Vieux 04/09/2019, 09h27   #1
Sven92
Avatar de Sven92
Sven92 is an unknown quantity at this point
Par défaut Megane II 1.9 dci hard idle, no throttle
Hi
I have a strange problem with megane cabrio.
Engine is struggling to start, everything mechanically is fine, injectors are tested and ok, almost every sensor is changed, wiring and voltages on ecu are ok.
It is rattling and struggling on idle, wont accept throttle, it is just idling.
no fault codes .
I have tried to change ecu, edc16c36 0281013907 by just cloning the eeprom and have the same problem.
Is it possible that eeprom is corrupted ?
I never had a similar problem before
Sven92 est déconnecté   Réponse avec citation
Vieux 04/09/2019, 23h25   #2
rokho
Avatar de rokho
Pouvoir de réputation: 9
rokho has a spectacular aura aboutrokho has a spectacular aura about
Saut,
Astuse très simple,vous dessoudez l'eeprom du calculateur d'origine,et la remplacez avec l'eeprom du calculateur q vous avez changer,bien sur si vous avez les même référence sur les 02ecu.
Moi je pense vous avez mâle fait le flache .
rokho est déconnecté   Réponse avec citation
Vieux 06/09/2019, 22h25   #3
Sven92
Avatar de Sven92
Envoyé par rokho Voir le message
Saut,
I have desoldered old eeprom and read it.
ther i desoldered new one, read it, deleted it and wrote bin from old ecu.
car has the same problem.
And I'm sorry, but I don't understand your second sentence
Rupteur / Hard cut EDC16 PSA WJon Chiptuning 13 04/07/2019 20h59
toyota petrol hard cut cartronics Chiptuning 1 22/06/2016 01h39
Nissan Idle Air Volume Learn adjustment without Consult or Scan-tool. Shadab Logiciel & autres documentations général 0 13/10/2015 00h55
iaw 59f full project( hard and soft ) Nizar-maoukil Immobilizer dumps/solutions 0 04/06/2015 16h40
calculateur bosh pas de soft et hard dybou Programmateur de composant (flasher) 3 28/03/2011 21h16
Fuseau horaire GMT +1. Il est actuellement 04h17.
