Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Logiciel & autres documentations général
Vieux 24/12/2012, 19h16   #1
TAGRART
Avatar de TAGRART
TAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud of
Par défaut TecDoc 4.2012 Torrent
This is full version, Just run setup.exe and that's all
The TecDoc Catalog (4Q/2012) is a flexible information systems, which allows you several personal settings to ease your daily work. TecDoc supplies the free vehicle spare parts market with current and comprehensive data for identifying and ordering parts – for both, PC as well as CV – directly from the databases of the cooperating automotive aftermarket manufacturers in a standardised catalogue form. You are only a few clicks away from the right part! Accurate identification of the right spare part! Quick customer service thanks to reliable part identification!
TecDoc Catalog is an electronic parts catalogues from standardised data records original data of parts manufacturers on DVD
* more than 2,892,000 articles
* over 1,500,000 illustrations
* more than 45,000 PC types
* 36,000 real existing CV types
* with technical additional information
* updated every 3 months
* multilanguage: 23 languages
The Information System TecDoc is the information source for the vehicle repair market with the original data of the parts manufacturers. Founded in 1994 by companies of the automotive aftermarket industry and the German Association for Spare parts (GVA), TecDoc Informations System GmbH has established itself as the leading supplier of electronic spare parts information on the European market.
Data search can be filtered by the following criteria (from the TecDoc manual):
1. General:
- Engine Code: the engine code
- Engine Type: then engine type
2. by Model Year (from/to):
- the engine was/is constructed during this period
- Engine Number: the engine number as defined by TecDoc
3. by Technical Data:
- Output in kW: engine output in kW
- Output in HP: engine output in HP
- Capacity (technical): engine capacity in technical terms
- Cylinder: number of cylinders
- Valves: number of valves
- Torque in Nm: the maximum torque
- Compression: the engine compression
- Bore: engine cylinder bore
- Stroke: piston stroke of the engine
- Main Bearings: the number of crankshaft main bearings
- Engine Block Design: the engine block design, i.e. straight or V
- Fuel Type: the required fuel type
- Charging: the type of charging, i.e. turbo- or supercharger
- Cylinder Head Design: the cylinder head design, i.e. OHC or OHV
- Engine Control: the type of engine control, i.e. timing belt or chain
- Valve Control: the type of valve control
- Cooling Type: the type of engine cooling, i.e. water or air.
Liens torrent par MP
TAGRART est déconnecté   Réponse avec citation
The Following 12 Users Say Thank You to TAGRART For This Useful Post:
Albi (07/04/2013), arnaud4211 (27/01/2013), autodiagauto (27/12/2012), Breizhelec (27/12/2012), mesrine_29 (16/01/2013), mounirflash (25/12/2012), natouss225 (27/12/2012), neocol (13/03/2013), newfree (27/12/2012), nyonsais (25/01/2013), prodiag (25/12/2012), rabahclim (31/12/2012)
Vieux 27/12/2012, 16h40   #2
autodiagauto
Avatar de autodiagauto
Pouvoir de réputation: 43
autodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond repute
Bonne fête
français ou pas
autodiagauto est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to autodiagauto For This Useful Post:
natouss225 (27/12/2012), nyonsais (25/01/2013)
Vieux 27/12/2012, 23h58   #3
newfree
Avatar de newfree
je veux le lien svp ..
Never too old to learn ? There is always a way even if there is non..
do not forget THANKS button.
Vieux 14/01/2013, 21h18   #4
Ayoub_b
Avatar de Ayoub_b
Ayoub_b is an unknown quantity at this point
Merci.
je veux le lien SVP
Ayoub_b est déconnecté   Réponse avec citation
Vieux 16/01/2013, 13h26   #5
mesrine_29
Avatar de mesrine_29
mesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant futuremesrine_29 has a brilliant future
[QUOTE=autodiagauto;93034]Bonne fête
français ou pas
merci[/QUOTE
C'est indiqué dans la description du logiciel du post MULTILANGUES.
Bonne année.
mesrine_29 est déconnecté   Réponse avec citation
Vieux 24/01/2013, 23h09   #6
dixneuf57
Avatar de dixneuf57
dixneuf57 is on a distinguished road
Merci.
je veux le lien SVP
dixneuf57 est déconnecté   Réponse avec citation
Vieux 25/01/2013, 07h07   #7
nyonsais
Avatar de nyonsais
nyonsais is a splendid one to beholdnyonsais is a splendid one to beholdnyonsais is a splendid one to beholdnyonsais is a splendid one to beholdnyonsais is a splendid one to beholdnyonsais is a splendid one to beholdnyonsais is a splendid one to behold
merci si tu peux faire suivre le lien.
nyonsais est déconnecté   Réponse avec citation
Vieux 25/01/2013, 07h11   #8
nyonsais
Avatar de nyonsais
merci si tu peux me passer le lien
Vieux 06/02/2013, 12h12   #9
nyonsais
Avatar de nyonsais
bonjour,
j'ai installé TecDoc 4-2012 au lancement il me dit :
application expired ( # 8500)
que faire?
Vieux 06/02/2013, 13h37   #10
TAGRART
Avatar de TAGRART
Personnellement je ne l'ai pas essayé car ma connexion internet ne me permet pas de télécharger un soft aussi volumineux mais essaye de désinstaller avec "total unistaller" et réinstalle de nouveau
Vieux 07/04/2013, 15h29   #11
Albi
Avatar de Albi
Albi is an unknown quantity at this point
Thumbs up
Salut peux tu me donner le lien d'avance merci
cordialement
Albi est déconnecté   Réponse avec citation
Citroen service box 5.2012 TORRENT Scanworld2020 PSA Group Peugeot, Citroën 0 23/12/2012 19h00
TecDoc 2Q 2012 Mecatec Logiciel & autres documentations général 1 06/09/2012 12h10
la nouvelle version du tecdoc 3Q.2012 Mecatec Logiciel & autres documentations général 3 03/08/2012 20h54
Fuseau horaire GMT +1. Il est actuellement 19h18.
