Vieux 16/01/2022, 13h30   #1
karimus
Avatar de karimus
karimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud of
Par défaut RTA Citroen C1 édition 2008
Bonjour les amis,
Je vous propose la revue technique de la Citroen C1 édition 2008.
L'accès est sans mais le lien sera communiqué à ceux qui seront intéressés et la règle est simple :
1 Thanks = communication du lien
Bonne journée.
Salutations.
le savoir se cultive par le partage
karimus est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to karimus For This Useful Post:
Baldman (16/01/2022), boris93600 (16/01/2022), Fastdiag (16/01/2022), Med1387 (16/01/2022), njeu85 (10/10/2023), toze60 (17/01/2022), transitforum (17/01/2022), uncleseb (10/10/2023), yayapap (06/03/2024), youky (18/01/2022)
Vieux 16/01/2022, 14h23   #2
karimus
Avatar de karimus
Bonjour boris93600,
C'est dans ta boite.
Salutations.
Vieux 16/01/2022, 14h46   #3
karimus
Avatar de karimus
Bonjour Fastdiag,
Slts.
The Following User Says Thank You to karimus For This Useful Post:
Vieux 16/01/2022, 14h52   #4
Fastdiag
Avatar de Fastdiag
Fastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond repute
Merci pour le partage.
Cordialement
Il ne faut pas perdre son temps à avancer des arguments de bonne foi face à des gens de mauvaise foi
Fastdiag est déconnecté   Réponse avec citation
The Following User Says Thank You to Fastdiag For This Useful Post:
karimus (16/01/2022)
Vieux 16/01/2022, 14h54   #5
karimus
Avatar de karimus
Avec plaisir !
Vieux 17/01/2022, 10h03   #6
karimus
Avatar de karimus
Bonjour Baldman,
Salutations.
Baldman (17/01/2022)
Vieux 17/01/2022, 11h10   #7
karimus
Avatar de karimus
Bonjour toze60 & transitforum,
c'est dans vos boites respectives.
Slts.
toze60 (17/01/2022)
Vieux 18/01/2022, 10h23   #8
karimus
Avatar de karimus
Bonjour youky,
Salutations.
Vieux 10/10/2023, 10h40   #9
njeu85
Avatar de njeu85
njeu85 is an unknown quantity at this point
@karimus merci pour le partage.
Pourrais-je avoir le document svp ?
njeu85 est déconnecté   Réponse avec citation
Vieux 10/10/2023, 10h53   #10
karimus
Avatar de karimus
Envoyé par njeu85 Voir le message
Bonjour njeu85,
Faudrait te conformer déjà au point 4 et ensuite au point 6 du lien suivant :
https://www.tlemcen-electronic.com/f...thread.php?t=2
Salutations.
njeu85 (10/10/2023)
Vieux 10/10/2023, 11h04   #11
njeu85
Avatar de njeu85
J'ai bien rempli tou mon profil et fait ma présentation.
Par contre malheureusement pour moi je suis débutant et donc le point 1...
1 - Nous acceptons les membres ayant une certaine expérience dans le domaine, les membres débutants niveau 0 ne seront pas acceptés dans notre communauté ou ils seront interdits.
Bien que je soit bon bricoleur je ne suis pas mécanicien
Pour le point 6
6 - Concernant les Mots de Passes :
- Ne demandez pas de mots de passe sur le thread/post/forum (SEULEMENT PAR MESSAGE PRIVÉ)
- Il est interdit de transmettre un mot de passe que l'on vous a confié, sans le consentement de l'auteur du post, sous peine d’exclusion immédiate du forum.
Je suis évidement d'accord et je ne demande à personne de mot de passe et ne transmettrai rien à personne non plus
Merci de votre aide.
Vieux 10/10/2023, 11h33   #12
karimus
Avatar de karimus
Très bien ! Alors afin d te conformer au point 6 tu devrais me faire la demande du par MP (message privé), j'attends ton message.
Salutations.
njeu85 (10/10/2023)
Vieux 10/10/2023, 13h00   #13
njeu85
Avatar de njeu85
@karimus merci
The Following User Says Thank You to njeu85 For This Useful Post:
karimus (10/10/2023)
Vieux 10/10/2023, 13h10   #14
karimus
Avatar de karimus
@karimus merci
Je t'en prie.
Salutations.
pin code citroen c4 2008 soufxp Transponder, code pin 10 26/07/2017 02h12
Citroen Lexia 347.19 + Citroen C5 2001-2008 Multilingual TAGRART LEXIA, PP2000, DiagBox 0 16/11/2012 17h48
remettre sur 0 bsi citroen berlingo 2008 Amine-TE Tableau de bord (Dashboard) 13 22/05/2012 15h27
Citroën Service Box 08-2008 cedmar PSA Group Peugeot, Citroën 9 04/11/2009 12h21
Fuseau horaire GMT +1. Il est actuellement 02h45.
