Vieux 15/11/2017, 06h09   #16
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
If you have had a virus, you may already have file corruption, run the following commands to ensure all is fixed, or you might want to consider formatting and reinstalling Windows and applications.
Open an Administrators CMD and Run the following commands in sequence:
C:\WINDOWS\system32>chkdsk /b /f /v /scan c:
C:\WINDOWS\system32>DISM /Online /Cleanup-Image /StartComponentCleanup
C:\WINDOWS\system32>DISM /Online /Cleanup-Image /AnalyzeComponentStore
C:\WINDOWS\system32>DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:G:\Sources\Install.wim:1 /LimitAccess
C:\WINDOWS\system32>SFC /SCANNOW
Simple est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Simple For This Useful Post:
adiago (15/11/2017), manudiag (15/11/2017), souague (23/11/2018)
Vieux 15/11/2017, 13h15   #17
manudiag
Avatar de manudiag
manudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nice
Hello
thanks i scans tonight if i have enough time, but i think windows defender has destroyed the clip activation crack and it has to delete a file for diagbox but i do not know which one
thanks, I'll let you know
merci je scanne ce soir si j ai assez de temps , mais je pense que windows defender a detruit le crack d activation de clip et il doit supprimer un fichier pour diagbox mais je sais pas lequelle
merci je te tient au courant
manudiag est déconnecté   Réponse avec citation
Vieux 16/11/2017, 17h58   #18
Larson92
Avatar de Larson92
Pour info, Diagbox previens de ne pas faire la mise a jour vers W10
Le savoir n'est rien si le savant n'a pas la noblesse de le partager...
The Following User Says Thank You to Larson92 For This Useful Post:
manudiag (16/11/2017)
Vieux 20/12/2017, 16h44   #19
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Slt
Diagbox 9.12 fonctionne avec WIN 10 maintenant
Pour la version 8 il faut prendre WIN 7 en 32 bits
maitresox est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to maitresox For This Useful Post:
adiago (01/10/2019), damiano59 (20/11/2018), manudiag (31/12/2017), souague (23/11/2018), Staza (20/12/2017)
Vieux 20/12/2017, 17h21   #20
Staza
Avatar de Staza
Staza is a jewel in the roughStaza is a jewel in the roughStaza is a jewel in the roughStaza is a jewel in the rough
Je te conseille d'installer sur windows 7 32 bits aucun problème win 10 poubelle !!!
Staza est déconnecté   Réponse avec citation
The Following User Says Thank You to Staza For This Useful Post:
manudiag (29/01/2018)
Vieux 20/12/2017, 19h22   #21
Heineken
Avatar de Heineken
Pouvoir de réputation: 31
aucun soucis sous windows 10 32bit avec version 7.xx , je m'en sers régulièrement ...
The Following User Says Thank You to Heineken For This Useful Post:
Vieux 31/12/2017, 19h01   #22
manudiag
Avatar de manudiag
salut a tous
maitresox je sais pour diagbox 9.12 c est ok sur windows 10, j ai fait l upgrade au boulot , mais pas encore cracker a moins que tu es réussi mais que tu ne diffuse pas et je comprend parfaitement ton point de vu tes mésaventure avec tes version tlemcen
Heinken diagbox version7XX ne fonctionne plus depuis la version de Windows 10 update 1709 et prend jusqu a 7.57 après il bloque c est Windows qui le bloque j ai mis une exception mais ça ne change rien j ai peu être pas fait toute les exception qui fallait , avant cette mise a jour tous fonctionner bien
il m a scratcher clip aussi mais ça refonctionne depuis la dernière version de clip avec l exception
merci a vous
Vieux 29/01/2018, 21h06   #23
manudiag
Avatar de manudiag
Envoyé par souague Voir le message
Pour ma part, ok sous W10 x32 update 1709 en v7.57.
si tu fait une mise a jour de 7.57 a 7.58 ça marche ou pas ?
pour moi non ça bloque c est Windows qui empêche le fonctionnement
9.12 fonctionne en win 10 et je doit vérifier mais je crois qu il est en 64 bits il me semble
par contre il est en version update 1609
a suivre
Vieux 05/02/2018, 20h42   #24
repcles
Avatar de repcles
repcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to behold
slt a tous nouvelle mise a jour diag box 9.17 avec trois marque dispo
peugeot
ds et citroen
Vieux 06/02/2018, 17h07   #25
Heineken
Avatar de Heineken
As-tu fait cette maj sous W10 1709 ?
Zenata a sûrement raison quand il dit qu'il vaut mieux rester sous W7 (ou xp) pour les précédentes version de DiagBox.
J'ai discuté avec un tech. Citroën, ils étaient sous W7 jusqu'à la v8.5, ensuite ils sont passé à W10 et DiagBox v9.0.
je suis sous diagbox 7.62 avec windows 10 à jour , et aucun soucis.
manudiag (10/02/2018)
Vieux 10/02/2018, 02h59   #26
louay
Avatar de louay
bonjour j'ai exactement le même probleme depuis la mise a jour 7.57 vers 7.58 erreur "problème d'accès aux données"
---------- Post added at 02:59 AM ---------- Previous post was at 02:58 AM ----------
je suis sur win10 64
Vieux 10/02/2018, 15h57   #27
manudiag
Avatar de manudiag
Envoyé par Heineken Voir le message
il me semble que c est windows 10 qui me bloque meme probleme sur deux pc different
et meme probleme si je refait une install , et sans antivirus
j ai du donne des exclusion pour execute plusieurs logiciel depuis cette mise a jour meme des logiel officiel avec licence
tu as fait comment pour le faire tourner ?
Vieux 10/02/2018, 17h14   #28
Heineken
Avatar de Heineken
Envoyé par manudiag Voir le message
J'ai rien fais de spécial .
je maintient l'ordi à jour , rien de plus.
En ce qui concerne le diiag je fais tourner diagbox , clip , odis , vaspc , delphi , wow .... tout est ok sous windows 10 32bit.
Tu parles "d'exclusion" , tu parles d'antivirus là , non?
Vieux 10/02/2018, 17h29   #29
manudiag
Avatar de manudiag
je fait aussi les mises a jour via Windows update il le fait en automatique
l exclusion c est dans Windows il me bloque des logiciels qu il considère comme pas original
la je suis avec un windows 7 je ne peu pas te mettre une capture écran
j ai du faire la même chose avec clip pour qu il refonctionne
merci pour ton aide
Vieux 10/02/2018, 17h45   #30
Heineken
Avatar de Heineken
merci pour ton aide
En tout cas , je n'ai jamais eu ce problème .
Mise a part , parfois windows defender qui mets les "exe" en quarantaine , mais résolu une fois restaurer et mis en exclusion , rien d'autre . Mais là c'est l'antivirus windows , mais si tu me dis que ce n'est pas ça.....
une capture ecran du message serait pratique pour avoir une idée , peut être...
Diagbox windows 8 carto LEXIA, PP2000, DiagBox 6 29/03/2015 10h22
windows 7 et diagbox klif26 LEXIA, PP2000, DiagBox 8 19/09/2014 10h39
diagbox et windows 8.1 tonio5766 LEXIA, PP2000, DiagBox 2 14/04/2014 20h08
diagbox windows 7 32b sur netbook alexio LEXIA, PP2000, DiagBox 0 24/02/2014 21h17
Fuseau horaire GMT +1. Il est actuellement 19h15.
