Vieux 04/10/2019, 15h57   #1
mehdiloujdi
Avatar de mehdiloujdi
mehdiloujdi will become famous soon enoughmehdiloujdi will become famous soon enough
Par défaut Activation rétroviseur rabattable tiguan 2014
Bonjour les amis quelqu'un aurait-il la solution avec vcds pour activer l'option fermeture des rétroviseurs merci impossible d'accéder au calculateur module comfort
Envoyé de mon SM-G975F en utilisant Tapatalk
mehdiloujdi est déconnecté   Réponse avec citation
Vieux 04/10/2019, 17h24   #2
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 69
Salut ,
Tu as quel version de vcds ?
Tes rétroviseur sont ils compatibles ?
---------- Post added at 15h17 ---------- Previous post was at 15h15 ----------
Pour le 2015 c’est cette manip
Next - Plug your VCDS in your laptop, and in your Car's OBD II port. Turn the car to Ignigition on (no need to start the engine)
Now do the following : Goto module 46
Function 07 (Coding)
Long coding Helper
Go to Byte 6
Make sure Bit 7 has a check mark in the box (Power Windows/Sunroof disabled after door opening)
- Don't ask me WHY you need this
Hit the "do it!
" To save the changes
NOW - Go to Module 42
Click Security Access
Hover over the security box, it will give you the access code - but it's 04354 in case you need it.
Then click "Adaptation"
Find the "System_Parameter_0-System_Paramater_blah_blah_blah_Byte 8" parameter
Open it up.... should have a stored value of 90. Change it to 95 or 99 (I did mine for 95).
Save everything and you're done.
Make sure your mirrors are already open, and then leave your mirror setting on R, L, or Off (I leave mine on R so the reverse dipping will work appropriately).
Get out of your car, take your key fob and press and hold the lock button...... like magic.... the Mirrors should fold.
Get back in the car, and turn the car on.... Voila, mirrors automatically re-open.
---------- Post added at 15h24 ---------- Previous post was at 15h17 ----------
Après regarde ce liens
https://ankk-vagcom.com/tiguan-5n-ra...tiere-ouverte/
The Following 3 Users Say Thank You to Alessiapia14 For This Useful Post:
djalil (15/07/2024), mehdiloujdi (04/10/2019), youcef_trik (11/10/2019)
Vieux 04/10/2019, 17h38   #3
mehdiloujdi
merci pour ta réponse version 18.9
et oui les rétro son compatible car sa fonctionne avec bouton sur portière
j'ai suivi ce tuto le module confort 46 n'est pas accessible sur ce modèle donc module central éléc 9 j'ai décocher l'option power windows mais toujours rien
a mon avis il faut faire du codage sur portière conducteur et passager mais il ya beaucoup d'option je suis perdu merci
---------- Post added at 15h38 ---------- Previous post was at 15h36 ----------
il n'y a pas System_Parameter_0-System_Paramater_blah_blah_blah_Byte 8 dans ladaptation de la porte il ya System_Parameter_0-System_Paramater0 1 2 3 4 5 6 7 8
et une longue ligne de code
Vieux 04/10/2019, 17h54   #4
mehdiloujdi
Voilà ce que j'obtiens dans la datation de la portière
Vieux 04/10/2019, 17h54   #5
Pouvoir de réputation: 175
Salam
essayes :
http://ankk-vagcom.com/golf-6-5k-rab...-retroviseurs/
sinon :
essayes avec VCP
Vieux 04/10/2019, 17h55   #6
mehdiloujdi
Parameter0
Vieux 04/10/2019, 18h26   #7
Alessiapia14
Ta le dégivrage des rétro ?
Vieux 04/10/2019, 18h43   #8
mehdiloujdi
oui j'ai le dégivrage
The Following User Says Thank You to mehdiloujdi For This Useful Post:
Alessiapia14 (06/10/2019)
Vieux 06/10/2019, 09h19   #9
Alessiapia14
Je cherche encore, je discute avec des techniciens en Italie qui font que ça de la customisation, si j'ai une réponse, je te le ferai savoir ![emoji6]
The Following 4 Users Say Thank You to Alessiapia14 For This Useful Post:
everson29 (30/10/2019), mehdiloujdi (11/10/2019), revo (11/10/2019), youcef_trik (24/08/2020)
Vieux 06/10/2019, 15h09   #10
Alessiapia14
Ton calculateur de porte c'est quoi la reference?
Mon contact m'as dit sur un Tiguan DE 2014 avec code 99 c'est à l'ouverture et fermeture du véhicule ,CODE 95 c'est ouverture a la mise sous contact ou fermeture a la coupure du contact, donc pour lui c est faisable sur le tien,il a besoin de ta. Réf calculateur de porte pour t aider.
Dernière modification par Alessiapia14 ; 06/10/2019 à 16h55.
Vieux 06/10/2019, 20h52   #11
fractal007
Avatar de fractal007
Pouvoir de réputation: 9
fractal007 will become famous soon enoughfractal007 will become famous soon enough
Permet de pouvoir rabattre les retroviseurs meme apres avoir coupe le contact et ouvert une portiere.
(Permet egalement de pouvoir fermer les vitres et le toit ouvrant)
[46 - Module confort] -> [codage- 07] -> [assistant codage Long]
octet 6 :
Bit 7 : Decocher < Power Windows/Sunroof disabled after door opening >
fractal007 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to fractal007 For This Useful Post:
abdel93 (07/10/2019), revo (11/10/2019)
Vieux 11/10/2019, 12h54   #12
mehdiloujdi
Envoyé par Alessiapia14 Voir le message
je démonte panneau de porte je te tien au courant merci
maximin (11/10/2019)
Vieux 11/10/2019, 15h54   #13
Alessiapia14
Salut, Ça roule on fais ça ![emoji6]
mehdiloujdi (21/10/2019)
Vieux 24/12/2019, 17h10   #14
taz_13
Avatar de taz_13
taz_13 is a jewel in the roughtaz_13 is a jewel in the roughtaz_13 is a jewel in the rough
Pour moi il faut aller dans codage long et le faire pour la porte passager et pour la porte conducteur.
Selon la version c'est un bit x ou y (des fois caché le 6) dans l'octet 4.
Et selon le modèle c'est comme les golf dans 42/security access - 16 adaptation.
Pourrais-tu mettre une photo de ton écran VCDS en codage long.
Bonnes fêtes de Noel à tous.
taz_13 est déconnecté   Réponse avec citation
Ajout d'otption sur 208 ( retro rabattable et chargeur cd) nono93 PSA Group Peugeot, Citroën 4 02/03/2017 16h58
Activation delphi 2014.3 jlm31 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 4 27/06/2016 14h27
activation delphi 2014.3 tom077 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 14 28/05/2016 10h19
problème retroviseur rabattable 208 1.6 hdi bmfrep Electronique 3 30/08/2015 21h49
Fuseau horaire GMT +1. Il est actuellement 04h58.
