Vieux 20/02/2017, 12h39   #1
Ian995
Avatar de Ian995
Ian995 is an unknown quantity at this point
Par défaut Défaut 207cc boot ouvert
J'ai un 2008 207cc qui vient avec une coupure ouverte de démarrage parfois quand je m conduis
La botte n'est pas ouverte
Veuillez indiquer l'emplacement du capteur pour ce
Ian995 est déconnecté   Réponse avec citation
Vieux 20/02/2017, 21h37   #2
rilou25
Avatar de rilou25
rilou25 is an unknown quantity at this point
Hello
can you explain the problem in English , because I don't understand with the translator
thanks
rilou25 est déconnecté   Réponse avec citation
Vieux 21/02/2017, 10h30   #3
Ian995
Avatar de Ian995
Hi
The 207 CC has a open boot fault coming up sometimes when driving
The boot is not open
where is this sensor which is givin this fault ?
Vieux 21/02/2017, 13h27   #4
Zangief
Avatar de Zangief
Zangief has a spectacular aura aboutZangief has a spectacular aura aboutZangief has a spectacular aura about
Envoyé par Ian995 Voir le message
Hi
Hi Ian995
Could you post here the fault code ?
Zangief est déconnecté   Réponse avec citation
Vieux 21/02/2017, 15h11   #5
doud77
Avatar de doud77
Hi,
I think the switch is in the boot lock itself (internal component)
Vieux 21/02/2017, 15h18   #6
rilou25
Avatar de rilou25
Hello
I don't think it's a sensor problem.
Car rolls when this happens and you do not give a default code.
Do you have games at the level of the contact key? Can you do the test with only the car key and not all your key ?
I have already seen a false contact with a key too heavy.
A +
Vieux 22/02/2017, 11h37   #7
Ian995
Avatar de Ian995
Hi
No fault code is detected using Diagbox
The boot open message happens sometimes when driving and then goes away
The car is a 207 CC
I can open the boot with the remote key and close it but the fault is still happening randomly
DEMANDE CLEAR POUR 207CC - autoliv 609221000 - 9664066680 suez13008 Airbag 3 13/10/2015 17h32
Peugeot 207cc Mezz PSA Group Peugeot, Citroën 2 23/10/2012 21h35
calage chaine de distrebution 207cc stofa-25 Mécanique générale 6 28/12/2011 16h37
probleme ralenti sur une 207CC moteur 1.6 Amine-TE PSA Group Peugeot, Citroën 20 26/12/2011 21h01
Fuseau horaire GMT +1. Il est actuellement 13h28.
