aura aboutDiagsysteme has a spectacular aura about
Par défaut Viginiser dump dae clio3
Bonjours et bonne annee a tous
voila j ai recupere une colonne d ocasion
ref 8200294978
ya t il qq por virginiser le dump de 24lc16
merci cordialement
Type de fichier : bin DUMPORI24LC16.bin (2,0 Ko, 16 affichages)
Diagsysteme est déconnecté   Réponse avec citation
The Following User Says Thank You to Diagsysteme For This Useful Post:
sams49 (07/07/2018)
Vieux 06/01/2015, 16h04   #20
Nizar-maoukil
Par défaut dae vierge
voici ton dump vierge
pass dans t'as boite
regards
Type de fichier : rar 24lc16 8200 294 976+978 vergin dump okk.rar (103 octets, 53 affichages)
regards
The Following 2 Users Say Thank You to Nizar-maoukil For This Useful Post:
Diagsysteme (10/01/2015), samb4064 (25/02/2015)
Vieux 10/01/2015, 18h58   #21
Diagsysteme
Par défaut dae clio3
merci a Nizar-maoukil ton dump vierge il marce nike
apres avoir entré le vin callibrage angle volant ensuite codage type moteur et dimention des roues avec la clip
Nizar-maoukil (10/01/2015)
Vieux 25/02/2015, 13h36   #22
ryosaeba
Avatar de ryosaeba
Pouvoir de réputation: 26
slt j'ai un soucis avec une dae de modus elle a perdu le code antidem donc pas de demarreur si je mets un dump vierge je peux la recoder avec quoi ? car dans la clip j'ai pas vu la fonction pour rentrer le code antidem
Vieux 25/02/2015, 13h44   #23
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
Envoyé par ryosaeba Voir le message
pas besoin de codage antidem.
il te faut metre vin+ calibrage angle volant
The Following 2 Users Say Thank You to S-keys For This Useful Post:
ryosaeba (25/02/2015), samb4064 (25/02/2015)
Vieux 25/02/2015, 16h31   #24
ryosaeba
Avatar de ryosaeba
ok merci sinon quelqu'un a t'il un dump que je peux mettre ? ma ref est : 8200826807 thks
sams49 (07/07/2018)
Vieux 01/04/2016, 15h52   #25
profrenault
Avatar de profrenault
profrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant future
Bonjour a tous
Fichiers attachés non disponible
slt quelqu’un peut les poster
merci d'avance
profrenault est déconnecté   Réponse avec citation
Vieux 01/04/2016, 16h00   #26
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Envoyé par profrenault Voir le message
Bonjour a tous
merci d'avance
Salam
Pass dans ta boite
Type de fichier : rar 8200294976-8200294978--A VIRGIN.rar (1,0 Ko, 28 affichages)
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to tarik_electronic For This Useful Post:
سعدان (17/06/2019), Afortunao (11/11/2019), satellito (14/03/2021)
Vieux 03/04/2016, 21h34   #27
profrenault
BONJOUR
ça marche 100%
THANKS
Vieux 03/04/2016, 23h00   #28
tarik_electronic
BONJOUR
ça marche 100%
THANKS
Merci pour le roteur Content pour toi.
Vieux 11/06/2016, 17h10   #29
seat130
Avatar de seat130
seat130 is a jewel in the roughseat130 is a jewel in the roughseat130 is a jewel in the rough
Par défaut vierge DAE clio 3
Salut quelqu'un pourrais me faire un vierge svp merci
http://www.tlemcen-electronic.com/fo...ad.php?t=55046
seat130 est déconnecté   Réponse avec citation
Vieux 05/07/2018, 09h28   #30
batucada
Avatar de batucada
batucada is an unknown quantity at this point
salut avec quoi je peux extraire le dump sans démonter en passant par obd ? merci
batucada est déconnecté   Réponse avec citation
Besoin de dump vierge sawadogo2 Toyota, Lexus 1 08/09/2016 22h57
DAE CLIO 3 24C16 coté difficile besoin aide rosco2012 Immobilizer dumps/solutions 3 19/05/2013 17h38
j'ai besoin de dump vierge PIC16F84 Immobilizer dumps/solutions 1 21/04/2013 09h20
besoin dump vierge 406 hdi nhsdany Immobilizer dumps/solutions 3 04/03/2013 16h01
besoin dump vierge uch esp4 capalti Immobilizer dumps/solutions 1 26/06/2012 13h36
Fuseau horaire GMT +1. Il est actuellement 21h27.
