Vieux 11/02/2020, 16h38   #1
hichem iphon
Avatar de hichem iphon
hichem iphon is on a distinguished road
Par défaut codage abs seat len 2009
bns mes amis j besoin de long codage abs de seat leon 2009 2.0 tdi
abs 1K0 907 379 BK
ESP MK60EC1
VIN VSSZZZ1PZ9R047441
et merci d avence
---------- Post added at 06:38 PM ---------- Previous post was at 06:36 PM ----------
fuule scan
Tuesday,11,February,2020,1655:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.0.2
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ1PZ9R047441 License Plate:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ9R047441 Mileage: 266130km-165365miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 SF HW: 03G 906 021 AN
Component: R4 2,0L EDC G200SG 1454
Revision: --H08--- Serial number: SEX7Z0I031R059
Coding: 0050072
Shop #: WSC 80093 222 69422
VCID: 75E157D41CC13EE7B2-8020
3 Faults Found:
012545 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 1628
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 11101110
Torque: 0.0 Nm
Torque: 351.4 Nm
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 1631
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 11101110
Torque: 0.0 Nm
Torque: 351.4 Nm
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Bin. Bits: 0 00 0
Readiness: 1 2 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 35110 377 08192
VCID: 7CF742F0FFEB6FAFCD-8028
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 0
Count: 20992
Count: 195
Count: 42240
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 279
Count: 42240
Count: 0
Count: 256
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 295
Count: 42240
Count: 0
Count: 256
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 28672
Count: 270
Count: 42240
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D51BFB4B41136270A-8078
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006026492
Coding: 81880F2F00041000431D00000000000000017F075C40000000 0000000000
Shop #: WSC 06402 785 00200
VCID: 3365A9CC523560D75C-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 130109 022 0601
Coding: 00056208
Shop #: WSC 06402
3 Faults Found:
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 G HW: 1K0 919 475 G
Component: PARKHILFE 005 1506
Revision: 00005000 Serial number: 0 263 004 301
Coding: 000001
Shop #: WSC 04941 000 00000
VCID: 366390D8814775FF7B-8062
No fault code found.
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A02 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0L42QH
Coding: 0012338
VCID: 3B7581EC7A65A89784-806E
Subsystem 1 - Serial number: 6333FTS613000069
Subsystem 2 - Serial number: 6343FTS646360069
Subsystem 3 - Serial number: 6353ETS6973PU5KR
Subsystem 4 - Serial number: 6363ETS63DTDV5KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
5 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 13
Reset counter: 211
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:42
01224 - Control Module Does Not Match Vehicle
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
00588 - Airbag Igniter; Driver Side (N95)
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
01281 - Airbag; Drivers Side; Disabled
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:44
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 855 0111
Coding: 0000134
VCID: 7AFB44E835DF519FDF-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 827 H
Component: KOMBIINSTRUMENT VO3 0952
Coding: 0002101
VCID: 356197D45C417EE772-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C0102F3
Coding: 01A07F06000202000202
VCID: 377D9DDC464D8CF760-8062
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 171
Mileage: 266136 km
Time Indication: 0
Date: 2000.00.00
Time: 12:58:48
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0952
Shop #: WSC 00137 211 56823
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000518388917
Coding: 0004272
VCID: 408FF6001383CB4FD1-8014
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
1 Fault Found:
00573 - Steering Torque Sensor (G269)
008 - Implausible Signal
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F7F06850560084F01207C80
VCID: 0305390C421510578C-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000884288906
Coding: 0004272
VCID: 4189F3041889C247DE-8014
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040424
VCID: 2B55B1AC8A05381714-807E
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003603091
Coding: 0000144
VCID: 74E76AD017BB27EF85-8020
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003730933
Coding: 0000144
End-------------------------(Elapsed Time: 01:50)--------------------------
hichem iphon est déconnecté   Réponse avec citation
Vieux 12/02/2020, 09h58   #2
vwseb
Avatar de vwseb
Déjà pourquoi es-tu dans ce cas ? As tu remplacé le boîtier?
Pour le coding y'a pas le longcoding helper dans VCDS ? Pour les autres défaut il faut faire les manips suivantes:
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
[Close Controller, Go Back - 06]
Note:
If Adjustment Not Possible is displayed:
The On/Off/Next button was used and the procedure will need to be repeated WITHOUT clicking it.
The G85 live values were not within the +/-1.5 °specification. Repeating the procedure within specifications should resolve it.
The Steering wheel should be turned to full right lock stop and to full left lock stop and centered again followed by repeating the procedure.
The 16-Steerign Wheel control module and 44-Steering Assist control module (when applicable) Coding and Adaptation configurations should be checked to rule out a conflict.
After successful basic setting, the Steering Limit Stop needs to be adapted too.
Prerequisites:
[Select]
Group 004
[Go!]
Check field 2, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Do it!]
Group 063
[Go!]
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 004
[Go!]
[Done, Go Back]
Prerequisites:
[Select]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Do it!]
Group 066
[Go!]
[Done, Go Back]
Group 005
[Go!]
Check field 1, the value has to be between -3.8 and +3.8 bar.
[Done, Go Back]
vwseb est connecté maintenant   Réponse avec citation
Vieux 12/02/2020, 10h31   #3
hichem iphon
Envoyé par vwseb Voir le message
Basic Setting
Prerequisites:
Start the vehicle.
[Select]
Group 004
[Go!]
[Done, Go Back]
[Do it!]
Group 060
[Go!]
[Done, Go Back]
Note:
Prerequisites:
[Select]
Group 004
[Go!]
[Done, Go Back]
[Do it!]
Group 063
[Go!]
[Done, Go Back]
Group 004
[Go!]
[Done, Go Back]
Prerequisites:
[Select]
Group 005
[Go!]
[Done, Go Back]
[Do it!]
Group 066
[Go!]
[Done, Go Back]
Group 005
[Go!]
[Done, Go Back]
merci pour la rep
loperation et fait avec fvdi avec succ
Vieux 12/02/2020, 11h13   #4
1 6 D
Avatar de 1 6 D
1 6 D is an unknown quantity at this point
Try as basic coding:
113B601209260001990F06E8901A0042300000
1 6 D est déconnecté   Réponse avec citation
Vieux 12/02/2020, 14h21   #5
Nour01100
Avatar de Nour01100
Nour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to all
Slt tu as pu faire le codage ??
Nour01100 est déconnecté   Réponse avec citation
Vieux 05/04/2020, 17h44   #6
salim-diad13
Avatar de salim-diad13
salim-diad13 is on a distinguished road
avec diagnostique bosch kts il le code facile
salim-diad13 est déconnecté   Réponse avec citation
Codage abs seat ibiza BAZBOZ ABS, ESP, DSC 11 22/02/2017 16h30
seat leon 1.9 tdi 2009 dpf off egr off manueldord Chiptuning 5 20/12/2015 18h58
codage long abs seat leon 2009 star31 ABS, ESP, DSC 4 12/07/2015 20h55
seat ibiza 2009 hugopinho Airbag 1 27/09/2011 21h32
codage ABS passat(C3) 2009!!!!! Moh VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 1 12/12/2009 18h05
Fuseau horaire GMT +1. Il est actuellement 21h24.
