Vieux 14/08/2009, 19h26   #16
t77
Avatar de t77
t77 is an unknown quantity at this point
OK may be you need only diagnosis by Lexia/Proxia and make telecoding.Do you have this interface? If not you will problem ,becouse even if you will have a good dumps ,that you must conduct telecoding.Try first diagnosis BSI
t77 est déconnecté   Réponse avec citation
Vieux 14/08/2009, 21h10   #17
msv81
Avatar de msv81
msv81 is an unknown quantity at this point
I've already diagnosed BSI. There are no keys there. BSI is locked and ECU is blocked too. I need good pair of dumps or my fixed dumps. I think I need synchronized dumps (ecu+bsi) which are suitable to each other. Is there any other way to fix such problem?
msv81 est déconnecté   Réponse avec citation
Vieux 15/08/2009, 00h29   #18
Mrpromega
Avatar de Mrpromega
Hi
Your BSI remains emptied my friend, have no fear, you've just to set the keys on the BSI with the appropriate Personal Identification Number of the car to left the immobilizer ok, then you've to activate the locking options, windows ... etc
Best Regards !
Vieux 27/08/2009, 15h45   #19
msv81
Avatar de msv81
Sorry for delay. BSI was successfully restored, but the problem is deeper than I've thought. There are some serious errors in motor block flash which I can't delete.
Additional info:
SIEMENS SID 801
5WS40030B-T
/05653/226454082/02280
Firmware version SW9646449280
Flash version HW9644302380
Can somebody help me with error cleaning? Current firmware is in attachment.
Type de fichier : rar STM29F400BB.rar (112,9 Ko, 25 affichages)
Vieux 28/08/2009, 00h24   #20
Mrpromega
Avatar de Mrpromega
Hi
To remove the doubt that the immobilizer prevents your car to start, why not squarely remove the immo from ur ECU "Immooff" and try here to start the engine, after you see other problems. & remember to put everything after in order...
this is what you need, it will be in degraded mode: Less than 3000Rn/Min
Best regrads !
Type de fichier : rar SIEMENS.rar (131,2 Ko, 14 affichages)
The Following User Says Thank You to Mrpromega For This Useful Post:
GUILLE (02/11/2013)
Vieux 28/08/2009, 08h28   #21
msv81
Avatar de msv81
Thank you very much! I'll try it and write about the result.
Vieux 28/08/2009, 22h37   #22
msv81
Avatar de msv81
Mrpromega, Thanks for you help. Firmware is suitable, but problem was not solved. After flash reprogramming and trying to start engine PPS shows P0200 Injector Circuit Malfunction error and engine does NOT start. This error can't be cleared via PPS. Can this problem be solved without ECU replacement ?
The Following User Says Thank You to msv81 For This Useful Post:
Mrpromega (30/08/2009)
Vieux 30/08/2009, 17h58   #23
Mrpromega
Avatar de Mrpromega
Hi !!
Now, ur problem seems clearer than it was !!!
U've 1 on these 3 causes :
Injector - Wiring or ECU
Check all of them & the prb'll solv
Ecu delphi virgin file Amine-TE Immobilizer dumps/solutions 17 25/03/2015 12h19
Please virgin BSI file for 206 peppery Immobilizer dumps/solutions 1 30/05/2009 20h10
Fuseau horaire GMT +1. Il est actuellement 12h37.
