| Autoradio et Navigateur GPS Astuce, dump, aide pour décodage d'autoradio et navigateur. |
i was given the RCD 300 BLAUPUNKT CAR STEREO as a gift for my vw golf
REF VWZ1Z2H6470262 MODEL 1K0035182E can any one help me to get the working code for it please |
Essai le code 2565 Crdlt abdel |
| The Following User Says Thank You to abdel_ren For This Useful Post: | qwerty (25/03/2012) |
You must have a serial number begining with : Bpxxxxxxxxxxxx
thank you abdel_ren for your help
but the code is incorrect the serial number start with VWZ1Z2 NOT BP XXXXXXXXXX FOR THIS MODEL THAK YOU Dernière modification par cedrsan ; 25/03/2012 à 14h04. Motif: Fusion |
You must extract the dump of the eeprom 95640, To find the code for your radio
1-We must locate the eeprom 95640
2-Dessoder memory using a hot air station 3-Read the contents of the eeprom with an eeprom programmer as XPROG or BeeProg .... and finally send the binary file to the forum and will do the rest. |
thank very much
si tu veut un dump qui fonctionne très bien envoie moi message.
#10 |
#11 |
Pouvoir de réputation: 16 ![]() ![]() |
hi
>>>>>>>>>>>0292<<<<<<<<<<<< PASS PM |
#12 |
voici le fichier je l'ai extrais moi même .code 0054.
password par mp |
| The Following User Says Thank You to ziamo For This Useful Post: | ouragh (13/02/2014) |
#13 |
merci bien Ziamo
Dernière modification par cedrsan ; 28/03/2012 à 11h46. |
| [Résolu] blaupunkt fiat ducato cc | allaoua | Autoradio et Navigateur GPS | 4 | 25/03/2012 13h03 |
| [Résolu] Code autoradio blaupunkt | mom33 | Autoradio et Navigateur GPS | 7 | 21/03/2012 11h14 |
| [Résolu] autoradio clio3 blaupunkt bloqué!! | solution auto | Autoradio et Navigateur GPS | 7 | 13/02/2012 21h55 |
